Old 02-18-2021, 05:50 PM #16
LarryWestKY LarryWestKY is offline
Real Name: Larry Keith Morris
LarryWestKY is on a distinguished road
P0171
2000 t4r 3.4 rough idle, losing power, no vacuum leak, gas mileage is quickly dropping. I don't know how to post pictures of data. This is what it read
Calc Load
ECT
STFT B1 LTFT B1
Eng RPM
22.7 %
189 (°F
-08 %
258 %
713
Stft was -0.8
Ltft was -25.8
WTH is wrong?
LarryWestKY is offline   Reply With QuoteReply With Quote
Old 02-18-2021, 05:56 PM #17
spartacus's Avatar
spartacus's Avatar
o
Calc Load
ECT
STFT B1 LTFT B1
Eng RPM
22.7 %
189 (°F
-08 %
258 %
713
Stft was -0.8
Ltft was -25.8
WTH is wrong?
I can't quiet grasp your data posted but p0171 is an unmetered air and lean code. Clean or replace your maf if you don't have a vacuum leak. It could also be related to fuel pressure which would mean, fuel filter, fuel pump (test the resistance) or very seldom fpr
edit: iF the air fliter is dirty replace that too..
Old 02-18-2021, 07:26 PM #18
HiLife HiLife is offline
Your ecu is trying to make up for a lot of air entering after the maf.
Hence to almost pegged -25.8 LTFT.
The extra air could be coming in almost anywhere between the manifolds and maf. Most common one is the aging rubber coupling right before the throttle body.
Old 02-19-2021, 12:02 AM #19
I sprayed that hose/line with carb cleaner. All vacuum lines were soaked and no difference in idle. Is there any other way to check that?
Old 02-19-2021, 09:27 AM #20
Check the vacuum hose going to the fuel pressure regulator for the presence of fuel.
If the for bellows is ripped and leaking, raw fuel could be traveling through the vacuum hose.
Sorry, got confused earlier. The ecu is trying to lean out the engine cause its seeing too much fuel.
Old 02-19-2021, 10:50 AM #21
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Calc Load
ECT
STFT B1 LTFT B1
Eng RPM
22.7 %
189 (°F
-08 %
258 %
713
Stft was -0.8
Ltft was -25.8
WTH is wrong?
Likely a stuck open injector, but try pulling the vacuum line off the fuel pressure regulator to see if there's any fuel in the vacuum line or coming from the vacuum line fitting on the fuel pressure regulator. Your engine is trying to reduce fuel so it's not a vacuum leak or unmetered air. How does your exhaust smell?
cel , fine , idle , runs , truck
High idle is driving me crazy T4Rscott 3rd gen T4Rs 16 11-19-2019 11:14 PM
98 4 runner ,crazy idle andres4runner 3rd gen T4Rs 22 04-09-2018 04:25 PM
Crazy pulley issue Gremcat Classic T4Rs 5 06-30-2014 09:09 AM
Spectre6000's Crazy Idea Thread #4: Idle Up spectre6000 3rd gen T4Rs 13 08-24-2012 12:06 AM
IDLE acting all kinds of crazy whacked out! 4x4runner91 Classic T4Rs 11 02-10-2009 08:55 PM
