Old 12-26-2019, 07:57 PM #1
RBuilt714 RBuilt714 is offline
Real Name: Ta
RBuilt714 is on a distinguished road
Real Name: Ta
My 1999 Toyota 3rd gen 4Runner Limited 4WD
Hello guys. I recently sold my 1998 Tacoma Xtra cab 4WD and purchased this 3rd gen 4Runner Limited 4WD and I am new to this forum.
To do list:
-Use JDM engine x
-Replace steering wheel x
-Replace front seat cover x
-New radiator x
-New tires x
-New rims x
-New heater core x
-New front window x
-New coilovers x
-Reverse camera
My 1999 Toyota 3rd gen 4Runner Limited 4WD-969af245-2be2-43bd-8bf3-61603cfad0c7-jpg
RBuilt714 is offline   Reply With QuoteReply With Quote
Old 12-26-2019, 08:18 PM #2
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
Originally Posted by RBuilt714 View Post
Hello guys. I recently sold my 1998 Tacoma 4WD and purchased this 3rd gen 4Runner Limited 4WD and I am new to this forum.
Welcome to T4R.org, a fantastic forum as you might already know.
Curious, what was the motivation for the switch? I'd likely be in a Tacoma if I didn't have two little ones...
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 12-26-2019, 09:09 PM #3
Real Name: Ta
Real Name: Ta
I switched because the 4Runner is more useful for me. I need the space for my two niece and brother dog in the back when we go hiking or camping.
Old 12-28-2019, 02:05 AM #4
BostonJon BostonJon is offline
BostonJon will become famous soon enough
Good luck with the new rig.
Replacing the heater core is - by far - the most PITA job I’ve done on the 4Runner. Total dash removal required.
BostonJon is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 07:04 PM #5
Real Name: Ta
Real Name: Ta
New suspension for the 4Runner 😀
My 1999 Toyota 3rd gen 4Runner Limited 4WD-4ab18205-f400-40d2-bfd5-2a78eb2c5af2-jpg
Old 01-09-2020, 08:04 PM #6
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
While you're in there, get the Lower ball joints knocked out too. Between those (and their bolts) and the radiator, you're addressing the biggest issues that can stop you in your tracks.
And from personal experience, doing all the control arm bushings makes a MASSIVE difference in ride quality.
Good luck with your new ride.
Brian. is offline   Reply With QuoteReply With Quote
Old 01-10-2020, 01:21 PM #7
mesooohoppy mesooohoppy is offline
mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about mesooohoppy has a spectacular aura about
i agree, that is why i did everything at once. dont forget to check out the tie rods!
99 4runner limited; imperial jade mica
IG: mesooohoppy
mesooohoppy is offline   Reply With QuoteReply With Quote
Old 03-12-2024, 02:57 AM #8
Real Name: Ta
Real Name: Ta
Smile
I been MIA! Fast forward 4 years later! I replaced the heater core and yes it was a PITA but a good learning experience.
Old 03-12-2024, 03:01 AM #9
Real Name: Ta
Real Name: Ta
Hey Brian, thank you for the help. I did get my LBJ and radiator replaced.
Old 03-13-2024, 09:13 PM #10
Kokomodo Kokomodo is offline
Kokomodo is on a distinguished road
1999 4Runner "Must Do" List
It's now 2024, and I also just purchased a '99 4Runner Limited. I had the timing belt/water pump replaced as there was no history on it. The front wheel bearings were bad, and according to the mechanic, seized into the knuckles. He replaced the entire spindle assembly. The rear differential carrier bearings are going, and so that will be rebuilt. The heater blend door Bowden cable is seizing...still working on what to do about that. I also had the radiator replaced. Shocks and bushings will be replaced when the rear differential is rebuilt. It has 248k miles on it. What else should I be worried about?
Kokomodo is offline   Reply With QuoteReply With Quote
Old 03-14-2024, 02:37 PM #11
ninethings ninethings is offline
Real Name: Tim
ninethings will become famous soon enough
Real Name: Tim
Lower ball joints if they weren’t replaced during the spindle assembly install.
Those go and could destroy all of the work you’ve already done. Easy swap, shouldn’t take more than an hour.
<a href=https://blogger.googleusercontent.com/img/b/R29vZ2xl/AVvXsEhRUBHdN4dX3N-MZqnf4MmbxaF1QVQ8kLoGcbvEX3SNwSyV_geqoX9F5LACC8BWf7UQIBzi5AC5qHBgksRfky-s3P1k9Pp-70LTMpPzK__f2bK2f30sbQq_zRuN3Cqwx93feDQ9Ndb2dQav6nodFdYVRSNBnDFeeSfFIiVfUq0VyQ3yYr93Gg0IjfTdAO0/s320/IMG_4239.jpeg target=_blank>https://blogger.googleusercontent.co.../IMG_4239.jpeg</a>
ninethings is offline   Reply With QuoteReply With Quote
3rd , 4runner , 4wd , gen , limited
1999 Toyota 4runner Limited - TN EPatt For Sale: Vehicles 13 01-28-2016 04:09 PM
