Old 01-01-2020, 04:07 PM #1
jayk2k3 jayk2k3 is offline
jayk2k3 is an unknown quantity at this point
question about the evap vent solenoid
1. is the vent solenoid normal open when the car is off and no power?
2. when i supply power to the vent solenoid and apply vacuum pressure, it build ups pressure and slowly leaks down (bad solenoid)? I know in the picture i have the valcume hose hooked up backwards, i tested it the other way around (right way).
question about the evap vent solenoid-55558888-jpg
jayk2k3 is offline   Reply With QuoteReply With Quote
Old 01-02-2020, 10:39 PM #2
No evap experts here? Should that solenoid hold pressure?
Old 01-02-2020, 11:52 PM #3
spartacus's Avatar
spartacus's Avatar
I am no expert but what little I know of evap systems. The vent solonoid is always open and the purge solonoid is closed . The pcm opens and closes the vent and purge solonoids there is a procedure for testing the solonoid in the fsm. hope it helps
question about the evap vent solenoid-screenshot_2020-01-02-20-57-13-jpg
Old 01-02-2020, 11:58 PM #4
spartacus's Avatar
spartacus's Avatar
I can post the rest of the procedure if you need or you can down load the fsm here
2000 4Runner FSM - Printable - Google Drive
Old 01-03-2020, 10:26 AM #5
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Usually if the circuit in the solenoid is stuck or has failed, an EVAP code is triggered. Sometimes, but not for all makers, a high ohm reading can indicate that the solenoid is failed/on its way out. Sometimes just tapping on them can free them/wake them up.
My guess though is that somewhere in the EVAP system there may be a slight vacuum leak, but not large enough to trigger a code. Access to a smoke machine would help here.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 02-21-2023, 05:16 PM #6
[email protected] 2ettares@comcast.n is offline
2ettares@comcast.n is on a distinguished road
Yes, it's an old thread.
My evap soleniod under the hood isn't opening. I've put 12 volts across the ternimals and it reacts. There's 12 volt at the plug but it doesn't activate the solenoid.
Any reason(s)?
2ettares@comcast.n is offline   Reply With QuoteReply With Quote
Old 02-21-2023, 10:26 PM #7
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Any reason(s)?
Could be a ground issue or a high resistance in the wiring causing an amperage restriction. If you can try to use a test light on the power and ground side of the connector.
Old 02-24-2023, 03:59 PM #8
Where is this connector? And what pin or slot is it?
question about the evap vent solenoid-check-vsv-ccv-connetor-id-jpg
Old 02-24-2023, 05:13 PM #9
Real Name: Patrick
Real Name: Patrick
What is shown in your picture is the ECM which is located behind the glove box.
Old 03-05-2023, 08:06 PM #10
I couldn't get to the ECM easily so the blue and white wire at the plug is the B+. I hooked a jumper from the plug to purge valve terminal (B+). I jumped the ground terminal at the purge valve to the car's body. The purge valve activated. The yellow and green go to the ECM and internaly it connects to ground. Do I have a defective ECM?
question about the evap vent solenoid-check-vsv-ccv-jpg  question about the evap vent solenoid-purge-valve-circuit-jpg
bad , power , pressure , solenoid , vent
3.4 swap evap question Llowlife Classic T4Rs 1 12-22-2018 05:08 PM
Had my Evap replaced. Cools but air flow from vent is weak now. First 4Runner 4th Gen T4Rs 10 08-28-2018 04:59 PM
EVAP/Tank Vent Nightmare djaye. 3rd gen T4Rs 8 06-06-2018 03:34 PM
Shift solenoid question BettyBlue4runner Classic T4Rs 0 02-20-2011 02:15 PM
Evap. System Vent Control P446 Maritimer 3rd gen T4Rs 6 09-07-2010 07:09 AM
