Old 12-30-2019, 02:14 PM #1
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
A340F Test Port location?
Hi,
Does the A340F have a test port?
I've been reading about using the test port as location of the A/T oil temp probe being used by some FJC owners.
Thanks.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 07-09-2020, 05:23 AM #2
Tyler992 Tyler992 is offline
Tyler992 is on a distinguished road
I've been looking all over the web. I also don't know and can't seem to find out if my a340f transmission has a test port?
Tyler992 is offline   Reply With QuoteReply With Quote
Old 07-09-2020, 11:13 AM #3
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
http://japan-parts.eu/US/3/352792A.png
Part # 35104A is what I found to be test port's. FSM shows gauge connected to lower front plug.
Same plug right rear, no mention of use, assuming it another test port.
Test procedure in FSM using front port, corresponding pressures.
The plugs have a J-spec taper, have yet to find J-spec specs for banjo fitting.
SST kit $600 - $1100.00
Old 07-09-2020, 09:12 PM #4
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
wile I use my torque ap for temps. I know there has to be an easier way as some people mount a permanent gauge, maybe they mount something in the lines to the cooler
related to that, the tundra and sequoia have a thermostat and hoses that route the tranny fluid to the cooler only when temps require....wonder if we can use those in a 4runner
Old 07-09-2020, 09:36 PM #5
good find on this!
I guess, a banjo test port can be fabricated to fit the thread
Old 07-09-2020, 11:10 PM #6
Real Name: Mark
Real Name: Mark
@3bears , The test guage is rated 300 psi, line pressure. Your referring to cooler lines, that's pump pressure is my understanding, different than line psi in that part of trans.
@HiluxSurf SSR-G , Toyota's SST kit has straight and bango fittings.
I haven't been chasing this hard, OTC might have something, a fluid gauge 300 psi not cheap, hose fittings.
You really gotta know, find a shop that won't jack you around have them do it for a Benjamin or 2 or 3.
Old 07-10-2020, 11:08 AM #7
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
If you are using the pump pressure test port then that will not be an accurate transmission temp. Fluid goes from the pan through the filter then to the pump. After exiting the pump it still has to go through every other part of the transmission before exiting to the cooler so temp at the pump will be much lower than the temp of the trans fluid heading to the cooler.
a/t , a340f , location , port , test
OBDII port location on 97' 4runner wingoda 3rd gen T4Rs 9 02-19-2020 11:20 AM
99 Surf OBDII Port Location? antexity 3rd gen T4Rs 6 08-27-2016 01:58 PM
Torture Test: ARB Air Locker Static Torque Failure Test TotalAutomotiveLV General Discussions 4 06-08-2016 11:57 AM
2001 A340F vs 2000 A340F clenceo 3rd gen T4Rs 0 12-26-2013 07:30 PM
Possible power port location? Narkhelek 5th gen T4Rs 2 06-28-2012 09:17 PM
