Old 12-18-2019, 03:58 PM #1
thobry's Avatar
thobry thobry is offline
thobry is on a distinguished road
thobry's Avatar
Blue sea switches: whatís the difference
Is there a difference in using a 300 amp M-series battery switch ($24 on amazon) vs a 100 amp 187 series circuit breaker switch ($52 on amazon)?
I see thereís a price difference but could I just use the M-series battery switch to disconnect my blue sea fuse box from the battery system in my 4Runner?
Thanks!
thobry is offline   Reply With QuoteReply With Quote
Old 12-18-2019, 05:54 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 will become famous soon enough jgue467 will become famous soon enough
jgue467's Avatar
Why not use a relay? https://www.amazon.com/Stinger-SGP32...SBQKVHEJ6R15FF
Luck.
2001 Limited 4WD - 320K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL
StopTech slotted rotors - Magnefine trans filter - In series trans cooler, Original: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and on and on. WooHoo!!
Old 12-19-2019, 12:51 PM #3
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe will become famous soon enough Kanoe will become famous soon enough
Kanoe's Avatar
I see there’s a price difference but could I just use the M-series battery switch to disconnect my blue sea fuse box from the battery system in my 4Runner?
Thanks!
Sure you could use a switch as a disconnect, but the purpose of the circuit breaker is that it will trip if any piece of downstream work shorts out. It will prevent fires or damage.
Why not use a Maxi-fuse holder right off the battery? They come in 60, 80, not sure if 100 also, maybe. That will be cheap and still protect. Or put the maxi-fuse before the switch if you still want the on/off feature.
People go for the breaker as it is the neatest solution.
Edit: after looking at the 2 products, there is also the size factor. The switches are kind of big and bulky for under hood work. The blue seas breaker is smaller and neater.
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
Kanoe is offline   Reply With QuoteReply With Quote
amp , battery , blue , difference , switch
PDX, OR: AOB "LED Light Bar" and "Rear Lights" Switches - Blue pbcolt For Sale: T4R Items 4 03-26-2018 06:45 PM
Coil colors. Blue/Blue front. Single orange rear? Tstinson 3rd gen T4Rs 0 06-19-2016 06:39 PM
Air on Board Switches...why no blue for 2016 model? live_discover 5th gen T4Rs 21 03-21-2016 09:41 PM
*URGENT* *HELP* Front Spring ID, Blue/Red & Blue/Blue; which side is which? Please! TheFriZ 3rd gen T4Rs 19 07-18-2014 05:45 PM
Copyright © 2019
