Old 08-06-2022, 04:38 PM #316
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Free height is the unloaded (free from weight) height. It’s the longest the coil will ever be which can determine if your coil is going to fall out of place while flexing.
901 coils are for the rear of 2nd gens. 906 coils are for the rear of 3rd gens
Old 08-07-2022, 04:58 AM #317
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
is the front conical coil isolator of the LC80 similarly sized to that of the VZN185L 4Runner?
Originally Posted by Devbot View Post
What are you 210V folks doing for coil isolators - did you keep the OEM cones, scrap em, or what?
I took mine out because I hate how they look and wanted to drop my rear down slightly but without them the coils buzzed nonstop over the smallest bumps in the road. I put them back in so it wouldn't be so embarrassing driving around but that extra height drives me nuts; I can almost swear they add upwards of 1/2 inch instead of 1/4 inch even though i know better (stupidly didn't think of taking before/after measurements to confirm this afternoon)
I would love to even out my rake even just slightly but I really don't want to carry around a bag of sand or gravel - been there-done that, a year later I'm STILL vacuuming up sand and pebbles. Anyone got a trick up their sleeve? I'm assuming not since solid axles are dead simple and there's not really much to hide but I thought it would be worth asking regardless. I heard one user tried to slip a piece of tubing over the top of the coils which sounded like a smart idea, but apparently it fell out pretty quickly (and I imagine zip ties wouldn't last long with constantly rubbing against the body)
What I wouldn't give for these coils to be a hair shorter.... If they were wrapped a little differently I probably would've taken a sawzall to them by now honestly. Hell I'm still considering it a little bit, but I'm not that cheap and will probably get some new front coils if I can't think of anything
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 08-07-2022, 05:01 AM #318
does the 901 have the same OD as that of the 906? That could be a potential alternative, longer coil with the same spring rate
Old 08-07-2022, 09:06 AM #319
Real Name: Patrick
Real Name: Patrick
I have no idea if they will interchange, but 901 springs are only 5mm longer free height than 906 springs. You’d get more height by adding trim packers to 906 springs.
Old 08-07-2022, 10:22 AM #320
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I had that idea but I couldn't find any that weren't just as thick if not more. But I also didn't look very hard so maybe I'll give it a whirl, if anything they'd give a way cleaner look
Old 08-08-2022, 01:06 PM #321
octanejunkie's Avatar
octanejunkie octanejunkie is offline
Real Name: C8H18 Mike
octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of octanejunkie has much to be proud of
Thickness doesn't always matter, it's how they are formed and heat treated.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->2WD 4runner Journal Thread
octanejunkie is offline   Reply With QuoteReply With Quote
Old 08-18-2022, 07:44 PM #322
89T4runner's Avatar
89T4runner 89T4runner is offline
89T4runner is on a distinguished road
89T4runner's Avatar
Anyone here running the 9602HD coils from Toytec? Wondering if they would be an upgrade from OME 890s
Toytec Rear 3" Lift Heavy Duty Coils (Pair) - 96-02 4Runner
9602HD-P - Toytec Rear 3" Lift Heavy Duty Coils (Pair) - 96-02 4Runner
We designed these rear coils for use with additional load.
Toytec rear lift coil springs offer a great ride quality and increased rear suspension off-road performance.
These coils provide an average lift amount of 3" (with approximately 300 LBS additional weight).
These coils are custom made to our high quality of standards.
Designed as a pair with side specific coils to help eliminate the typical driver side lean that is common with 3rd Gen 4Runners.
Not for use with stock rear shocks.
Extended rear brake lines recommended.
Sold as a pair.
**Recommended for use with additional constant load or lift amounts will be greater
Sent from my SM-G998U using Tapatalk
1989 4runner 'Marilyn', 3.0 5 spd, ball joint spacers with KYB monomax, OME springs with 5100s, 33x12.5 duratracs, 4.88s, ARB fr, open rear, smittybilt fr, trailgear rr.
2000 4runner SR5 sport w/ elocker, Fox 2.0s fr, tundra 5100s with OME890 rr
89T4runner is offline   Reply With QuoteReply With Quote
Old 10-16-2022, 11:11 PM #323
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
So is the consensus the Dobinsons 675V won't fit with long shocks like Tokicos? That sucks if so. I was hoping they'd just be slightly smaller 210V's
Originally Posted by 89T4runner View Post
Anyone here running the 9602HD coils from Toytec? Wondering if they would be an upgrade from OME 890s...
If you search 9602 in the thread's search function (not the forum's search at the top right of the page) you'll find some here and there posting about them
Old 10-18-2022, 03:28 PM #324
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
I kind of forgot about this thread. After having some seat time with the 2890 ome springs, I feel like they were a great upgrade for the extra weight over the 2906.
For a close to level, daily driving, some wheeling, without lots of weight (stock skids and such)on a 2” lifted 3rd gen, it’s almost perfect. It’ll hit the bump stops more and more as weight in gear and armor goes on.
The 2890 ome did add a lot of lift though. Definitely has a rake now even with weight. I’m starting to rebuild the front end with all new Toyota lower arms, JBA uppers, and I’m planning to move the 6112 coils up to the 2.3” from 2” to see if that gets it about at the right ride height. It’s really cushy thought for the high speed rally stuff.
