Old 10-06-2020, 12:07 AM #211
jaher jaher is offline
jaher is on a distinguished road
Suggestions?
I'm so impressed with everyone's builds and I'm hoping you can give me some advice. I have a '99 with the tall coils, now currently sagging in the rear. Here is what the current measurements are (unloaded):
Hub to fender Existing Tall '99 Springs
Front Left 20 3/4"
Front Right 20 1/2"
Rear Left 20 1/2"
Rear Right 20 1/4"
I carry normally about 75 lbs of tools in the back. I have an aluminum roof rack.
For camping, I pull a pop-up with a 400-500 lb tongue weight, with a weight distribution hitch. Plus, I am carrying my wife, two kids, a large dog and about another 100 lbs of gear/food. I'm running 265 70 R17 - brand new KO's on the new 5th Gen black/silver SR5 wheels - looks really good. We will often take rough four wheel drive roads. Not very much rock crawling though.
I'm looking for a moderate lift, maybe 1" over what original tall spring height. I don't really want to get into lowering the front diff, panhard bar, etc due to limited funds for the rig build. I don't think steel plate bumpers are any where in my near future. I like the idea of rear progressive springs to handle the trailer weight better.
Any suggestions on a suspension setup? Thank you!
'99 SR5 V6 5 sp MT, approx 202k miles, elocker, Colorado mod (hail dents) and antenna delete mod (car wash method) but working on getting everything in order
jaher is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 02:49 AM #212
beklemmung's Avatar
beklemmung beklemmung is offline
Real Name: Levi
beklemmung is on a distinguished road
beklemmung's Avatar
Real Name: Levi
If you haven't already seen it, I suggest taking a look at this thread: Absalom's Cookie Cutter 4runner Builds - New and Updated! Read through the whole thing; Absalom added two more build options in post #158 on page #11.
Front Left 20 3/4"
Front Right 20 1/2"
Rear Left 20 1/2"
Rear Right 20 1/4"
1997 3.4L 4WD auto SR5, nearly 200k miles, pretty much all stock
beklemmung is offline   Reply With QuoteReply With Quote
Old 10-06-2020, 11:09 PM #213
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Originally Posted by Wrecked - Rebuilt View Post
So I've had my 210v's on my truck for four months now, so I think I can safely give a fair review. This included three months of daily driving and quick trip to Moab, where I hit Top of The World, Elephant Hill, Fins and Things and White Rim.
If I had the stock bumper/stock weight these would be a serious no-go. They give almost as much lift as the OME 861. I'd wager 5-5.5in at stock weights. With my coastal off road plate bumper i'm sitting right at 4.5in. And fully loaded with my full size spare, recovery gear, spares, camping equipment and 50qt cooler with ice I'm right at 4in. When I add my 4xinnovations swingout I'll be at 3.5in [verified by adding another 200lbs to the truck]. They have not settled more than .25in in 10,000mi
My rear setup for the last 4 months:
-Dobinsons 210v [no spacers or stock bump-stops]
-Tokico LC Shocks [top mounting plate bored out for LC hardware]
-Durobump 5.25in extended bumps
-Eimkeith panhard correction kit
-Extended Brake lines
-Sonoran Steel Sway bar relocation/lift [to clear the e-locker motor]
-Stock sway bar links
-Whiteline control arm/panhard bushings.
-255/85r16 Maxxis
This setup did amazingly well on all of the trails. No issues fully flexing out to the bump stops. The driveshaft only makes the slightest contact on the gas tank skid...only noticed the witness marks when inspecting the truck, never heard it hit.
The ride, for a lifted 24year old truck is surprisingly compliant. And once you have it loaded for the weekend the rear of the truck is genuinely comfortable. I was most impressed with how well the coils held weight under 'moderate speed' runs...40mph off road. The coils held the weight while providing enough up travel that I never had the rear bottom out. However the front bottomed out 3-4 times, I hate that feeling.
The 210v's are here to stay on my truck. However, I don't think these are going to be the 'golden ticket' for low height, high flex coils. For me, these fall under the same category as the OME 861. If you are running a plate bumper with swingout, and load the truck up with people these will be great. However, I'd look somewhere else for a stock weight truck.
I too am using 210v+Tokicos and can confirm with no weight the rear is a little bouncy, and I could see how it could get annoying for most, but personally I don't mind it since a rear bumper will be added eventually - on that note, they handle weight incredibly (or at least the 200lbs of gravel I had). One of the very few gambles I'm satisfied with. What side did you put the bigger coil on?
I wouldn't exactly say the 210v are a low lift coil though - they're basically a progressive (and stiffer?) 8 wrap LC coil. Without weight I think I gained about 4in or so, maybe more. Hard to tell when going from clapped to new suspension. But +200lbs made it nearly even with my Tundra front end, maybe 1/2in of rake
Old 10-07-2020, 09:04 AM #214
Wrecked - Rebuilt Wrecked - Rebuilt is offline
Real Name: Matt
Wrecked - Rebuilt is on a distinguished road
Real Name: Matt
I have the taller of the coils on the driver's side. My truck really likes to show it's driver's side lean, so I also have a 1/4in top plate spacer on the driver's side strut.
