Originally Posted by nissanh
Done with the axle:
The OEM retainer went in without an efforts: The TIMKEN retainer was TOO tight and it cause the tool and ring the bend.
Please take a look.... Did the grease and sharpie test.. What do you think?
The new space between the retainer and the polished end is 4 mm
I can't really see where the seal wiped away the sharpie mark and the delineation of where the seal pushed the grease back on the retainer is sort of hard to tell too. Try just doing the sharpie test and fully snug the axle into the housing with the 4 nuts and then turn the axles several times so we can get a clear visual of where the seal is riding on the retainer. I know from experience that 4mm of polished axle showing should be fine with the retainer flipped but it would be nice to have better confirmation before you bolt it back up.
