Old 01-04-2020, 04:53 PM #1
RocksRunner RocksRunner is offline
RocksRunner is on a distinguished road
Climate control issue , unable to change the airflow
I have 99 Limited with the digital display unit. Originally when searched the web for the issue, I was thinking that it was the unit that was bad. However, I will say that all the buttons and control knobs work and I do see a response from the display. Meaning when I push the AC button it kicks on and the lights turn on, cold air comes out. When I turn the knobs the temperature and airflow increase or decrease accordingly.
Now here's the tricky part, when I select defrost or try changing the modes of airflow from (driver )high to (feet) low/ both I see the display change accordingly. But, there is no change in where the air is coming from. Is it possible there is a bad solenoid or control module that tells the vents to move accordingly?
On a side note i picked up a used climate control module from the local pick and pull. That unit barely works, just the back light.
RocksRunner is offline   Reply With QuoteReply With Quote
Old 01-04-2020, 05:54 PM #2
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Search this forum (better search option is in the stickies). You'll find Both someone who'll repair your unit for you and instructions on how to repair it yourself if you're handy with a soldering iron.
Best I can tell, it's simply due to cold-solders that break over time and it needs to be reflowed, but I paid the forum member to fix mine (very happy with that interaction).
Brian. is offline   Reply With QuoteReply With Quote
Old 01-04-2020, 09:04 PM #3
JRZEE2000TR4LTD's Avatar
JRZEE2000TR4LTD JRZEE2000TR4LTD is offline
Real Name: John
JRZEE2000TR4LTD will become famous soon enough JRZEE2000TR4LTD will become famous soon enough
Real Name: John
It's not the control. Either you have a bad servo motor or the the damper doors themselves are stuck. What vent is the air coming from right now?
SILVER 2000 4runner Limited TOTALED
WHITE/SILVER 1999 4runner Limited l Rear Locker l Tundra/890 coils | 5100 Bilsteins all around | Sonoran Steel Bumpstops l 199 mm Tundra brake upgrade | SCS Matte Gray Ray10 Rims | 275 70 17 BFG KO2 tires | LR UCAs | EIMKEITH panhard brackets | LED interior upgrade l Rear LED tailights l Pioneer AVH-X5700BHS Alpine Type "R" speakers NVX JAD800.4 Class D Amp Kenwood Under seat Subwoofer l Front window tint 20% l Weathertech window visors and floormats l OutGear Solutions Full Length roofrack l Morimoto 40" LED lightbar
JRZEE2000TR4LTD is offline   Reply With QuoteReply With Quote
Old 01-05-2020, 08:31 AM #4
That's kinda what I'm thinking due to all other buttons working with no issues. The air is coming out of both the upper and lower. Not really an issue but defrost doesn't come on.
I can't seem to pin down the location of the door or solenoid that controls the door/vent.
Old 01-05-2020, 10:05 AM #5
MaineRunna's Avatar
MaineRunna MaineRunna is offline
MaineRunna will become famous soon enough MaineRunna will become famous soon enough
MaineRunna's Avatar
It's called the mode door actuator or air outlet servo motor. It looks like it's on top of the heater box and the book time to change it is 5.3 hours, meaning your whole dash has to come out.
98 SR5 4X4 5spd, desert dune metallic, Toytech Eibach 3" lift, 1" body lift, RAD Rubber Designs splash guards, 4XInnovations bumpers, Doug Thorely Headers, Magna-flow converter, JBA muffler & tail pipe, RCI skid plate, SPC UCA's & rear LCA's, front sway bar links on rear, gen II rear links on front, Tundra brakes, '02 headlights, tail lights & sidemarkers, BFG 255/85R16 Mud Terrain T/A's 241,000 miles.
MaineRunna is offline   Reply With QuoteReply With Quote
Old 01-05-2020, 08:36 PM #6
Wow , thank you for the heads up.
airflow , change , control , display , unit
04 Limited Climate Control issue nicheel8 4th Gen T4Rs 6 10-21-2016 05:08 PM
2006 limited climate control issue JEL 4th Gen T4Rs 4 11-17-2015 09:59 PM
How to change climate control bulbs 2005 Sport terrihight 4th Gen T4Rs 3 09-27-2011 01:52 PM
Climate Control Issue smallfry 3rd gen T4Rs 1 08-01-2011 12:35 AM
Climate Control Issue After Kenwood DDX418 Install rtuck1 4th Gen T4Rs 11 05-22-2011 11:47 PM
