12-26-2019, 10:26 PM
Heater control valve
Has anyone had any luck with any aftermarket heater control valves? I bought one off of Amazon (four seasons) and it was leaking within a month. I returned it and figured maybe I got a lemon. Replacement lasted about 5 months before I noticed it started leaking.
If the damn OEM part wasn't a hundred bucks (yikes) I would have just went that route.
Or does someone have a lead on a good deal on the OEM part?
Sent from my SM-N975U using Tapatalk
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
12-26-2019, 11:11 PM
87240-35070
$72 from McGeorge
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
12-26-2019, 11:37 PM
Real Name: Andy ಠ_ಠ
Real Name: Andy ಠ_ಠ
I have used these guys tons... shipping can be expensive on large items but usually small stuff is pretty good.
not sure what year you have because I think there are some differences. this would be for my 97
8724035050 - PartSouq - Auto Parts Around the World
48+11 shipping like $60.87
the funny thing is if these guys have the part, it's usually cheaper and they can ship it from the UAE faster than I can get stuff from Chicago to Minneapolis.
12-27-2019, 12:26 AM
Location: Stationed in Camp LeJeune, home is Conover, NC
Advance auto for the last 4 years. No problems.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
12-27-2019, 08:51 AM
I went with OEM heater valve and done once and call it good!
Yep.. partsouq.com is the way to go. I got 3 shipments and all came to my door just in 4 days after placing the order.
For $11 shipping, add some other small items you think will be needed in the future: drive belts, light bulbs, valve cover gaskets, spark plug tube seals.. PCV valve, vacuum hoses
12-27-2019, 09:13 AM
I have to ask Mike if you have replaced those heater hoses? I remember some forum member who despite using an OEM valve still had leaks over time. Turned out to be the hose as the culprit.
But aftermarket parts are a crapshoot. The other day I was in Advance to get a Moog outer and inner tie rod plus the adjusting sleeve for a Chevy truck. Despite being made in the US, to get those three parts to mate correctly it took me and the counter dude ten minutes and opening fourteen boxes before finally achieving success.
Originally Posted by nissanh
I went with OEM heater valve and done once and call it good! ...
+1 !
On my Runner very few (fingers crossed) components have failed in 320K miles, look at my sig.
The heater valve was leaking slightly (just crud on outside) at 290, so I replaced it with OEM. I don't expect to see that part fail again.
Luck and enjoy the Runner.
12-27-2019, 09:29 AM
All of the heater hoses by the firewall have all been replaced. I installed new ones when I was swapping engines. I had to replace one of those hoses on my original engine and it was an absolute nightmare to get them on/off which is why I just put all new ones on the donor engine.
It's definitely leaking from the valve, specifically, from where the valve pivots . That is where the first aftermarket one leaked also.
I'm going to check out this partsoq thing, $60 is a little easier to swallow.
2011 Camry SE V6
12-27-2019, 09:43 AM
Just ordered it from partsouq, just under $61. I'm done screwing around with aftermarket junk valves.
I usually only buy OEM stuff but I figured for this, an aftermarket one would be fine. NOPE!
Thanks fellas
2011 Camry SE V6
12-27-2019, 11:49 AM
Or does someone have a lead on a good deal on KrogerFeedback the OEM part?
I have also the same question. Can someone please resolve the issue?
Reason: Spelling
12-28-2019, 01:12 AM
Real Name: Keith
Real Name: Keith
The valve for my '97 is $33.67 plus shipping at Amayama. I ordered 5 similarly small items and the total shipping is $20.88.
12-28-2019, 01:28 AM
Real Name: Samuel
Real Name: Samuel
I have 2 years on my four seasons one with no leaks yet. Hit or miss parts. The advanced auto one is a reboxed four seasons FYI
2001 Sport Edition 4WD, IJM, Auto, DD
1999 SR5 4WD, Millennium Silver Metallic, 5 speed, E-locker, Trail Rig
1998 SR5 4WD Custom bodywork from hitting a median. Beater truck.
1999 Limited 4WD No longer a vehicle. Now it's in parts and stored away.
12-28-2019, 08:07 AM
I’m happy with my napa valve.
12-28-2019, 02:10 PM
Bought one from Oreilly's and its been installed for 3-4 years now with no problems.
I really wonder if people are using hammers to install.
