Originally Posted by Baughb
I want to remove just the driver side rear seat in a '99 Limited.
The seat bottom came out just fine. The seat back has had its carpet cut at the joining seam of the rear cargo carpet.
What I can't find is how to remove just the single seat back and still keep the passenger side seat intact. The center bracket for the seats doesn't have a way to separate so that just one seat comes out... as far as I can tell. I'll tug on it more when I get a free day on Monday but, a link to a video or some assurance/tips/actual knowledge from someone with more experience would be great too.
Thank you
if you take a look at my old build thread and scroooolll way down 2nd last pic.
once you have the seat back off you should be able to unbolt the seat back from the hinges. yes the center hinge in one big hinge so you will always have that unless you modify it.
you can use a seam ripper (sewing thing) to separate the carpet pieces on the seat back/rear section.
be careful on the seat back it's only hardboard and the nasty white plastic connectors are stubborn mofo's.
https://www.toyota-4runner.org/2851263-post14.html