The one thing I'm always surprised with is how much variance there is between 4runner with the 'same' equipment. With my setup I feel that I'm getting more lift than most. With my 120lb plate bumper, sub, and recovery equipment I'm easily at 4.5in of rear lift. My front is sitting at 3.25in [too tall for my taste]. But I know I'll be able to lower my front suspension to 2.75in once the swingout goes on. I'm not running the centering cones, so maybe it is a result of running whiteline bushings, where there is less binding and the suspension can more freely move? No idea. Maybe I need to take some measurements from my stock 00'
Wrecked - Rebuilt is offline   Reply With QuoteReply With Quote
Old 10-07-2020, 12:31 PM #215
cdrewferd cdrewferd is offline
Banned
cdrewferd is on a distinguished road
Banned
I just ordered the 210v and will be getting the Tokicos soon. Don't have a plate rear yet, but will be building one with a dual swingout this winter so that should help bring the height down.
cdrewferd is offline   Reply With QuoteReply With Quote
Old 10-08-2020, 08:03 PM #216
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Oh jeez, that does seem a little excessive. Very strange. Solid axle isn't particularly complicated, so if anything I'd think Dobinson sent the wrong coils, but that seems kinda far fetched. Might be worth a shot to take them out for some measurements and compare online, you could try asking them directly but since the springs aren't intended for our vehicles I'm not sure if you'll get much advice
Don't forget to get the tokico retaining washers for the top bushings as well, if you bought from a Toyota dealer like McGeorge. For whatever reason they include the bushings and nuts, but leave out the retaining washers and make no mention of it
Old 10-10-2020, 10:41 PM #217
raztec raztec is offline
raztec is on a distinguished road
Interesting read Absalom has. I always assumed the Old Man Emu coil springs were the best options for the 3rd gen 4runners. But he doesn't even mention them once.
raztec is offline   Reply With QuoteReply With Quote
Old 10-11-2020, 01:00 AM #218
beklemmung's Avatar
Real Name: Levi
beklemmung's Avatar
Real Name: Levi
He mentioned them in the Jack of All Trades build (OME 906 in the rear). A lot of people use 880s or 881s in the front, if they want more lift than 99 talls.
**Rear Coil Spring Discussion - The Perfect 3rd Gen Rear Spring**-ome-springs-jpg
Old 10-12-2020, 11:44 PM #219
Boss.man Boss.man is offline
Boss.man is on a distinguished road
Has anyone considered looking into a lift coil from the 5th gen? I'm definitely sold on the Dobinsons. But I wanted a little more than the 2" a 137v will give.
I know that just swapping the stock coils from a 5th to a 3rd will net about 1" of lift. But I'm looking for 2.5-3" rear lift. I was looking at the C59-325 or the C59-505.
I'm going to pair them with billy 5100's. I believe the 325's are a 1.5" lift for a 5th gen and the 505's are a 2" both at stock weight. And since the 5 is about 1000 lbs heavier than a third, I would think it would handle the 400ish extra pounds I usually have on board.
I just don't want to worry about dropping a coil anywhere. I've also given some consideration the the 137v's with the 10mm packer. But once again do not want to drop a coil.
For reference I was looking at these shocks at wheelers.
5100 Rear Shock Set for 1996-2002 4Runner (1.5"-3" Lift)
Boss.man is offline   Reply With QuoteReply With Quote
Old 10-19-2020, 05:13 PM #220
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
It's further up in the thread, but a couple people have said that 5th gen rear coils are too wide and don't sit correctly in the coil buckets and can make contact with the frame as the compress/extend.
Old 11-12-2020, 04:44 AM #221
Jaysen4runner's Avatar
Jaysen4runner Jaysen4runner is offline
Jaysen4runner will become famous soon enough
Any 210v forsale before I purchase online? 😅
(DD)-97 4runner limited Green. Camburg uca, Icon w/700 Rear 210v w/ Foxs, Arb locker, Gear- 4.88 F&R. Tundra Trans cooler. All armor BFF
(Crawler) 95 Toyota pickup 22re, dualcases 4.7, Longfields, 37s, Dual Arbs.