The 2890 did reduce the bottom outs greatly. It feels like a lot of travel was added since it’s not constantly hitting the Duro bumps now. A sway bar adjustment was needed though, which helped the added body roll greatly. I have an eimkeith PCK on order to hopefully alleviate the body roll since the added ride height with the 2890. I’m sure the rear end bushings are also shot.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 05:50 PM #325
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
I thought the 906 are heavier than the 890’s? 220 vs 190?
I loved my 890’s when I ran them. They don’t have enough free length and high enough ride height for my setup, and like you said, they get overloaded quickly just because they don’t sit high enough to keep off my extended bumpstops & longer compressed length shocks when you have any real weight in the back. They work best with the 4Runner 5100’s or similar ext/ comp length shock from my experience. That way you do without the bump extension and maximize their bump travel before making contact with the axle.
There’s not much for options between 890’s and LC coils ride height-wise unless you’re mixing trim packers and/ or spacers. I wanted to try the Dobinsons but they seem like their options are just like the older aftermarket offerings (ARB & Toytec primarily). Either too short or too long for my ride height and spring rate preference. That’s why I settled for the older Toytec Superflex even though they’re a 240 lb spring rate and would have preferred 200-220 ideally. They have plenty of free length to prevent dropping a coil when using the longer travel shocks and also sit at a decent ride height to avoid contacting the bumpstops too easily and don’t sit at 4”+ lift unloaded. I had to settle on a heavier coil to get the other properties I needed out of a rear coil.
It’s a game of give and take the way the rear suspension on these vehicles work.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 10-18-2022, 11:26 PM #326
Romeo1's Avatar
Romeo1's Avatar
**Rear Coil Spring Discussion - The Perfect 3rd Gen Rear Spring**
Your right, The rate is higher on the 2906, like you said at 220 pounds per inch. But the free length is much shorter. I plotted out the spring rate, and even though the 890s spring is a lighter 190 rate, the addition of free length comes into play and ups the ride height at a given load much better than the 2906.
Some force examples.
190x3 =570
220x2.59=570
190x4=760
220x3.45=760
I do sometimes wonder if a 220 rear spring rate is probably a better match for the 600 pound front spring rate with my 6112 shocks, slightly at least. But the issue is is getting the right freelength in that spring rate. Even when you go to the 891, you get a shorter spring.
Other reason for my decision to go with the 2890 was the sales guy at Wheelers said a coworker had 2891 springs in his 4runner and it rode like crap since there wasn’t hardly any weight on it. He said you better have some bumpers and a drawer system, otherwise you won’t like it. So I went the 2890 route.
My thinking was the rear springs are cheap enough to replace when/if I cross that bridge.
Old 02-06-2023, 12:16 AM #327
rickashay's Avatar
rickashay rickashay is offline
Real Name: Addison
rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold
rickashay's Avatar
Real Name: Addison
Do you know how much lift you’ve got with the older Superflex coils? I just picked up a set as well and am hoping for a similar result. Do you know if all older Superflex coils are the same at the 240lb rate?
190x3 =570
220x2.59=570
190x4=760
220x3.45=760
The reason I started this thread was to basically gather data, start discussion, and chat about the “perfect rear 3rd gen spring”. I still think a coil that rode like an 890 but had a longer free height would be a great rear spring option for our trucks. ~2.5” of rear lift with a small/medium load and the ability to run longer shocks would be so nice, all while keeping suspension geometry closer to factory at its static height. I should look into a GB for getting a custom run of springs made. I wonder who Toytec uses to manufacture their springs…
Anyone know the free length of an 890?
rickashay is offline   Reply With QuoteReply With Quote
Old 02-06-2023, 09:57 AM #328
Real Name: Patrick
Real Name: Patrick
I use this website as an OME spring reference: Cruiser Outfitters
Old 02-06-2023, 10:17 AM #329
Real Name: Evan
Real Name: Evan
Right at 3” or 23” hub to fender. My Nguyen Works single rear swing out and 35” spare added a little weight overall but not much. I am roughly 60 lbs over stock weight w/ tow hitch. I also have the rubber cone bumps removed, which cuts 1/4” from the static ride height. From what I remember, Toytec only offered the Superflex with 3.75” lift, and their medium/ light duty 3” lift coil with a shorter free hight and the rest of the offerings were made by OME. It’s been a while since that was the case though, so I’m a little fuzzy on it.
Old 02-06-2023, 02:06 PM #330
Romeo1's Avatar
Romeo1's Avatar
I agree completely. There is a bit of a gap between the 4runner offerings, and then jumping all the way up to a landcruiser Spring.
3rd , coil , gen , rear , spring
Rear Coil Spring Changeout Franky_Dabbs 3rd gen T4Rs 12 07-02-2020 08:23 PM
Rear Coil Spring Replacement SouthAl 4th Gen T4Rs 6 07-26-2016 12:24 PM
PLZ HELP!! Rear spring coil question.. mironkedz 3rd gen T4Rs 0 11-24-2010 12:04 AM
Rear Coil Spring Spacer alp 3rd gen T4Rs 19 10-16-2010 12:22 PM
which rear coil spring????? lexustech 3rd gen T4Rs 4 10-12-2007 06:35 PM
