Hello,
I'm sure this has probably been covered before, but search as I may I could not find it. Everything I could find had to do with headlight replacement itself vs. the bracket.
There is this black plastic bracket broken on the driver side of my 1997 that is leaving the filler panel, headlight, and grill all loose. It seems as if they all connect at the same point.
In the first two pictures you can see the passenger side bracket intact. In the last picture you see the drivers side broken and missing.
Anyone know a part number for what all needs to be replaced here, and where to get it?
Thanks for the help!
View post on imgur.com
