Old 12-27-2019, 01:19 AM #1
MarkBlack's Avatar
MarkBlack MarkBlack is offline
Real Name: 1997 4RUNNER
MarkBlack is on a distinguished road
MarkBlack's Avatar
Water Leaking in
Im having water coming in from the plastic underneath the windshield on the driver side. It leaks down and onto my driver side floor mat. Before I start ripping everything apart, I was curious If anyone has had this issue before. I plan on tackling it tomorrow on my day off. Ill post some pics.
MarkBlack is offline   Reply With QuoteReply With Quote
Old 12-27-2019, 02:11 AM #2
RAD4Runner's Avatar
RAD4Runner RAD4Runner is offline
RAD4Runner has a spectacular aura about RAD4Runner has a spectacular aura about
RAD4Runner's Avatar
Many of us first-gen owners have leaks because of rusted metal around the windshield. The trim around the windshield is purely cosmetic and catches and traps dirt and moisture and keeps it moist in there, promoting rust. Yours should be no different.
If you want quick but robust fix, Clean rusted area, paint, then patch leak with Sika urethane, the stuff they use to attach the windshield.
If you want a clean and robust solution, be prepared to have glass removed, do some rust repair, repaint and have glass re-installed. This is what I did on mine, and I did not have trim re-installed for above reason, like one thing that Jeep did better than Toyota.
86 4Runner, 22R-Eliable, 5-Speed Manual, dlx. WHAT'S YOURS?
If you want us to help from afar please let us see, hear, feel what you're dealing with.
A picture paints a thousand words.
Toyota components are bullet-proof. Issues often arise from poor wiring, assembly and/or maintenance. Suspect those first.
Next only to our senses, the multi-meter is the most important electrical diagnostic tool. Spend $6 at Harbor Freight or $$$ blindly replacing parts.
RAD4Runner is offline   Reply With QuoteReply With Quote
Old 12-27-2019, 08:45 AM #3
nissanh nissanh is offline
Check the wire-harness rubber grommet on the fire wall next to the brake booster. If someone ran wires through it, they might have pierced/cut open it and that is where it can leak. I found my 97 4R and an 03 tacoma with the same issue: Affix a rubber flap above it to the fire wall to divert the water over it... problem solved!
Old 12-27-2019, 09:15 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I have a leak in the drivers side on my one 4R. I am going to investigate that rubber grommet. I think my lip on the driver side windshield is gone hence my one leaks. But I will very this grommet. Thanks for the tip.
driver , issue , side , underneath , water
water leaking in jpeak 5th gen T4Rs 3 01-02-2019 07:30 PM
Why am I leaking water? Jumpkix 3rd gen T4Rs 12 03-25-2016 10:53 PM
water leaking jasmine366 Classic T4Rs 5 06-09-2011 06:01 PM
Water leaking manp0899 Problems & Warranty Issues 1 02-16-2010 12:27 AM
Water leaking from AC? Avet14 4th Gen T4Rs 4 06-23-2008 10:38 PM
