06-09-2020, 07:10 AM
#91
Official Vendor
Official Vendor
Originally Posted by Amory
I got ready to pull the trigger on some 861s this week but found this thread. My brother and I each have 3rd gens that are very similar and both of us are looking for a 3-3.5" lift with bumpers, swingouts, sliders, and 80-100 lbs. or more of gear. I've also been preparing to move my rear shocks outside of my frame. After finding and reading over this thread, I remembered AssBurns's build thread where I saw he's running stock JL coils in the rear for about 2" of lift with a pretty beefy looking bumper and I'm not sure how much other weight, so maybe an aftermarket JL coil could be a viable option. I'm not sure how to tag him though, but maybe he could offer something else... I'm also very interested to hear how the Dobinsons fit and handle weight.
His JLs were too soft after he put the spare tire on the rear, IIRC.
@ AssBurns
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
06-09-2020, 10:11 AM
#92
OME2850 with all the above + f150 gas tank and a bit more gear
06-09-2020, 01:02 PM
#93
Real Name: Steven
Real Name: Steven
With just the bumper, tools/gear, and small ice chest, I was sitting around 1.5-2" of lift with the JL coils. Once I put the spare tire on, and moved the battery to the rear, it sat probably less than 1" of lift, so I put my 8 wraps back on, and now I'm sitting around 2.5-3" of lift. With the current setup, it has a good enough lift height, and soft enough to perform well.
06-09-2020, 06:05 PM
#94
Real Name: Tony (no surprise)
2000 Limited, E-locker
Maintenance/Build Thread
06-10-2020, 02:21 PM
#95
Real Name: Matthew
Real Name: Matthew
Originally Posted by the great him
I know I may be one of the few, but I love my 861s in anything I wish they were stiffer/held more weight. But then again I do have a good amount of weight back there, full bumper w/swing out and tire, hilift, tools, recovery equipment, sub, amp, compressor, rollbar and basket... I find that sometimes I get a little wiggle back there and some harsher bounces, to combat that I have airbags inside the coils, and I should probably step up to a 2.5 shock in the back not just the 2.0.
Also a big fan of my 861s.
I've got a drawer system in the back, 50 qt. fridge, lots of tools, spare parts, swing out bumper w/ 35" tire, recovery equipment, sub & amp, ARB dual compressor, and whatever camping gear we need. Plus more tools on top in a pelican case.
Most of my trips are also with my lady friend and our two dogs (~60 lbs each). Guessing loaded up, my weight is somewhere in the 5250-5500 lb range. It's a lot. FWIW, it isn't my daily and most of our trips involve setting up a base camp and wheeling from there. A good amount of the weight comes out with that but all tools, recovery gear, fridge, etc. remains in the 4Runner.
This picture does a pretty decent job of showing how low these things get when weighed down.
2002 Stellar Blue Pearl - Build Here
Instagram: mattyjako
06-13-2020, 11:26 PM
#96
In that case maybe I'll look into stock LC coils. I won't be carrying a significant amount of weight anytime in the near future and my bumper will be as light and close to the body as possible.
06-18-2020, 06:10 PM
#97
I hope I'm not ruining the initial discussion of the thread, but are the stock landcruiser coils progressive? I would really like a progressive coil in the back (I have no added weight) and in the 3-inch lift range.
I have the 890s which are great, but might need a little more lift in the back. Maybe I just took the wrong advice and should get a shock to fit my coils instead of the other way around. I'm running 4th gen 5100 with the 890s.
"Bettie" - 1998 4runner LTD E-Locker Evergreen Pearl 275K+, Alpine HU, Infinity Reference Speakers, Airraid MIT, B&M Cooler, Light Racing UCA, RCI skids, Bilstein Tundra 5100 and 4runner Eibach Coils in front/ Bilstein FJ 5100 and OME 890 rear, LC80 wheels wrapped with MT Baja ATZ 285/75/16, 99+ overhead console, 99+ center console, sound-deadening, Ditch lights
06-19-2020, 11:33 AM
#98
Real Name: Evan
Real Name: Evan
I had the same setup and was riding my extended bumpstops too often when wheeling so I got the Superflex coils. I was at the point that I wanted something that could handle at least a couple hundred pounds and still get 3” of lift so in my case the coil swap was and easy decision. I loved my 890’s for daily driving and wheeling but they just didn’t sit high enough for my usage with extended bumpstops and some extra weight when wheeling.
To answer your question, LC coils are linear and are not great at holding weight. The upside is that since they sit so high to begin with, once loaded down they will still sit at a decent height. Possibly too much lift unloaded if you like the 3” lift hight range of the 890’s.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
06-19-2020, 11:28 PM
#99
So I just got the 210v springs today. They're labeled left and right side. There's a little diagram on the box with a top down view of a right hand drive car facing forward. It's showing that left is the passenger side and right is driver. Since we don't have right hand drive cars here obviously would I swap the sides and put the one labeled right on my driver side?
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
06-20-2020, 01:55 AM
#100
No, keep the coil spring position as indicated on the diagram. most of the weights are on the left so the effect of the RHD position is minimal
06-20-2020, 02:33 AM
#101
LC80 Front coils:
48131-6A480 - FH 19.25" (White / Orange / Green)
48131-6A570 - FH 18.75" (Double Purple / Gray / White)
Originally Posted by Dieselchessy
I have used LC ~150k.
One is 8 wraps, white, dark blue, double purple. Free standing it’s 483mm.
Other is just over 7.5 wraps, white, light blue, double purple. Free standing it’s 473mm.
06-20-2020, 08:37 AM
#102
So I finally replaced my rear coils that they previous owner setup. I replaced the OME 891 coils with 2" lift spacers with the ToyTec "SuperLift" coils they sell today. Not sure if they are the same as the original superlifts but they are a HUGE ride improvement.
After Kings and now the coils I really hope to be done messing with the suspension for a while. But damn it rides nice now.
06-20-2020, 09:08 PM
#103
Real Name: 3 Bears
Real Name: 3 Bears
nice...what springs/shocks you running in the front ?
06-21-2020, 02:58 AM
#104
honestly 890 are the worst spring I ever ran. LC 7.5 wrap alot better but be better if it hold weight.
(DD)-97 4runner limited Green. Camburg uca, Icon w/700 Rear 210v w/ Foxs, Arb locker, Gear- 4.88 F&R. Tundra Trans cooler. All armor BFF
(Crawler) 95 Toyota pickup 22re, dualcases 4.7, Longfields, 37s, Dual Arbs.
IG: Jaysen4runner
06-21-2020, 07:28 AM
#105
The King OEM upgrade with extra travel on the 600 lb springs. My wife and I spent all day yesterday driving around on various roads and I wish I had done this sooner. I am traveling for work this week but hope to get on the trails in a few weeks to check out the travel on the shocks soon.
