Old 12-23-2019, 02:56 PM #1
Hollywood1 Hollywood1 is offline
Hollywood1 is on a distinguished road
Front Shock, Coil, recommendations. Possible leveling Coil.
So while fixing my GFs 02 Evap leak on the Tank Check Valve. I noticed a good amount of Oil residue from a few leaks. I had cleaned it up prior to get a better idea of where the leak is coming from and Im most certain its from the Valve covers. But it also looks like the front Passenger shock is blown and leaking as well.
As for the valve covers, Im gonna do a reformist first until I can get to the timeing belt swap mid next year.
But Ill have to get the Front shocks replaced soon.
It currently has OEM shocks with a leveling spacer about 1.5
The rear has an OLd Man Emu 1.5 lift Coil
What do you guys recommend for the front Shock/Coil replacement?
I read somewhere that the 99 4runner had a taller Coil spring?
Or should I just go with a new Bilstein 5100 and use the same coils and leveling spacer?
As of right now, the ride height is level and it rises fairly well. Its not on the soft side, still rides like a truck. My concern is it being too stiff if I swap the spring or add the 5100 that it will rattle the dashboard too much.
Any insight would be appreciated.
2000 2WD SR5 V-6
Hollywood1 is offline   Reply With QuoteReply With Quote
Old 12-23-2019, 03:08 PM #2
spartacus's Avatar
spartacus is just really nice spartacus is just really nice spartacus is just really nice spartacus is just really nice
spartacus's Avatar
courtesy of@phattyduck. "The front suspension uses (coil over) shocks, but they will often be (incorrectly) called struts.
For OEM-like ride, go OEM. They will last another 15-20 years.
For slightly more controlled ride, go with Bilstein 4600. Those seem to last ~10 years (they did for me, at least).
For a mild lift, Bilstein 5100's are popular (with new lift springs in the back)... From there, the choices get complicated.
If you are happy with your current ride height, just replace the shocks (and top bushings, but most shock sets come with those). New springs and other parts are only needed if you want to change the ride height."
Old 12-23-2019, 06:09 PM #3
negusm negusm is offline
negusm is on a distinguished road
I just redid my front struts with OEM Toyota and my rears OEM. Ride is amazing. Exactly like I remember driving the car off the lot new. Worth every penny.
They lasted 17 years and 250k miles. Weren't even leaking but the bushings were shot in the bottom. Has to be the cheapest shocks/struts per mile.
I did not change the springs. Those are still original and still good.
I did change the top supports on the fronts and I changed all ball joints.
2002 4Runner 4WD SR5 - Original Owner
negusm is offline   Reply With QuoteReply With Quote
coil , front , im , leveling , valve
Front Shock/Coil Question Jhiggs33 3rd gen T4Rs 1 08-04-2017 08:59 AM
want to add a 1' leveling kit along with 3 inch coil over in the front ryanberls 4th Gen T4Rs 9 04-28-2016 07:48 AM
front shock and coil assembly newmexrunner For Sale: Suspension/Wheels/Tires 3 10-25-2012 10:49 AM
front shock and coil assembly newmexrunner Engines / Suspension / Wheels / Tires / Audio / Accessories 1 07-22-2012 09:31 PM
KYB Front coil over recommendations? Blueman2 3rd gen T4Rs 0 09-21-2010 10:39 AM
