I know I may be one of the few, but I love my 861s in anything I wish they were stiffer/held more weight. But then again I do have a good amount of weight back there, full bumper w/swing out and tire, hilift, tools, recovery equipment, sub, amp, compressor, rollbar and basket... I find that sometimes I get a little wiggle back there and some harsher bounces, to combat that I have airbags inside the coils, and I should probably step up to a 2.5 shock in the back not just the 2.0.
https://uploads.tapatalk-cdn.com/202...38589dc1ba.jpg |
I received the same email last week. Sometime mid-May will be the soonest they will have the 210v back in stock.
For the time being I will try to get the 675v to work a little better with my setup. I've been driving on them for a week now and I do have to say that they are the most comfortable coil I've run on my 4runner. I've loaded my truck up ~200lbs of gear and with my 120lb plate bumper i am sitting .75in higher in the rear than the front. And so far the coil contact with the frame seems to be a non-issue with regards to noise and flex. I will be making 23mm and 13mm spacers to correct the driver's side lean and lift another half inch. Here's hoping that it somehow helps the frame rub. If the custom spacers work out i'll let everyone know. At this point I should probably start considering the OME861s |
Has anyone mentioned getting a 5th gen lift spring? I think a 1" lift spring for 5th gens would be equivalent to 3-3.5" of lift on our rigs and springs should be soft too right? I love the way my LC 7.5 wraps ride but they're almost 4" of lift and i don't like the rake. I'm trying to look for the softest 3"+ of lift because i have stock weight in the back.
So the Dobinsons 675v are for the FJ, 4th and 5th 4runners. They are a 3in, stock weight, high-flex coil. I am currently running them with a 120lb steel plate bumper and they netted me 4in of lift. With this in mind I'd think a 1in lift coil from a 5th gen would only net you a 2-2.5in lift. The other issue is that if you are running extended shocks a 1in lift coil might not have enough free height to stay in the truck at full flex.
I had this issue with the Dobinsons 137v (2in variable rate coil). Even with 10mm trim packers the coils would be loose to the point of falling out (with stock LC shocks). Also, while FJ, 4th and 5th gen coils technically 'work' I wouldn't recommend them to anyone. I bought my as a fun experiment but I will not be keeping them in the long run. The FJ/4th/5th gen coils are a larger diameter so you have to get creative to center them on your oem coil perches...I'm also having an issue where the coil is too wide, to the point that it hits the frame of the truck. |
I didn't want to run them if they weren't seated fully, so I put the 861s back on for now. I can post photos if people want, it was kind of hard to get a photo that showed it well though. But I'd agree that they aren't the right solution unfortunately. |
i did more investigating and found out that the 210's are similar to a 7.5 wrap that sonoran steel uses, just i think 30lbs different in weight holding, and also not variable spring weight.. the part number sonoran uses is (48131-6A570) and i assume if you use a stiffer shock it would help with carring the load, thus a safe an known shock is the black tokico. (48531-69417) the end total for this setup online is $367.30 after shipping fees.. the only issue is that if im not mistaken it does have driver lean and need a 1/2" spacer for just the driver side. i may just be pulling the trigger as i think im about to really add some weight in the next 2 weeks with a sleeping platform/drawer system.. **EDIT** 1994 LC Front right 48131-6A570 18.7 inches Front left 48131-6A480 19.5 inches 91 LC without alumn wheel Front right 48131-60230 20.5 inches Front left 48131-60810 21 inches 91 LC with alumn wheel Front right 48131-60260 20.9 inches Front left 48131-60820 21.1 inches dobinson 210V 475mm (one side) = 18.7inch 185mm (other side) = 19.1 inch with that being said, theres a .4 inch difference (3/8s difference).. i have a lil skips gas tank skid so i think with the 55 lbs it should bring it down to atleast a 1/4 inch difference.. i think im going to pull the trigger and proceed with the 1994 LC springs |
I have a 4X innovations bumper on the way and i'll be adding a rear swingout. I think the 861's will be overkill. Maybe the dobinsons 210V will provide the proper height with that extra weight, kind of a hybrid between the stock LC springs and the 861's.
Are the Dobinson 210v just an aftermarket version of the FZJ80 coils (48131-6A570 & 48131-6A480) & the benefit being they're a cheaper option?
That sucks Toytec discontinued the superflex coils. I like them a lot & would buy them again if something happened to the ones I have now. Hopefully they bring it back like they did the ultimate 5100 coilovers (which I recently bought & waiting delivery). |
-Dobinsons 210v are probably the most expensive rear coil, with a retail price of $230 +$40 in shipping (with tax you're pushing $290).
-Land cruiser coils can be found for $111 per side (McGeorge Toyota), often with free shipping if you get a promo code, total you're ~$237 -OME861 will be your least expensive (new) option. you can usually find them on Amazon for $187, shipped to your door in two days. The reason there is a lot of interest in the Dobinsons 210v is that it is a stock height, stock weight, progressive rate coil. The specs are DS -285mm / PS -275mm free height, with a 182-217# progressive rate. This means that this coil is going to have a ~1/2in lower free height than the OME 861, while also providing a softer initial coil rate with the truck is unloaded. When the truck does have a bit of load (rear bumper, swing out, camping gear, and spares) the coil will compress the 182# section and get into the 217# section. So the hope would be that you'd end up with a 4-4.5in lift unloaded and then settle out to 3-3.5in of lift fully loaded. Not to mention it 'should' ride better unloaded than the OME861s, while retaining the weight carrying capacity of the OME861 when fully loaded. This is all speculation though. |
Any pics of dobinson on the 4runner?
Well that is super weird...I checked McGeorge while writing my post and just re-checked this morning. McGeorge have the 570s list price as 168.89, but automatically discount it to $111.16, and even if you can't find free shipping, shipping is only $19.64 (obviously dependent on where you live). Maybe pricing is region dependent as well??
Search Engine Optimisation provided by
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
Advanced User Tagging (Lite) -
