Old 01-08-2020, 06:27 PM #16
TCMach's Avatar
TCMach TCMach is offline
Real Name: Tyler
TCMach will become famous soon enough
TCMach's Avatar
Real Name: Tyler
I need a 1" lift coil that holds weight like an 861 and has enough free height not to fall out.....
My build:TCMachs build
2000 4Runner:Kings, 37s, lockers
2018 TRD OR:stock and staying that way
TCMach is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 05:13 AM #17
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Originally Posted by 4runnerfiend View Post
Sorry I don' have specific data. But..
I've been happy with LC 8 wraps with no internal cone bumpstop.
I always run with about 100+ lbs in the rear and it sits at just above 24" so about 3" lift.
When I'm fully weighted with camping gear and people shoot probably 300 lbs with all the cooler ice and water/gear.. maybe more. it sits about level with the front 23"
Just got out a did a good flex test. Grabbed the coil springs and they were not going anywhere, no chance of them falling out.
Running FJ/4th gen 5100, no sway bar, and Rokmen offraod lower links.
For me, I don't need any more travel in the rear, I need to concentrate on the front travel.
Now if I was running a 200 lbs rear bumper plus all this stuff. It would be to much weight.
A big problem I've seen with using used FJ80 coils is that the variance can be huge. I originally ran 8 wraps in the rear of my first 4Runner and found them to be way taller than a lot of other member's sets. I was sitting about 4.5" of lift unloaded or with moderate load. Once I stuck an extra 400lbs in the back it was closer to level, but still not perfectly even with the 3" up front. About 3.5" with the 400lbs directly over the rear axle in the cargo area.
I will say though, I had it paired with OEM Tokico FJ80 rears and the ride quality was superb for a budget oriented setup. Much better than running a budget aftermarket shock like rough country, pro comp, etc. Similar experience with off the shelf stock replacements from Napa paired with Superflex coils, Highly recommend it to anyone looking for a cheap shock ~75$ for the pair.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 08:34 AM #18
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
I just got a Slinky/Icon setup for our FZJ80 - the coils are designed to have multiple dead loops at ride height that work as a helper spring to keep the coil from falling out when drooped. Perhaps the Australian company that makes them would be interested in rolling a 3rd gen solution as well?
80 series Slinky/ICON Long Travel Suspension officially coming to the U.S.A. | IH8MUD Forum
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2023
eimkeith is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 05:17 PM #19
TCMach's Avatar
Real Name: Tyler
TCMach's Avatar
Real Name: Tyler
FWIW in my search for a shorter coil I got this from Dobinson.
C59-137V - 170lbs open -245lbs ride height - 331lbs collapsed - 420mm FH. The 70 mm difference in free height from an 861 or superflex might be an issue.
Old 01-09-2020, 06:37 PM #20
CT135 CT135 is offline
CT135 will become famous soon enough
So is there a difference between the Dobsinson 210V and the OEM LC springs? WHy would I want to buy one vs the other? Can it handle weight better than the oem but isn't as crazy tall/heavy duty as the OME 861. Cause if that is the case I may be buying them.
Originally Posted by Taylor20 View Post
Thanks Rick for starting this.
Just to throw some more info out there from my searching.
The Dobinson 675v is a LT 4th gen rear coil. It provides the 4th gen's 2.5" of lift on average in stock form. That would provide us with 3.5" of lift due to the OE 4th gen spring providing about 1" of lift to start with. With extra weight it would bring that down some.
The Dobinson 210v is the stock height extra weight LC front spring, and from what @Black798 has told me it offers about 3.5" of lift with the extra weight.
I did have 861's, rear swingout and drawer system, but almost 5" of lift, it was just too much for me. I will probably order the 675v and see what those provide in the next couple months.
Free height is key for a spring not falling out, it would have to be at least 480mm to not leave a worry of them doing so.
CT135 is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 07:57 PM #21
HiMiles HiMiles is offline
HiMiles is on a distinguished road
I've had about 6 different rear spring pairs in my 4Runner, with many more sub-combos of packers and air bags. I have both high and variable weight in the back, since I have a 4XI swingout bumper and tow a light car trailer from time to time.
I ended up with the Superflex coils, simply because they have the highest "final" rate of any of the heavily progressive coils and prevent big rake changes with variable weight. This is a huge selling point, especially when they still ride very nicely sans trailer.
Unfortunately, air bags aren't quite the silver bullet they'd seem to be for variable weight, since you can't safely run them at 0psi. I always found them a bit harsh unladen, even inside soft coil springs.
HiMiles is offline   Reply With QuoteReply With Quote
Old 01-09-2020, 10:19 PM #22
So with your bumper/swing out. Roughly how much lift are you getting from the super flex? Hub to fender would be awesome to know.
Old 01-10-2020, 07:54 PM #23
Fishwerks's Avatar
Fishwerks Fishwerks is offline
Real Name: Chris
Fishwerks will become famous soon enough Fishwerks will become famous soon enough
Fishwerks's Avatar
Real Name: Chris
Originally Posted by rickashay View Post
I for one, would love a LT rear spring capable of staying in the coil buckets at full droop, capable of supporting 200-250lbs of rear weight (over stock) and sitting at 2.5-3” of lift. My ideal spring may be different than yours, but that’s where we can start to collect some data and see if there are some common themes to approach a vendor about a custom spring potentially.
