Originally Posted by LittleCaesar
Personally I would. Usually they can be had for $30 or less in Virginia and South Carolina. As long as the seal is good, you should be fine. You could also snap up the EVAP solenoid as well for cheap.
It isn’t as if the filling up problem is killing ya somewhere in the short run, just more of a PITA.
Well I don't like not feeling up perfectly each time. Removed the ability to calculate fuel economy and also makes the trip counter unreliable for "range" since i may not always feel it to the same level.
I went ahead and just ordered pretty much all of the components for the tank. After my mechanic said we'd need to drop it (after he inspected things for a while) I just said screw it, might as well refresh it.
Ordered a oem fuel pump and the newer fuel sender since mine is the older crappy one. Gaskets and all that jazz. The added peace of mind will be good.
I'll follow up one it's all in.
