Originally Posted by jetfan186
I am sorry if i am hijacking a post. I am trying to figure out how to post. I have brake backing plates all rusted out. Is there a easy fix.i was told necessary to pass inspection. Thanks
Sent from my SM-N960U using Tapatalk
Short answer: It can be fixed:
The bad news. There is no easy fix. You have to pull the axles out the 3rd member. Then press everything off the axle back to that plate. Put a new plate in then press everything back on.
I would change the wheel bearings while you have them off.
This will give you an idea how fun this is to do
https://m.youtube.com/watch?v=AVhSDnw2ugo
Build Thread:
https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer:
https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information:
https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
