Old 12-18-2019, 11:19 PM #1
seanshreds seanshreds is offline
seanshreds is on a distinguished road
HELP! Cannot remove upper half of transmission dipstick tube
Hi all, I am in the process of changing the starter in my 4wd v6 3rd gen and it has more than lived up to the bad hype. I have spent multiple days trying to get the upper half of the transmission dipstick tube out but it will not budge. I have even put a pair of vice grips on trying to pull and twist and made no progress. It supposed to just be held in by an o-ring but it honestly feels like someone stuck some jb weld on it the last time it was pulled out.
Has anyone experienced this before and if so, what did you do to get the darn thing out? I am tired of not being able to drive so I am getting to the point where I might just cut the top half off the tube and forget about it until my next transmission fluid flush.
Thanks in advance for any advice!
1997 4Runner SR5, 4WD, Shred Mobile
seanshreds is offline   Reply With QuoteReply With Quote
Old 12-18-2019, 11:29 PM #2
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
yes this is common if nobody has ever removed it. spinning it has always worked for me. if it's rusted into place then it might now be a non removable part.
I would say try a torch and heat it up but I'm pretty sure ATF will burn. I can't imagine it would start a fire inside the trans but... not sure it's worth that kind of risk.
Old 12-18-2019, 11:43 PM #3
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
If it comes down to having to cut off the upper half of the dipstick tube you might as well drop the pan and replace it, pn 3510635110. I had to replace mine shortly after i got my 3rd gen bc the drain plug was stripped. I'm assuming you removed the 12mm bolt that holds the upper tube in place.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 12:58 AM #4
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
It should come right out once that one bolt is removed. There's literally nothing else holding it in place.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 02:45 AM #5
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
agree,
mine had no issue coming apart after bolt removal
2002 tundra ac v8 4wd
1969 kharmann ghia
Old 12-19-2019, 12:56 PM #6
There are at least two dipstick tube part numbers, depending on emissions package (and 2WD vs. 4WD, but that's not an issue here). Make sure you get the right one if you need a new one.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-19-2019, 01:51 PM #7
fourfive's Avatar
fourfive's Avatar
The part number I referenced was for the transmission pan but still should have clarified since there are multiple part numbers for transmission pans. I've seen at least 3: 35106-35110 (for my 02 4wd), 35106-34010, 35106-34020
seanshreds, if you cut the dipstick tube & go the route of getting a new pan, you will have to buy a new dipstick tube & transmission pan.
Old 12-19-2019, 03:29 PM #8
Thanks for all the responses! To everyone who mentioned the upper bolt on the dipstick tube, I can assure you that I have removed all of the necessary bolts (including the upper one holding it to the engine). I know it should be easy to remove but it is just stuck.
I am going to give the vice grips another shot but if that does not work, I might cut it and replace the pan later.
Old 12-19-2019, 08:08 PM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Soak that joint with heavy duty penetrating oil. I am trying to recall if a little o ring is in that joint as well.. That really should come apart for you.
Old 12-19-2019, 08:29 PM #10
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
There is an o-ring on the upper half. Mine was caked up with crud and a bit stiff to pull apart. Have someone that sprayed something that eats rubber and I can see that o-ring chemically melting into place.
I'd hit that joint with MAP gas and give it a good twist, might be enough to seperate and need only a replacement o-ring. Worst case, I'd cut it off as close to the joint as possible, but leaving something to get ahold of. Drop the pan and work on it off the vehicle, you'll absolutely get it out that way and not need a replacement pan, just the upper section.
Brian. is offline   Reply With QuoteReply With Quote
Old 12-19-2019, 09:23 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I couldn't recall thanks @Brian. Hard to say what PO did. At this point though. It either has to come apart or get cut off. So I try a few things to see if you can get it loose. Even a heat gun might expand the metal some then hit it with freeze off to try to get that joint apart
Old 12-20-2019, 01:06 AM #12
BoomerBob's Avatar
BoomerBob's Avatar
This is my 2wd dipstick where the O-ring is after pulling it out.
This thread reminded me of another the OP might want to check out.
Trans dip stick tube - top stuck to bottom and won't come out
Old 12-20-2019, 01:38 AM #13
Thanks for all the responses! I decided not to cut for fear of getting little metal shavings in the tranny. Instead, I decided to take the starter apart from inside the engine bay and pull it out in pieces. I did the same thing to put the new one in. Next time I flush the tranny I will probably drop the pan and see if I can separate the tube joints with some heat. Thanks again for all your help!
Old 12-20-2019, 01:40 AM #14
BoomerBob, I had already read that post before posting mine. That is where I got the vice grip idea. Thanks though!
Old 12-20-2019, 09:45 PM #15
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Glad you got your starter fixed but major bummer on that tube. You may need to use a lift to get enough clearance to pull the tube in one peace. Not 100% on sure on that one as I never seen one rust solid.
Understand not wanting to cut it though.
dipstick , half , transmission , tube , upper
2004 4Runner Transmission Dipstick Tube Cracked - Help TNcaveman 4th Gen T4Rs 4 07-26-2018 10:39 AM
Advice Needed On Bent Transmission Dipstick Tube atalarico 3rd gen T4Rs 10 06-14-2016 02:38 PM
Automatic Transmission upper and lower dipstick Oring? beer-toe 3rd gen T4Rs 10 04-23-2016 01:58 PM
Rusted dipstick tube bantis556 4th Gen T4Rs 4 07-18-2013 02:02 PM
