06-21-2020, 08:09 PM
#106
Real Name: Devan
Real Name: Devan
Anybody know how much extra weight the OME 890s are rated for? Just curious, since I can't find much beyond just listing them as "medium duty"
06-22-2020, 10:44 AM
#107
The 890 has a spring rate of 190 pounds, compared to the 891 rate of 210 pounds. Those are the 3” coils. The 2906 are 220 but only a 2 inch lift.
97 Limited, 5100’s, OME 883/891, Built Right UCA, Custom Sliders, coastal off-road front bumper, 4x innovations rear bumper(custom built swing out), 4.88 gears, Circuit Offroad 17x8.5 wheels, Kenda Klever RT 35x10.5r17
06-22-2020, 06:23 PM
#108
Real Name: Eric
Real Name: Eric
Just Picked up some 891s for my settup, planning to lift next week. Have a hunch its gonna be pretty rough a lot of the time, but seems like the 891s are just a stellar choice from everything I've read.
'99 4runner SR5 4wd 5-speed: Cooper Discoverer STT Pro (265/75r16), Tacoma Whip Mod
06-22-2020, 08:41 PM
#109
Real Name: Devan
Real Name: Devan
Awesome, thank you. I won't be running any serious extra weight in the rear for quite some time, so I don't need the heavy coils - but I would like to stiffen the ride some. I've heard great things about the 890s, just never got a spring rate
Seems to be lots of debate around OME coils, I'm learning
06-24-2020, 10:57 PM
#110
Here's what the 210v's look like with no weight. Got some rake but will be adding quite a bit of weight in the future so I figured i'd just get them now so I don't have to change them out later.
1999 Limited with rear locker.
Sherpa Matterhorn | Sonoran Steel Diff Drop | SPC UCAs | DuroBumps Front and Rear | OME 890 Springs and Black Tokico Shocks | Eimkeith Reinforcements and PCK | King Coilovers | OCD Sway Bar Links | Opt Offroad Rear Arms | Lil Skips Gas Tank Skid Plate | FGP Rock Sliders | 4x Innovations Rear Plate Bumper with tire carrier
06-25-2020, 09:48 AM
#111
Real Name: Patrick
Real Name: Patrick
What's your hub to fender measurement in the rear? How much additional weight do you currently have in the rear?
06-25-2020, 08:38 PM
#112
On the drivers side I measured about 25.5" and the passenger about 26.5". I have zero weight in the rear right now in this picture. Even my hitch is off and have a empty tank of gas. Need to load it up with some everyday carry gear and i'll also have a roof rack and rooftop tent on it soon. So all of that should add around 200lbs. Then i'll be getting a rear bumper with tire carrier sometime in the future.
06-26-2020, 08:53 AM
#113
Real Name: Patrick
Real Name: Patrick
Thanks for the measurements! That's a substantial difference between driver and passenger. I'm assuming you installed them according to the picture which was for a right hand drive which should have the same drivetrain/fuel tank configuration as a left hand drive. Have you considered swapping coil sides to see if it makes a difference?
06-26-2020, 07:47 PM
#114
Yea I put the taller spring that was labeled left on the drivers side so idk why it's lower. I'll measure it again after I drive around for a while and see if it changes.
06-26-2020, 10:50 PM
#115
Real Name: Devan
Real Name: Devan
I've never seen that plastic trim on and along the bottom on the doors. Is that a JDM thing? It really adds to the look
06-27-2020, 12:58 AM
#116
You’ve never seen a “limited” package 3rd gen 4runner???
Must be not many 3rd gens around your AO. Where I live you could hardly throw a rock without hitting one.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
06-27-2020, 01:07 AM
#117
I got the Moog 81041 rear coils in the rear, not sure how i feel about them yet. 500 miles on em so far and i swear my passenger side sits higher...
06-27-2020, 11:39 AM
#118
Real Name: Devan
Real Name: Devan
No no, it's like that way across all of WA - truly a sight to behold
Just the chances of seeing on stock is very slim - sometimes it hard to find one on OEM susp./ride height! And given my running boards sold for $250 it seems like OEM stuff is few-and-far in between
Because it does. Look up Toyota's "left lean" - huge problem with Toyota and these vehicles were some of the most prominent. There are a few ways to fix it, such as trim packers. Its such a problem many lift kits will level it for you with the coils themselves, or offer packers/spacers in the package (only gets worse as you get higher).
BTW I've been using those coils for the past few months/~1000mi (along with the Moog front pair). They're a little softer than OEM, but they'll do. Didn't settle much, and still sits level - just a lil squishy as times.
06-27-2020, 12:05 PM
#119
i was familiar with that but feel like its way more pronounced now! interesting.
yeah i have two more days if i want a free return on them , not sure yet.
ALSO how many replies or input do i need to do before i cant post a thread? i have a crazy noise in a video i wanna post to get help with on my 98
new account here
06-27-2020, 12:09 PM
#120
Real Name: Devan
Real Name: Devan
I believe it's 10 or something
