Old 12-21-2019, 12:43 AM #1
Rancho5 Rancho5 is offline
Rancho5 is on a distinguished road
02 Sport leaving my garage. Anyone recommend a great car cover?
Bought a 2010 Matrix and she neees to go into the garage, which means the Thundercloud Sport will be parked alongside the House. I値l drive her regularly, but I知 sure the Matrix will be driven more. I値l put a BatteryMinder on her while she痴 outside but need recommendations for a good car cover to protect her.
Any 3rd Gen specific covers you壇 recommend?
02 Thundercloud Sport, 155k.
Rancho5 is offline   Reply With QuoteReply With Quote
Old 12-21-2019, 12:53 AM #2
photoleif photoleif is offline
Real Name: Leif
photoleif will become famous soon enough
Real Name: Leif
i looked into vehicle covers and went with a garage-in-a-box instead. i'm not 100% in love with it, but i do know that there's no rubbing on the paint and such from it.
'99 'Highlander' 4R SR5 5VZ-FE | 5-spd | LED lighting | TBU | 265-75R17 Duratrac stuffed after some pinch-weld convincing
'95 Xtra cab 5VZ-FE swap 5-spd | 33x10.50-15 BFG AT/KOs | 4" Superlift | ARB rear locker | OME torsion bars | Total Chaos idler arm & uniball | Smittybilt bumpers | Sportsman topper | Aisin manual hubs | K&N | Dual Optimas | Extended diff breathers | Bilstein 5100s | De-striped | Hella pencil-beams
photoleif is offline   Reply With QuoteReply With Quote
Old 12-21-2019, 03:56 AM #3
TRD 4RNR's Avatar
TRD 4RNR TRD 4RNR is offline
TRD 4RNR will become famous soon enough
TRD 4RNR's Avatar
I've been using this for the last few years - purchased via Amazon:
ShelterLogic 10' x 15' x 8' All-Steel Metal Frame Peak Style Roof Instant Garage and AutoShelter with Waterproof and UV-Treated Ripstop Cover
1999 "Highlander" V6 4WD E-Locker || TRD Supercharger, URD 7th Injector, 2.2 Pulley || Toytec Aluma Series Boss Suspension, SPC A-Arms, Durobumps, Overland Endlinks || B&M Trans Cooler || 231mm Tundra Brakes, SS Brake Lines || 17" TRD Pro Wheels || BFG KO2 265/70R17-C || TRD Exhaust || 01-02 Tail Lights || Original Owner
TRD 4RNR is offline   Reply With QuoteReply With Quote
Old 12-21-2019, 09:20 AM #4
Mantilgh Mantilgh is offline
Mantilgh will become famous soon enough
Car covers are good for keeping dust off of your vehicle while parked in a garage.
Outdoors they get destroyed quick and scratch the heck out of your paint but it should prevent some UV damage
Mantilgh is offline   Reply With QuoteReply With Quote
Old 12-21-2019, 11:45 AM #5
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
As several others said, inexpensive car covers will scratch paint as the material flaps somewhat in the wind.
Now I don't have one yet I've read there are some that will not scratch yet of course those I'm sure are not the cheap ebay and possibly amazon. Above all read reviews and ask questions before you buy.
Luck and enjoy that Runner.
Old 12-21-2019, 12:14 PM #6
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Worse than the scratching is the fact they trap moisture, then become a sauna on sunny days. This can/does quickly and easily destroy the clearcoat.
OP, skip the battery tender too. I spent 3 decades as a motorcycle mechanic, I've seen hundreds of batteries killed by those things when they were left plugged in full time as people over-winter their toys. I know, the advertising all claims they go into "float" mode and won't do that... you always believe advertising meant to sell you a product? Even the best of the new generation (read, not inexpensive) battery chargers can/do/have killed batteries left on full-time connections. One day a month is Plenty to keep a battery ready to go anytime you want to drive. Or, simply drive the vehicle for 30 miles or more one time a month (if you're not going 30 miles or more, don't bother to start it as you won't give the oil enough time to cook off residual water and byproduct acids from combustion, instead you just spread it around the engine ~ and prolonged idling is even Worse than not starting it).
I have 4 vehicles between 2 people here. Only 2 covered spots, though I'm working on adding 2 more. Keep the sun off the paint is the #1 thing you can do to keep it looking good, but that only postpones the inevitable. Keep a good "wax" (some sort of paint protection) on the vehicles, I'm old and like actual wax so it's something I apply every 3 months. And drive the vehicles once a month for at least 30 miles (well, that's good for non-winter states, if you're trying to drive on a day when the high is only -10f, you probably want to up the drive time by double). I use all the systems of the vehicle on those drives too, A/C, Heat, window washers, 4wd, etc... anything not used tends to deteriorate faster. I have an expensive battery charger/tender (that has a couple "restoration" functions too), I use it once a Year just as a preventative thing. Try to correct any potential damage and prolong the battery life. 8~10 years out of a battery is normal for me... well, had one car that needed one every 5~6 years lick clockwork but that was the norm for that car across all owners.
Brian. is offline   Reply With QuoteReply With Quote
Old 12-21-2019, 05:45 PM #7
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
They're all kind of crap. That said, scratching my head at why a ten year old economy car gets the garage instead of a 4Runner. Defeats the purpose of the economy car.
I use a battery tender year round. My batteries work.
Old 12-21-2019, 06:03 PM #8
STI_MECE's Avatar
STI_MECE STI_MECE is offline
STI_MECE will become famous soon enough
STI_MECE's Avatar
Leave the car covers alone. Cleaning and waxing the car regularly is way better than covering it up.
Just because you don't drive it doesn't mean it needs to be washed and maintained. The car cover will only make things worse for you.
Sent from my Pixel 3 XL using Tapatalk
2000 SR5 4x2 Resto/Maintenance
STI_MECE is offline   Reply With QuoteReply With Quote
car , cover , i値l , matrix , sport
Recommend a Garage/non-portable Air Compressor IL_Fletch Off Topic 8 09-07-2017 04:15 PM
2004 4-Runner Sport... just got totaled. Recommend buying a 4thgen with 150k+ miles? Lumberg 4th Gen T4Rs 36 10-03-2014 10:44 AM
It's a great day! New (to me) Snap On tool box in the garage!! Jeff T General Discussions 12 11-23-2011 07:02 PM
Starting My build 02 Sport. Recommend me a wheel size! ar1five 3rd gen T4Rs 12 11-04-2011 04:50 PM
Anyone recommend a remote start for 06 sport 4r? flnycus 4th Gen T4Rs 2 10-17-2010 06:44 AM
