01-01-2020, 04:02 PM
Sudden Fuel Tank issue, can't refill without trouble
I believe this problem started last night and it's become significantly worse today. I just can't fill the tank anymore. I noticed this while doing a lot of driving for a new years trip.
No matter what I do, when I start to put gas in it instantly triggers the auto stop on the pump. Even at a half tank, I just fact keep gently starting it again and manually watching the gauge. Of course I don't want to overfill it, so I'm not really going any higher than 3/4 of a tank. But this drastically cuts the range down.
I'm thinking now that maybe she's never actually filled up all the way since I've had her. I've noticed that the fuel economy seems to vary wildly, but now I'm curious that maybe it's due to the tank not filling up every time.
- No codes.
- 2000 SR5 4x4 auto
Any ideas? I did some searching, but a lot of the threads are pretty old and most of them didn't even have a solution.
01-01-2020, 04:59 PM
The fuel tank is not venting. Could be the tank vent, vent valve, evap canister....
Any codes? Probably need to drop the tank and check valves and hoses.
01-01-2020, 05:08 PM
Mebbe bad rollover valve w/gasket on top of gas tank?
Someone did a thread about R/R but he had a PO440 + PO446 code too-
01-01-2020, 05:21 PM
Shit, well that sounds like a job for my mechanic then. Damn.
Is any of that cheap enough to go ahead and order before hand?
Any idea what the part numbers for those 3 items are?
Also, no codes but I'll try to pull again later.
No codes yet, I'll try to pull again but so far the only symptom is the filling problem.
Is that value cheap enough to go ahead and swap if they do drop the tank?
If they have to drop it, I feel like I might as well swap anything cheap while we are there... Haha.
01-01-2020, 05:56 PM
Can't really say what you need part wise without a proper diagnosis but shouldn't be too expensive. The vent valve is probably around $50. That's a guess!
01-01-2020, 06:07 PM
Shoot, yeah that's not much for the peace of mind even if that part isn't broken yet.
01-01-2020, 06:11 PM
77380-26010 - Genuine Toyota VALVE ASSY, FUEL CUT OFF
Toyota Part No.: 77380-26010
Your Price: $11.90
My Backyard Frame Swap
01-01-2020, 07:49 PM
Originally Posted by TheDurk
Wow, okay yeah that's a trivial price. Definitely going to have it swapped out if we're going to mess with anything.
01-01-2020, 09:46 PM
They started venting the tank through the EVAP system in 99 I think. (onboard vapor recovery) Could be the check valve in the top of the tank, but it might be the canister itself or the vent control solenoid valve. On some cars (Hyundai come to mind) the canister breaks down and fills the system with charcoal pellets causing the symptoms you describe.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
01-01-2020, 10:06 PM
If you drop the tank change the fuel pump and the filter screen around it while you are in there.
01-01-2020, 10:46 PM
Usually when unable to fill the tank, it is either the solenoid (a scan tool with the right EVAP sub setting can tell you if it is venting or not) and most of the time some EVAP code is thrown for a leak, or the charcoal canister is plugged(no code). My gut would say it is the latter even though I have never touched the EVAP system on this 4Runner except to change out vacuum hoses.
In my experience, when vent valves fail, you will get real strong heavy fumes throw back at you or gas is even spit back at you. Doesn’t sound like the case here.
Try filling next time with the gas pump nozzle halfway out the filler tube and see if you can fill up with less resistance.
01-03-2020, 06:54 PM
Interesting.
I've not noticed any fumes but I'll check for them when I fill up tonight. Also, checked for codes again and still don't see anything.
Lastly, do you have the part number for the charcoal canister?
I've basically decided that if we're going to have to drop the tank I might as well swap out anything that can go bad. Unless it's ultra expensive
01-03-2020, 06:56 PM
I've experienced something like this before on a different truck, but if I rotate the nozzle a little, it helps a lot.
Not ideal, but might be worth a try.
01-03-2020, 09:20 PM
The number is 77740-35392 though you could probably find one in a junkyard for much less.
01-04-2020, 02:39 AM
Real Name: Daniel
Real Name: Daniel
Yup, my old Wagoneer had this issue that I never bothered to resolve before I finally got rid of it. My solution was to simply fill with the nozzle upside down. It tricks the pump into not shutting off at all. The downside is you have to actually pay attention to how much you're pumping or you risk overflowing.
I'm sure there was a break in the early 80s evap system somewhere down the line that was really causing the issue, but what the hell. The thing wasn't very environmentally friendly or fuel efficient when it was new from the factory anyways. Also wasn't exactly known for its reliability.