IG: Jaysen4runner
Jaysen4runner is offline   Reply With QuoteReply With Quote
Old 11-14-2020, 03:24 AM #222
Fiffa's Avatar
Fiffa Fiffa is offline
Fiffa will become famous soon enough Fiffa will become famous soon enough
Fiffa's Avatar
Originally Posted by Jaysen4runner View Post
Any 210v forsale before I purchase online? ��
Not here, but as a recent installer I will suggest this:
1. Do not use the stock spring bumpstops to get the perfect rake (if you normally carry around ~200 extra lbs. + roof rack)
2. You're most likely going to need spring compressors to get them in
- After getting my 890's out by just loosening the control arm bolts and removing the lower shock mount, the 210v's were near-impossible to do without compressors by myself
The progressive rate on these is like a dream! I could not be happier with my purchase. I have a set of 4th gen 5160's waiting to go in to compliment the springs, so be mindful of the longer travel out on the trails, too!
Edit - Should've read your signature.
Fiffa is offline   Reply With QuoteReply With Quote
Old 12-07-2020, 08:42 PM #223
2TH4IST's Avatar
2TH4IST 2TH4IST is online now
2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about
2TH4IST's Avatar
I have a 1"body lift too for rear bumper/f150 tank so measurements have been adjusted.
I have ome 891's and 4 runner billies up front on 4th perch (soon to be dropped a notch). Rear are currently 22.75 pass and 23 drivers with a 10mm shim pack on pass side. I have eimkeith's bumper (113 pounds), f150 tank (127lbs full of gas), gas tank skid (45lbs) and the stock steel spare 265/70r16 along with a 1st gen 4runner roll bar in the back. So a total of around 300-350 lbs added to the rear. Just ordered the dobinsons 210v. Hopefully they will work good, i like the 891's but they are already starting to sag (3 months or so now). I dont want sky scraper of a lift, but with the additional weight I'll be adding (spare changed to 255/85r16, and a shelf/drawer system) I hope the 210v's will be good to go. Fronts will be king when I get coin.
Edit 22" both side with a full tank. Earlier measurements were with a quarter tank.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is online now   Reply With QuoteReply With Quote
Old 12-07-2020, 10:48 PM #224
Fiffa's Avatar
Fiffa's Avatar
Originally Posted by 2TH4IST View Post
I have ome 891's and 4 runner billies up front on 4th perch (soon to be dropped a notch). Rear are currently 23.75 pass and 24 drivers with a 10mm shim pack on pass side. I have eimkeith's bumper (113 pounds), f150 tank (127lbs full of gas), gas tank skid (45lbs) and the stock steel spare 265/70r16 along with a 1st gen 4runner roll bar in the back. So a total of around 300-350 lbs added to the rear. Just ordered the dobinsons 210v. Hopefully they will work good, i like the 891's but they are already starting to sag (3 months or so now). I dont want sky scraper of a lift, but with the additional weight I'll be adding (spare changed to 255/85r16, and a shelf/drawer system) I hope the 210v's will be good to go. Fronts will be king when I get coin.
Edit 23" both side with a full tank. Earlier measurements were with a quarter tank.
Based off of my experience so far, they should be perfect. I measured my hub-to-fender (limited trim) height and it's just shy of 24" on both sides. If you're in the market for a good companion shock then do the 4th gen 5160. The back end is so much more controlled than it was with standard 5100's and 890's (no sway bar).
... and to correct my last reply: make sure the e-brake is off and you should have enough movement to get the springs in; maybe with a buddy giving you the last little bit of play while you push the spring in.
'00 'Get Lost' Build
IG: get_lost_fiffa
Old 12-08-2020, 12:12 AM #225
2TH4IST's Avatar
2TH4IST's Avatar
Man I'm having a off Monday. I have a 1" body lift too lol. So minus 1 inch is 22" rear and 22.75" front.
I had to do a super cheap lift to get off the bumps when I finished the f150 tank swap. So I'll add from my post above:
Rear
891's rear
Kyb lc80 rear shocks with frame mounts drilled
Extended brake line
Ebrake bracket diy
1" bump stop spacers
2nd gen t4r sway bar end links
10mm trim pack on pass side
22" hub to flare both sides full tank minus 1" body lift.
It's really flexy, and I love how the rear feels; softness vs dampening. But it's starting to sag, which is disappointing.
Front
Stock springs (yuck)
4runner billies (24-248730, don't like them but we're beyond cheap and adjustable).
Diff drop
2nd gen 4runner sway bar end links
22.75" hub to flare minus 1" body lift
Rides stiff up front dampening doesn't match rear, but was cheap and only option I had.
3rd , coil , gen , rear , spring
Rear Coil Spring Changeout Franky_Dabbs 3rd gen T4Rs 12 07-02-2020 08:23 PM
Rear Coil Spring Replacement SouthAl 4th Gen T4Rs 6 07-26-2016 12:24 PM
PLZ HELP!! Rear spring coil question.. mironkedz 3rd gen T4Rs 0 11-24-2010 12:04 AM
Rear Coil Spring Spacer alp 3rd gen T4Rs 19 10-16-2010 12:22 PM
which rear coil spring????? lexustech 3rd gen T4Rs 4 10-12-2007 06:35 PM
