Originally Posted by 4Tuitous
I've been looking for OEM's myself...seem to usually run between $65 - $85 each in decent used condition...
Check out
partsgeek.com. $87/ea brand new.
You will also need to check your directional stalk to see if the fog switch is present, and likely will need to add the fog relay in the fuse panel under the hood.
Also, the 96-98 have different OE fogs than the 99-02 models.
