Originally Posted by Lamer
I have a 170degF thermostat en route to install but I was curious if ya'll think 212 is too high for the OEM thermostat?
The dash guage won't move much until its nearly too late, so don't rely on that.
Yes, for the 3.4 with the jiggle valve installed pointing down to 6 o'clock, the engine should be at about 185-190.
Mine with 320K miles stays in that range even here in central texas' 100+ degree summers (8 hours of 100+) easily With the A/C on, it can even idle like that for over 1 hour. Towing gets it up to 195 in the same conditions.
So something is up on your unit.
Check/replace the radiator cap too, cheap insurance, go with Toyota OEM if you can.
Luck and enjoy the Runner. :Cowboy:
