Old 12-28-2019, 04:59 PM #1
mkzg mkzg is offline
mkzg is on a distinguished road
Cast iron vs tube manifolds - any benefit?
In the process of my engine replacement. The donor is an 04 engine from a Tacoma, still complete with all accessories and exhaust and crossover pipe
My 97 4runner has the cast manifolds, the 04 engine has the factory tube ones. The cat connection is differnt, the 97 has the two tubes and the 04 one has the single round connection
Are there any flow benefits of the later ones on the taco engine? Versus me swapping the factory manifolds?
I have a supercharger as well if that makes a different
mkzg is offline   Reply With QuoteReply With Quote
Old 12-28-2019, 05:20 PM #2
APhelps APhelps is offline
APhelps has a spectacular aura about APhelps has a spectacular aura about
Typically a cast manifold is going to hold up better to heat cycling than a tubular one.
Not sure you're going to pull any power out of the vehicle by swapping manifolds though.
APhelps is offline   Reply With QuoteReply With Quote
Old 12-28-2019, 06:58 PM #3
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
4 cylinder or 6? The Tubular manifold was definitely an upgrade for the 2.7 A few more horsepower than the cast iron one and no cracking in the middle cylinders
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
Old 12-28-2019, 07:30 PM #4
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
I've never seen or heard anybody talking about the V6 manifolds, it actually wasn't until recently I found out they updated them. Since the cast manifolds don't crack on the V6s like the 4 cylinders tended to, I'd guess that any gains from swapping them out wouldn't really be worth the headache.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 12-28-2019, 07:39 PM #5
its a 6cyl. seeming like it would be pointless to keep the tube ones and have to make a new downpipe attachment flange. gonna just get the gaskets and swap manifolds over then
cast , connection , engine , factory , manifolds
Which 4Runner engines have cast iron block ones to avoid. blueuniform Engines / Suspension / Wheels / Tires / Audio / Accessories 2 08-06-2017 02:03 PM
Thought I'd Cast This Your Way Khjphoto General Discussions 0 04-07-2016 07:12 AM
Cast Iron Exhaust Manifold on a 2000 4Runner? Yoter 3rd gen T4Rs 5 02-16-2016 12:57 AM
Was that post related to welding a cast iron part removed? jow 4th Gen T4Rs 0 11-20-2011 04:06 PM
Any 4th Gen die cast models out yet? Dansnare 4th Gen T4Rs 3 09-09-2006 09:26 AM
