Old 12-27-2019, 04:27 PM #1
TrexRunnerGirl's Avatar
TrexRunnerGirl TrexRunnerGirl is offline
Real Name: Teri
TrexRunnerGirl is on a distinguished road
Real Name: Teri
Leaking coolant from....?
Now I know why I’m down a bunch of coolant but what is this and what’s the fix please?
It’s on passenger side between front n back door area.
I can’t get the photo to flip the right way. Sorry it’s upside down. I tried to flip it then reload it too, no dice.
Leaking coolant from....?-b2bb479b-44d5-4859-99fd-88fffb513796-jpeg
99 Limited Silver/Tan 145K, Love this old thing.
16 Sonata Sport, Red with Grey interior.
TrexRunnerGirl is offline   Reply With QuoteReply With Quote
Old 12-27-2019, 04:34 PM #2
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Those are the rear seat heater lines.
You can connect the to-from rear heater lines together up in the engine bay near the firewall, until the lines can be fixed properly. After doing so you'll need to top up the coolant in the reservoir, and possibly the radiator, depending on how much coolant has been lost.
Don't drive while low on coolant, or the engine will overheat, then you'll have real problems.
02SE is offline   Reply With QuoteReply With Quote
Old 12-27-2019, 04:50 PM #3
Real Name: Teri
Real Name: Teri
Rear seat heater? You mean where the heat blows under the seat from the switch in the center console right.
Good to know.
Yes she will be sitting until I can fix it.
Old 12-27-2019, 06:48 PM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Good to know.
Those are indeed the coolant lines for the rear heat. You can search on here but the 01-02 rear heater lines are stainless steel and survive better if you're trying to replace them. Otherwise, like others have said you can loop the lines back to each other and your vehicle will be drive able until you decide to repair it. If you decide to bypass the rear heater make sure to top the coolant off after.
coolant , door , flip , it’s , leaking
06 SR5 V6 Leaking Coolant peroxide 4th Gen T4Rs 10 07-01-2015 11:59 PM
Coolant Leaking ruijay Problems & Warranty Issues 2 10-29-2014 08:58 AM
BIG Coolant Leaking [HELP] mistersnowman97 Classic T4Rs 5 02-27-2013 02:49 PM
Leaking Coolant JRR Classic T4Rs 6 08-16-2012 10:02 AM
Leaking Coolant? simple 4th Gen T4Rs 6 02-06-2011 11:55 PM
