Old 12-31-2019, 06:40 PM #1
HappyHooligan's Avatar
HappyHooligan HappyHooligan is offline
HappyHooligan is on a distinguished road
Amp Wiring Kit Recommendations?
Hey everyone. I just purchased a JBL BassPro SL for under my drivers seat location and I need a wiring kit for it. What do you all recommend? I'm not looking for the cheapest nor the most expensive. Just the best.
_________________
2000 Sport
880/5100 906/5100
HappyHooligan is offline   Reply With QuoteReply With Quote
Old 12-31-2019, 06:53 PM #2
TreyG73 TreyG73 is offline
Real Name: Trey Smith
TreyG73 is on a distinguished road
install kit
Just ordered this one with my amp from Down4SoundShop.Com after checking out other options.
CERTIFIED BASSHEAD 4AWG 100% SILVER TINNED OFC AMP INSTALL KIT - Down4Sound Shop
2007 V6 Limited - Cornfed 3/2 lift, Bilstein 5100s, Sixity 1.25" wheel spacers, 255/75/r17 Yokohama Geolandar A/T, Kenwood Excelon DDX396, Excelon front and rear door speakers, Skar Audio SK-M9005D, JL Audio 10TW1-4 subs, LUMEN Black Factory Style Projector Headlights, Hikari LED headlight and foglight bulbs, more to come in 2020...
TreyG73 is offline   Reply With QuoteReply With Quote
Old 12-31-2019, 07:12 PM #3
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone has a spectacular aura about theesotericone has a spectacular aura about theesotericone has a spectacular aura about
4 gauge is way overkill for that amp. It's a 125RMS class D. So it will draw 12 amps at full draw. You could get away with 12 gauge wire for that run but most kits you will find will be 10 or 8 gauge. Literally any well rated kit off of Big A will run that just fine. I've used Boss in the past and have had no complaints.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
Old 12-31-2019, 08:03 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light
brillo_76's Avatar
Real Name: Jon
Best to have wire with heavier insulation and stranded wire is always better then solid becaude it's more flexible. The surface area between a stranded or solid is close as current travels on the outside of the wire .
4 awg handles 70 amps
6 awg handles 55 amps
8 awg handles 40 amps
10 awg handles 30 amps
12 awg handles 20 amps
14 awg handles 15 amps
As the other member stated. 12 gauge is great choice if the max current for this circuit is 15 amp. 12 gauge gives you some wiggle room and if your circuit fuse is 15 amp just dont put a 25 or 30 amp fuse in that circuit as you be heating the wire up. Keep the fuses really close the the max current draw.
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
Old 12-31-2019, 10:35 PM #5
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Complete 8 Gauge Amplifier Installation Kit - Merchandise
That'll be overkill, but a complete kit with quality products and affordable. You could certainly get away with the "KCA" kit for less money if you wanted, the main downside would be that the aluminum wire will not be as resistant to corrosion over time. If you're planning on this being permanent spring for the copper wire.
Being that you're planning on putting it under the driver's seat any kit will have RCAs that are too long and come with a lot of extra power wire. If you don't want to spool up RCAs either order a separate shorter set or piece together the things you'll need yourself.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 12-31-2019, 10:52 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Try to stay with copper as it's the 2nd best conductor we have. Aluminum is the 4th best conductor.
Copper can be soldered for better connections. Aluminum can not.
The only reason we are seeing aluminum wire more now is because of cost. Aluminum is a lot cheaper then copper.
As aluminum makes up 8.1% of the crust surface of our planet. While copper is
00068%
Our best conductor is Silver but no way would we see that available in wire form.
And Gold is the 3rd best conductor.
Also in time connection joints of dissimilar metals will react. However, aluminum to copper isnt too bad.
Old 01-02-2020, 11:18 AM #7
thanks for the help everyone. I just bought the Boss 8 gauge as it probably overkills what I need. Hopefully it's easy to figure out now to wire this up.
_________________
2000 Sport
880/5100 906/5100
Old 01-02-2020, 11:35 AM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
As long as you are happy with 8 gauge is all that matters. Just take your time and follow the instructions for hookup.
amp , cheapest , kit , recommend , wiring
Wiring air on board switch to Amazon wiring harness. Btmannin Engines / Suspension / Wheels / Tires / Audio / Accessories 3 06-18-2018 03:33 PM
PuddleLight Wiring Recommendations? whitetiger 5th gen T4Rs 1 09-30-2017 02:20 AM
HID kit recommendations Ashtonguyton 4th Gen T4Rs 15 12-11-2013 11:56 AM
ATF recommendations? Recoil Rob 3rd gen T4Rs 3 12-13-2012 08:50 PM
Any recommendations... today 3rd gen T4Rs 11 01-27-2009 07:50 AM
