Old 12-08-2020, 11:52 AM #226
Fiffa's Avatar
Fiffa Fiffa is offline
Fiffa will become famous soon enough
Fiffa's Avatar
Originally Posted by 2TH4IST View Post
Man I'm having a off Monday. I have a 1" body lift too lol. So minus 1 inch is 22" rear and 22.75" front.
I had to do a super cheap lift to get off the bumps when I finished the f150 tank swap. So I'll add from my post above:
Rear
891's rear
Kyb lc80 rear shocks with frame mounts drilled
Extended brake line
Ebrake bracket diy
1" bump stop spacers
2nd gen t4r sway bar end links
10mm trim pack on pass side
22" hub to flare both sides full tank minus 1" body lift.
It's really flexy, and I love how the rear feels; softness vs dampening. But it's starting to sag, which is disappointing.
Front
Stock springs (yuck)
4runner billies (24-248730, don't like them but we're beyond cheap and adjustable).
Diff drop
2nd gen 4runner sway bar end links
22.75" hub to flare minus 1" body lift
Rides stiff up front dampening doesn't match rear, but was cheap and only option I had.
With the additional weight you have compared to me (roof rack, rear storage loaded with gear full-time, spare in stock position) the 210's should still work nicely. These springs give when they need to in my experience.
As for the front, get you some 6112's! I feel like my setup has given this rig so much predictability and stability. I've been building it for overlanding more than rock crawling, so keep that in mind when considering my opinion.
'00 'Get Lost' Build
IG: get_lost_fiffa
Fiffa is offline   Reply With QuoteReply With Quote
Old 12-08-2020, 01:48 PM #227
2TH4IST's Avatar
2TH4IST 2TH4IST is offline
2TH4IST has a spectacular aura about 2TH4IST has a spectacular aura about
2TH4IST's Avatar
I'll dig into the 6112's. I too am building more for overland, my pocket book isn't deep enough for rock crawling. Yeah I want to say with the f150 tank it has helped a ton with stability/balance. But it's like having a fully loaded storage platform. Which I still need to build lol. The rear 891's with my weight have fully compressed the dead or progressive coils. And upon further inspection I see signs of the coil coming out of its pocket.
There's danger lurking around every corner, that's why I propose we make all of our buildings round.
I don't remember the time I was human that's why I don't understand anybody.
2TH4IST is offline   Reply With QuoteReply With Quote
Old 12-08-2020, 08:56 PM #228
Fiffa's Avatar
Fiffa's Avatar
Yikes! Before switching out my 890's I was nearly riding on the extended Durobumps! Lol
IG: get_lost_fiffa
Old 12-08-2020, 09:12 PM #229
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is online now
Real Name: Rich
the_welfare_wagon is on a distinguished road
Real Name: Rich
Rear
891's rear
Extended brake line
Ebrake bracket diy
Front
Diff drop
Im running 890s in the back. Do you think those LC80 shocks you have would be too long at full droop for me even if I extend bumpstops? I heard 890s are longer than 891s but I'm not 100% sure
the_welfare_wagon is online now   Reply With QuoteReply With Quote
Old 12-09-2020, 12:37 AM #230
2TH4IST's Avatar
2TH4IST's Avatar
Hmm I'm not 100% sure about to much droop, the 2 issues are to much droop dropping a coil spring, and the shock bottoming out before it hits the bump stop. I can't tell you how I came up with how much I needed to extend the bumps. I probably need to extend more. But planning on buying the duro bumps soon.
But everything is on hold at the moment, just got news today that they are closing down my work permanently on 12/31. Boo.
Old 12-09-2020, 12:53 AM #231
Fiffa's Avatar
Fiffa's Avatar
That sucks! Sorry to hear that, man!
IG: get_lost_fiffa
Old 12-30-2020, 03:06 PM #232
Jaysen4runner's Avatar
Jaysen4runner Jaysen4runner is offline
Jaysen4runner is on a distinguished road
Just installed the new 210v, over all very happy compared to the LC7.5. also installed a set of durobump 5.25 bumps. Sorry guys not sure why I cant rotate it around.
**Rear Coil Spring Discussion - The Perfect 3rd Gen Rear Spring**-db3-jpg  **Rear Coil Spring Discussion - The Perfect 3rd Gen Rear Spring**-db1-jpg  **Rear Coil Spring Discussion - The Perfect 3rd Gen Rear Spring**-db2-jpg
(DD)-97 4runner limited Green. Camburg uca, Icon w/700 Rear 210v w/ Foxs, Arb locker, Gear- 4.88 F&R. Tundra Trans cooler. All armor BFF
(Crawler) 95 Toyota pickup 22re, dualcases 4.7, Longfields, 37s, Dual Arbs.
IG: Jaysen4runner
Jaysen4runner is offline   Reply With QuoteReply With Quote
Old 12-30-2020, 07:37 PM #233
JSparky's Avatar
JSparky JSparky is offline
JSparky is a jewel in the rough JSparky is a jewel in the rough JSparky is a jewel in the rough
JSparky's Avatar
New to the 3rd gen forum, we just picked up an 01 as a backup vehicle for Baja.
