Originally Posted by chen5108
Looking real good, I'm in the process of bringing a Sunfire Red back to life also. I really need to get new front seats, can you shine some light on how the fitment of the Subaru seats went?
chen5108
Thanks. I actually sold this rig a couple months ago and got a Bronco. I immediately put some new seats in that Bronco though so I feel a little more experienced with the seat swaps now.
So unless the seats are direct bolt in (There are a couple threads on here about that), you are looking at a pretty big job, but it is definitely worth while. For my old 3rd gen the subaru seats hit 2 of the stock bolts, and I used large sheet metal screws for the other two brackets. I also ground down a couple of the brackets as they were too big to fit flat. The most important part of retro-fitting in different seats is to make sure they are perfectly straight. My driver's seat was at a very slight angle (not noticeable at first, but after long drives I did start to notice it and it bothered me). One of the seats I put in was electric, and they had seat heaters, but wiring was extremely simple on this. If you can wire in a new stereo, you can easily hook up electric seats.
This may be trickier to apply to the 4runner, but on my Bronco I drilled through the floor board and bolted in my new seats for all of the brackets that didn't line up. Obviously there is alot more room under a Bronco and things are less condensed, but this was much easier than trying to re-work brackets to fit the stock mounting bolts. Do keep in mind that you want these seats as secure as possible for safety, and bolting or even possibly welding is definitely a better option than using sheet metal screws. Hope this helps, and best of luck to you.
Reno-3rd Gen - 96 SR5 4x4 w/ 5-speed on 35's -
BUILD THREAD
