01-13-2020, 12:29 PM
#16
Little update here if anyone still cares, got mine fixed but had no actual broken wires. I do however have a bad rear wiper motor and, surprisingly, the window down function grounds on the wiper motor. Once i figured that out, i removed the bad wiper motor and just replaced the ground. works great now and i would not have expected that at all.
thanks again
@ brillo_76
for the wiring diagram
– 96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
01-13-2020, 07:27 PM
#17
thanks again
@ brillo_76
Do you have any pics for reference? My wiper and window started giving me issues after trying to remove the super frozen/stripped nut on the wiper stud and now neither work. I can hear the relay clicking and I'm thinking a wire issue, but I ripped into the bundle going from the tailgate to the body and have no broken wires. So I'm thinking it might be similar to your issue.
"Bettie" - 1998 4runner LTD E-Locker Evergreen Pearl 275K+, Alpine HU, Infinity Reference Speakers, Airraid MIT, B&M Cooler, Light Racing UCA, RCI skids, Bilstein Tundra 5100 and 4runner Eibach Coils in front/ Bilstein FJ 5100 and OME 890 rear, LC80 wheels wrapped with MT Baja ATZ 285/75/16, 99+ overhead console, 99+ center console, sound-deadening, Ditch lights
01-13-2020, 07:47 PM
#18
The wiper and window are interlocked - you can't operate the wiper with the window down and you can operate the window with the wiper on. There are limit detection switches, etc. that make sure this happens. You may have a problem in that part of the system instead of the boot wiring at the top.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
01-13-2020, 08:10 PM
#19
^this explained my issue, sorry i dont have pics.
I didnt care about the wiper so i just removed the busted one and left it out.
I tested the wires going into the wiper motor and found that if i grounded the bottom left(while looking at the connector, blue w/black or blue w/white) the window worked again in both directions so my issue is either the wiper dock sensor? or the wiper motor itself. Regardless, it works fine now with that wire grounded and no wiper.
–02 bmw 540i6
–19 Highlander SE
01-13-2020, 10:09 PM
#20
Interesting, good to know. Thanks for the info. I'll try and play around with it some more while I'm throwing parts at the problem.
01-26-2020, 01:27 PM
#21
Hi folks
Used this forum posting to locate my issues with rear hatch power (wires broken at loom, repaired with buttsplices and rewrapped)
I broke the grey grommet that assists holding the bootwrap at the body.
Had some leak issues in rear trunk during rain storm.
Looking for replacement part as I can't imagine it would be expensive- but having no luck Google or forum searching the name of the grey body grommet, or Toyota part number....
Any help appreciated. Thanks!
02-13-2024, 02:30 PM
#22
Hi ,I was wondering if someone could help me on this forum, i have a problem with my liftgate window rolling itself down , and it will not roll itself back up. Neither the dash switch or the key on the liftgate will get it to go up again, im assuming its a short wire somewhere, maybe from the ecu? so I read about hotwiring it with a small 12v battery. So long story short I have the panel off and located what I think is the plug for then motor and it has six wires, which ones do i have to apply 12v to to get it to roll up? I have pictures of it below. My goal is to get the window back up and leave the motor unplugged, I dont ever use the liftgate window anyways, any advice would be appreciated, tia
Gmail
02-15-2024, 04:10 PM
#23
Check the wiring bundle that goes from the body into the liftgate- they have a history of broken wires.
You will have to unwrap and then reconnect/repair whatever wire damage that you find. I found 4 broken wires in my bundle that made my window defogger inoperative -
1998 SR5 - 5 speed w/ 4.30 E-locker
My 1998 SR5 Build Thread
