Old 12-16-2019, 05:15 PM #1
oncewaspfd oncewaspfd is offline
oncewaspfd is on a distinguished road
Sudden loss of gas mileage
I got tired of seeing the check engine light on in my 02 4runner. Had a smoke test done and I replaced the charcoal evap canister. I went from 16 mph down to 13 mph. What gives?
oncewaspfd is offline   Reply With QuoteReply With Quote
Old 12-16-2019, 06:10 PM #2
MStudt's Avatar
MStudt MStudt is offline
official vendor
MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all MStudt is a name known to all
official vendor
MStudt's Avatar
The problem is winter. It's well documented that our 4runner's mpg suffer in the cold months due to fuel mixtures.
Mike
MStudt is offline   Reply With QuoteReply With Quote
Old 12-16-2019, 06:29 PM #3
T4Rchadly's Avatar
T4Rchadly T4Rchadly is offline
Real Name: chad morrison
T4Rchadly is just really nice T4Rchadly is just really nice T4Rchadly is just really nice T4Rchadly is just really nice
T4Rchadly's Avatar
dang is that what it is? i was getting nearly 270 miles to a tank only highway driving this summer/later fall and i noticed i can only get 200 after i changed out my RTT to my rocket box for ski season now that winter hit. i was getting suspicous about it as my truck runs and drives like its brand new as ive replace almost every component with OEM parts.
T4Rchadly is offline   Reply With QuoteReply With Quote
Old 12-16-2019, 06:38 PM #4
STI_MECE's Avatar
STI_MECE STI_MECE is offline
STI_MECE will become famous soon enough
STI_MECE's Avatar
Originally Posted by MStudt View Post
The problem is winter. It's well documented that our 4runner's mpg suffer in the cold months.
Mike
That makes me scratch my head. Cooler air is denser.....
Sent from my Pixel 3 XL using Tapatalk
2000 SR5 4x2 Resto/Maintenance
STI_MECE is offline   Reply With QuoteReply With Quote
Old 12-16-2019, 06:44 PM #5
T4Rchadly's Avatar
T4Rchadly's Avatar
thats what i was thinking.. im aware that states use a different blend gas during the winter time also though.
Old 12-16-2019, 07:02 PM #6
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
This is the exact reason for the loss of mpg. Plenty of links here with the same out come. I had the same issue while living in Missouri. Once November came around my mileage went to sh*t until around March, and this happened each of the 4 years of living there with my 4runner.
Mike
Old 12-16-2019, 07:05 PM #7
JMat's Avatar
JMat JMat is offline
JMat will become famous soon enough
JMat's Avatar
These trucks run in open loop a lot longer in cold weather areas not to mention many let them idle to warm up before they jump in in the morning.
1998 Toyota 4Runner 3.4 4x4 with 340,000 miles.
199mm TBU-Bilstein 4600-'99 Tall Springs(Rear).Almost Totally Stock
1997 Toyota 4Runner 3.4 4x4 with 247k miles-Project car
JMat is offline   Reply With QuoteReply With Quote
Old 12-16-2019, 07:19 PM #8
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
Mike
You can let you 4runner warm up for 12 hours, and it's not going to change the mixture of the fuel you bought. Do a search, and you'll find these exact same results.
Mike
Old 12-16-2019, 07:52 PM #9
Thanks everyone. I thought I screwed something up when I installed it.
Old 12-17-2019, 11:21 AM #10
MStudt's Avatar
official vendor
official vendor
MStudt's Avatar
It would have been very difficult to install a charcoal canister wrong on an 02 due to the hose lengths. After the original being installed for nearly 20 years the hoses aren't going to be flexible enough to reach another inlet/outlet on the canister.
Mike
Old 12-17-2019, 12:09 PM #11
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Like MStudt said, fuel mixtures change for winter. Combine that with your engine taking longer to reach operating temp and closed loop and gas mileage suffers. Cooler air is a plus, but all the anti-gelling additives they put in gas is a much bigger minus. If you think that your gas didn't change because you live somewhere warmish during the winter then please know that it did. It doesn't have as much additives as the great white north, but they're still present.
Old 12-17-2019, 12:16 PM #12
mesooohoppy mesooohoppy is offline
mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about
oh wow, this is a great thread. in the past, i have alway put 91 in my cars as that is what they called for. when i bought my 4runner that is what i used, just out of habit. when i lifted it and put 33s on it a couple of months ago (near the end of summer). i saw i was getting terrible mileage and just chalked it up to being the heavy SCS wheels and tires. my buddy told me to try out 87 and so far it seems like its been longer between fill ups. i will have to actually fill the tank up and do the math.
99 4runner limited; imperial jade mica
IG: mesooohoppy
mesooohoppy is offline   Reply With QuoteReply With Quote
canister , charcoal , evap , mph , replaced
Sudden oil loss. UPDATE sawguy 3rd gen T4Rs 34 03-22-2018 10:50 AM
Sudden oil loss. sawguy 3rd gen T4Rs 14 03-05-2018 12:02 AM
14TE sudden brake performance loss THEDK 5th gen T4Rs 1 04-18-2016 08:59 PM
Sudden drop in mileage Cumby 4th Gen T4Rs 8 01-11-2015 11:27 PM
sudden loss of mileage axpilot 3rd gen T4Rs 7 07-01-2011 03:48 PM
