01-17-2020, 10:31 AM
#31
What rear spring would be best for about 2-2.5" lift but a soft ride? It won't be off road very much so looking for best ride quality possible. Probably going to run either a 265-75-16 or 285-70-16.
01-24-2020, 05:23 PM
#32
I'm in the same boat, so far as I've read up on OME 906's would do it but a little harsh, OME 890s would be good unless you need full droop then they may fall out.
I'm also debating the fronts.
Bought the rig with mish mash of parts. 5100's up front and OME 895s with OME shocks in the rear. Rides like garbage.
01-24-2020, 08:31 PM
#33
I started to make a spread sheet with all the rear spring options and then decided I was going 890's and I'd change if I don't like it.
890 seems about the best choice for 2.5-3" lift when not carrying lots of weight. Amongst the other 2.5-3" options they seem less likely to fall out.
model/spring rate/wire diameter/free height D/P
OME 2890 190 .591 17.13/16.73
OME 2891 210 0.63 16.53/16.14
OME 2906 220 .669 15.35/14.96
I bought Tundra TRD coils for the front.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
01-26-2020, 12:00 PM
#34
Real Name: Leon
Real Name: Leon
One thing to note with the numbers above is that these springs won't give the same amount of lift. Using these numbers (which I haven't verified, but assume to be correct), here are the spring heights with 1000 lbs of load:
rate free H H @1000lb
890 190 17.13 11.87
891 210 16.53 11.77
906 220 15.35 10.80
Note that 890 and 891 have about 1" more lift than 906.
I have about a 2" lift with the 906's in my '97 (which is exactly what I wanted), so you'll get closer to 3" lift with the 890/891.
I'm quite happy with the ride with the 906's, I don't find them too stiff at all (and I like comfort, so take that for what it's worth).
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
01-26-2020, 01:32 PM
#35
That height at 1000# would be good data to have. Would be nice if all this type data was readily available.
01-26-2020, 03:31 PM
#36
Real Name: Leon
Real Name: Leon
Agreed. It's easy to calculate the expected ride height given the free height and spring rate, but it wouldn't account for progressive springs.
01-27-2020, 12:39 AM
#37
If your rig will not see offroad and will not have tons of weight in the rear then the best ride quality will be oem springs. So... a spacer lift will be your best bet. Daystar makes a 2.5" and a 1.5" spacer for the rear.
Amazon.com: Daystar, Toyota 4Runner 2.5" Rear Lift Kit, fits 1996 to 2002 2/4WD, all transmissions, all cabs KT09108BK, Made in America: Automotive
Amazon.com: Daystar, Toyota 4Runner 1.5" Rear Lift Kit, fits 1996 to 2002 2/4WD, all transmissions, all cabs KT09107BK, Made in America, Black: Automotive
IG: @4runnerfiend- 1999 SR5: ELocker Retrofit, Wheelers T1 Coils-tundra 5100's, Built Right UCA's, LC 8 wraps-Fox 2.0 with CD adjuster, Rokmen lower links, rear swaybar delete, Savage skids, Hot Metal Fab Front Tube bumper, Savage Rear tube bumper, TruckShopSD Sliders, F/R DuroBumps, 285 BFG KO2, Doug Thorley Headers, Magnaflow Overland Catback, yellow top, XRC 12k, ARB single compressor.
01-27-2020, 10:34 AM
#38
2.5-3.0" lift sounds about right when I had my 890s. I try to use center hub to fender measurements so that it's easier to establish a baseline for lift. With 890s I was consistently at 22.5-22.75" center hub to fender with a couple hundred pounds of cargo gear. With my Toytec superflex (the ones advertised for 3.75" lift) I sit 23-23.25" with the same amount of cargo weight. They handled similarly & was happy with both. I don't think the coil falling out should be an issue if a proper length shock is used.
For my next front set up I'm considering the Tundra TRD/Tundra bilsteins or Tundra 6112.
