Old 12-21-2019, 02:48 PM #1
benjamin247's Avatar
benjamin247 benjamin247 is offline
benjamin247 is on a distinguished road
How to measure for leveling height?
Added a heavy duty front bumper and want to level out my rig. How do I know how much height I need to level and which leveling kit to get?
1999 Black SR5 5-speed 4WD Rear e-locker
Suspension: Toytec 3" Ultimate Lift, JBA STD High Caster Upper A-arms, Eimkieth PCK
Wheels/Tires: Method 305 NV Bronze (16x8 | 0/4.5"), Goodyear Duratracs 285/75-16, 1.25" Spidertrax Wheel Spacers
Others: SRQ Fabrications Flush Grille, TJM T17 Front Bumper, Magnuson Supercharger, URD 7th Injector, Rock Gray Avery vinyl wrap, TG Sliders
benjamin247 is offline   Reply With QuoteReply With Quote
Old 12-21-2019, 04:19 PM #2
BrianK14 BrianK14 is offline
BrianK14 is on a distinguished road
Measure from center of hub to bottom of fender flare to know how much lift you need. How to lift depends on several issues. How good a ride do you want? Do you off-rad? How much do you have to spend? But, options are, from worst to best, spring spacers, top-hat spacers, adjustable shocks, and full coil-overs. You'll have to do some more research to determine which option is for you.
BrianK14 is offline   Reply With QuoteReply With Quote
Old 12-22-2019, 11:21 AM #3
Js'00imited4runner's Avatar
Js'00imited4runner Js'00imited4runner is offline
Js'00imited4runner will become famous soon enough
3rd Gen 4Runner Lift Information and FAQ's
This is really helpful as far as Lift/armor/suspension etc. go.
You probably should have had the front end suspension figured out before you had the bumper installed due to the fact you have that extra weight now to deal with after. Also you didn't give specs of the bumper. Manufacturer is it Plated/tube/winch mount/no winch mount/combined weight with or without a winch. Give a little more info and you might get a few more bites.
Also post a pic and show it off! Cheers.
2000 Limited 4wd Millenium Silver Metallic, E rear locker, KYB Monomax All around, '99 tall coils up front with daystar 1" spacer, OME 890's in back, Weathertech Floor and cargo Mats, Track decal shackle Brackets, Satoshi grill mod (wahoo), Diff breather mod, 200k+ and still going strong!
Js'00imited4runner is offline   Reply With QuoteReply With Quote
Old 12-22-2019, 12:09 PM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
What you need to do first is figure out what else, if anything, you plan on adding to your rig like a winch, rear bumper, roof top tent, sleeping platform in the back, etc etc, and then match a suspension set-up for the extra weight you've added and the lift you want.
If you get your front level, your rear will be sagging every time you load it down for a trip. Many guys like me choose to have a positive rake (rear higher than the front) so you can load down the back cargo area and not be sagging in the rear.
Getting your suspension right is a little trial and error and it's quite common for guys to choose one set-up and then switch something out pretty soon afterward because the set-up didn't work out as planned. With my suspension set-up, I quickly realized the rear springs I got weren't anywhere close to what I needed to support the weight I carry.
Anyway, I hope this helps.
height , kit , level , leveling , rig
Ever measure your rocker pinch weld height? INTMD8 Classic T4Rs 1 08-11-2014 07:45 AM
Ahh ... Height control and adjustable tail end height? coconutpete 4th Gen T4Rs 3 02-26-2013 11:49 AM
Can someone measure the stock hitch height for me? AddictedOffroad 4th Gen T4Rs 5 09-05-2012 04:19 PM
How to measure sag? Barak 3rd gen T4Rs 3 06-20-2011 07:03 PM
Gas measure hani1400 3rd gen T4Rs 4 04-02-2008 05:21 PM