I read through all the posts but couldnt find what Im looking for. Wed like a progressive/variable rate rear coil designed for stock/light loads. 2 lift max, ideally less. Does this coil exist? Thanks everyone.
67' Land Rover 109, 97' FZJ80, 16' 4Runner Limited
http://www.toyota-4runner.org/5th-ge...-jr-build.html
http://www.overlandcookery.com
http://www.schaubphoto.com
JSparky is offline   Reply With QuoteReply With Quote
Old 12-31-2020, 04:00 AM #234
Kirk D's Avatar
Kirk D Kirk D is offline
Kirk D will become famous soon enough
Kirk D's Avatar
I read through all the posts but couldn’t find what I’m looking for. We’d like a progressive/variable rate rear coil designed for stock/light loads. 2” lift max, ideally less. Does this coil exist? Thanks everyone.
Eibach claims to have a 1” lift coil. No info on load rating though. Beyond that I’d say the ome 890 but it would likey be more than 2 inches of lift with no load.
Ironically I just pulled my 890s out today to put in some LC 7.5 wraps. I was already well through the low rate with the amount of weight I’ve got back there. I know they’ve got a lower rate but they have a better free height so I netted 2” more ride height and I’ll just re-valve the kings a little tighter. At least until I can grab some 210v coils.
Edit: I think toytec also have a variable rate labeled to be what you’re looking for. Light to no load variable rate with only 2” lift.
Kirk D is offline   Reply With QuoteReply With Quote
Old 12-31-2020, 04:09 AM #235
Kirk D's Avatar
Kirk D's Avatar
Very curious to hear the differences from you because it looks like we might have a similar weight situation out back sans auxiliary tank but you may have more in the cargo than I do.
Old 12-31-2020, 02:04 PM #236
tunerboy tunerboy is offline
Real Name: Kenny
tunerboy is on a distinguished road
Real Name: Kenny
our 3rd gen spring/ shock setup
Originally Posted by det107 View Post
To The Top~
Any more ideas or set ups? Please share-
we typically spend 95% of our time on highway or gravel roads. I realized, with previous experience on our 03 Tacoma, that the damping on the King coilovers and Bilstein rear shocks was excellent while rolling fast down rough roads and trails, but way too under damped on the highway.
on our 4Runner, I went for Moog 81041 springs in the rear, Moog 81088 springs up front, with KYB heavy duty monotone shocks all around. next was new lower track arm bushings from Siberian Bushings, for a fantastic tight, firm ride that is still acceptable for our low speed offload action.
these Moog springs were for the Highlander version of the 4Runner, with about an inch more ride height than our Limited had as stock.
tunerboy is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 02:09 PM #237
The ride is a lot more plush, a course my shocks aren't anything like yours. I'm on 210v paired with Foxs 2.0 from a Tundra. No more bottoming out compared to before a bit tighter on corners but overall the weight is what I wanted most. Which the 210v seem to do very well as for now. We will see it how it does after I abuse it on the Trails here in Fresno!
IG: Jaysen4runner
Old 01-15-2021, 02:40 PM #238
Kirk D's Avatar
Kirk D's Avatar
Time to get on the dusy ershim trail. I need to go do that one again.
Old 01-15-2021, 11:29 PM #239
3bears 3bears is online now
Real Name: Joshua 3 Bears
3bears is a jewel in the rough 3bears is a jewel in the rough 3bears is a jewel in the rough 3bears is a jewel in the rough
did you have to use any trim packers to make ride level side to side ? wonder what the life is of the coils. I had KYB gas adjust with the "toyota" talls and only got about 50k out of the rear shocks, but springs lasted. I assume you meant monomax on the kyb's
2001 SR-5...bone stock ( for now) bought 12/10/20. silver, cloth, sunroof.
2000 SR-5 V6 Auto . TOTALED 10/22/20. Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, 3 inch lift with tundra springs, billies, lc springs tokico shocks, DRL delete, Big 3 wire, full roof rack, TBU, Swapped in Elocker , all synthetic fluid. block, oil pan and tranny heaters, other small junk
3bears is online now   Reply With QuoteReply With Quote
Old 01-20-2021, 01:18 AM #240
I wouldnt take my 4runner on Dusy, Ill take my crawler lol
IG: Jaysen4runner
3rd , coil , gen , rear , spring
Rear Coil Spring Changeout Franky_Dabbs 3rd gen T4Rs 12 07-02-2020 08:23 PM
Rear Coil Spring Replacement SouthAl 4th Gen T4Rs 6 07-26-2016 12:24 PM
PLZ HELP!! Rear spring coil question.. mironkedz 3rd gen T4Rs 0 11-24-2010 12:04 AM
Rear Coil Spring Spacer alp 3rd gen T4Rs 19 10-16-2010 12:22 PM
which rear coil spring????? lexustech 3rd gen T4Rs 4 10-12-2007 06:35 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