•Black 2002 SR5 4x4 3.4L V6
Suspension: Front: Toytec Boss coilovers/eibach 600#, SPC UCA, durobumps Rear: Bilstein/Superflex, SS adjustable panhard, durobumps Body Lift: 2" 4crawler Tires: 315/75/16 General Grabber AT2 Wheels: SCS F5 Matte black 16x8 3.5bs Armor: Custom bolt on rock sliders (no frame drilling)
•Black 2018 TRD Pro (wife’s)
Armor: Custom bolt on rock sliders (U-bolts)
01-27-2020, 12:06 PM
#39
Originally Posted by CT135
So with your bumper/swing out. Roughly how much lift are you getting from the super flex? Hub to fender would be awesome to know.
Here's a picture. This is with Superflex + trimmed OEM top cones. The rear bumper is a 4XI with a swing-out 34" tire and a full jerry can, so fairly heavy.
Hub-to-fender distance is 23.75". Even with the bumper setup, I imagine I'm still short of the 1000lb total load on each spring.
03-07-2020, 11:18 AM
#40
Real Name: Durwin
Real Name: Durwin
Originally Posted by rickashay
Good discussion. I might have to try the superflex's but I am worried I will be too heavy for them too...
I am just waiting for someone to try the Dobinsons 675V before I make a move.... any takers? lol
Addison,
I'm late to this discussion. I am very interested in this topic though. I currently am running 861's w/ Tokico LC shocks. I love the flex, but wish the ride height was a little lower. Also, they are too stiff.
For reference, I have a Bandit design rear bumper with dual swing outs (which is heavy) and 35" spare, rear storage / sleeping platform, fridge, Rago rear window panels (full) and usually my 70lb golden retriever. So I'm guessing 400+lbs. And the 861's are still too stiff.
Have you made a decision yet?
Is Dobinson the solution?
Thanks
Durwin
99 2.7l 5spd ARB locked F & R, 5.29's, dual cases, Shrockworks front bumper w/ Warn M8000s, King 25001-151EXT coilovers, OME 861/LC shocks, Stubb's sliders, Shrockworks full skids, custom built rear bumper, Kenda Klever RT 35x10.5r17 on FN FX pro 17x8's, TBU
03-07-2020, 03:07 PM
#41
Real Name: Addison
Real Name: Addison
Originally Posted by owyheerat
Addison,
Thanks
Durwin
No movement on my behalf yet. I have decided to keep my 7 wraps until my Eimkeith rear bumper is on and the F150 fuel tank swap has been completed. Once the weight stabilizes, I will start trying coils.
03-07-2020, 03:32 PM
#42
Official Vendor
Official Vendor
(same here)
keith
'96 SR5 - 3.4/5spd
check out the stuff I make
03-09-2020, 01:50 PM
#43
Real Name: Chris
Real Name: Chris
I ordered the Dobinson 675V last night.
Once I get them installed and get some drive time with them I will post here.
I was very close to buying the Toytec superflex but they aren't on the website right now (unless the part number changed?).
Fishwerks' Photo/Build Thread 2000 SR5 l White on White l 35s l Supercharged
2010 Trail Edition l Salsa Red Pearl l Stock
Instagram
03-09-2020, 06:13 PM
#44
Real Name: Matt
Real Name: Matt
Definitely keep us posted on how the 675v work for you. I've been in the market for new rear coils for the last year and have been weighing all options.
I currently have the Dobinsons 137v (50mm) for the 4runner/Surf. They are very progressive 170/240/320 ft/lbs and hold weight well, but aren't tall enough with the longer LC Shocks. If they were a 70mm free height coil they'd be perfect.
Also, I spoke to Toytec about the Superflex rear coils. They have been discontinued due to low interest. Toytec recommended the OME861, but they are too tall for my liking.
I have also considered the Dobinsons 210v 182/217 ft/lbs, and reason you chose the 675v over the 210v?
03-10-2020, 02:12 PM
#45
I have some OME 861's in my garage (brand new) that I was planning on throwing on when my rear bumper and swing out finishes. After reading about the Dobinson C59-210V LC springs I think i'm going to ditch the OME and go with the DObinsons. Seems like they hold weight well and give a little lower of a lift compared to the OME 861's and ride a bit better.
97 Limited, 5100’s, OME 883/891, Built Right UCA, Custom Sliders, coastal off-road front bumper, 4x innovations rear bumper(custom built swing out), 4.88 gears, 255/80r17 Wildpeak AT3W
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