I'm glad you started this thread. I've been talking to Tyler about rear springs a good bit lately. I like the 861s when I have the swingout on and the truck loaded for a camping trip or something, but most of the time I wish they sat 1-2" lower. Like @AZBub mentioned, you really need a lot of weight to get them down to a reasonable height.
Originally Posted by 4-Ripcord View Post
I went through the same process on my last 4runner, actually had most of these springs on it at one point or another trying to find the right one I liked.
I used some OME chart to fill in spring rates for most of them, and confirming free heights by hand measurements. The superflex and 891 are progressive so hard to give an exact value for, but superflex definitely felt softer than the 861. IMO the 861 were too stiff.
In the end I was most happy with the superflex, and would get that again if I built another t4r.
My requirements were very similar to yours: +250ish lbs, less than 3" lift, long enough to not fall out when drooped.
Good to know, I've been considering superflex or one of the dobinsons variations as options.
Take a sawzall to the 861s and let us know how much to cut.
Fishwerks' Photo/Build Thread 2000 SR5 l White on White l 35s l Supercharged
2010 Trail Edition l Salsa Red Pearl l Stock
Instagram
Fishwerks is offline   Reply With QuoteReply With Quote
Old 01-10-2020, 08:53 PM #24
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
I was thinking more along the lines of what we did in high school to lower rigs. Take a torch and apply heat at the right point until the spring relaxes to the desired height.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 01-10-2020, 10:58 PM #25
Taylor20's Avatar
Taylor20 Taylor20 is offline
Taylor20 will become famous soon enough Taylor20 will become famous soon enough
Taylor20's Avatar
Originally Posted by AZBub View Post
OME 861. You either love em or hate em. The thing is if you have a lot of gear all the time or an actual overland rig buildout in back is where these springs shine the most. Yes unloaded they sit high. No they are not for a rig that doesn’t have a ton of weight in back. A ton of weight would be along the lines of a fridge, slide, storage, support gear, rear tire swing out with fuel etc.... Just like you would re-gear to gain back performance from weight and tire size etc you add these springs to deal with....weight.
I have those now, and those that I have talked to with them agree its too much lift and too stiff. This sparked the quest, for me at least, to find a more suitable spring.
Slinky is good stuff, I'm just leaning more towards Dobinson because I have been in contact with someone about a creating a new option for the 3rd gen's...and I have just heard more about Dobinson.
If the free height was there, these would be an excellent option with say under 150 extra lbs.
Spring rate and coil diameter for the most part. The difference in minimal, only about .5" between the two.
I had Superflex before the 861's and swingout, drawer system. Amazing springs, but with extra weight, they sagged.
Ya, they are a good option, just not the right option for most.
Horrible idea
02 Sport
Toytec Boss/LJ - TRD Pro & 255's - TBU - 4:30's - Elocker
4xI - AED - Savage
Taylor20 is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 01:40 AM #26
Tough crowd. LOL!
Old 01-11-2020, 02:22 AM #27
rickashay's Avatar
rickashay rickashay is offline
Real Name: Addison
rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold
rickashay's Avatar
Real Name: Addison
Good discussion. I might have to try the superflex's but I am worried I will be too heavy for them too...
I am just waiting for someone to try the Dobinsons 675V before I make a move.... any takers? lol
rickashay is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 09:50 PM #28
Mark_BC's Avatar
Mark_BC Mark_BC is offline
Real Name: Just call me the Grease Monkey
Mark_BC has a spectacular aura about Mark_BC has a spectacular aura about
Mark_BC's Avatar
Is there a front version of this thread? I'm going to get a coastal offroad front bumper (100 lb) plus winch so i want to know which coil and shock to get for about maybe 1" of lift and overlanding with gear in the back.
3rd Gen 4Runner Closed Top Front Bumper Kit - Coastal Offroad
I know there's tons of threads on suspension but it changes from year to year and there's too much information overload.
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
Mark_BC is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 09:09 AM #29
Taylor20's Avatar
Taylor20's Avatar
I will be as soon as my 861's sell
02 Sport
4xI - AED - Savage
Old 01-17-2020, 12:37 AM #30
Stumbled across this site. It’s got a pretty good list of specs.
Cruiser Outfitters
3rd , coil , gen , rear , spring
Rear Coil Spring Changeout Franky_Dabbs 3rd gen T4Rs 12 07-02-2020 08:23 PM
Rear Coil Spring Replacement SouthAl 4th Gen T4Rs 6 07-26-2016 12:24 PM
PLZ HELP!! Rear spring coil question.. mironkedz 3rd gen T4Rs 0 11-24-2010 12:04 AM
Rear Coil Spring Spacer alp 3rd gen T4Rs 19 10-16-2010 12:22 PM
which rear coil spring????? lexustech 3rd gen T4Rs 4 10-12-2007 06:35 PM
