Old 01-07-2020, 07:27 PM #1
What is your oil pressure at idle with a warmed up engine with hot oil?
For those of you with oil pressure gauges. Please post your oil pressure at idle with a engine that has its oil up to temp.
Old 01-08-2020, 10:52 AM #2
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Curious as well. Also in to see what kind of gauges people have.
Old 01-08-2020, 10:58 AM #3
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
Curious myself on what oil port, what thread pitch, what electric sending unit and gauge combo’s folks have.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 01-08-2020, 11:09 AM #4
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
this is adapter you will need.
Toyota to Aftermarket Oil Pressure Gauge Adapter
this is where you will want that adapter
FSM specs for oil pressure
I just have a test one
Engine Oil Pressure Test Kit
once I have verified the pressure I will remove it. you can leave this one on the truck and just tuck it over by the battery and drive around. then check pressure whenever you want.
Old 01-08-2020, 11:24 AM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Any one know what the threads are for this pressure gauge block port? I like to get a T so I can port in a A/M gauge or tester from time to time. Could make a decent mod and have a dash oil pressure gauge like years past..:-)
Old 01-08-2020, 11:27 AM #6
What did you do with the factory sending unit when you connected the aftermarket one in it’s place?
This is a 1/8” BSP thread T.
https://www.ebay.com/i/332974988369?...iABEgJv2PD_BwE
Better description on this one of it containing both NPT for aftermarket sender and BSP for OEM sender.
1/8" BSPT Oil Pressure Sensor Tee to NPT Adapter Turbo fits Lexus Toyota Mazda | eBay
The China seller add uses some of the same images as the US seller add.
Old 01-08-2020, 11:33 AM #7
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
like I posted above
1/8" National Pipe Thread to 1/8" British Standard Pipe
5vz has BSP and most aftermarket stuff in US is NPT
I have the yota shop one and it works fine. it's a bit tight in that spot but it does fit.
Old 01-08-2020, 12:27 PM #8
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Thanks @sleepydad and@ Dieselchessy. I am liking that threaded one as we don't have a lot of space in that area as sleepydad pointed out. :-)
I would have both the OEM one in and the A/M digital one in. I have no reason for a mechanical if I am going to place one in my console. I like that we can just put some thread tape on and nipple that off if need be as well. :-)
Old 01-08-2020, 01:46 PM #9
I ordered the adapter Tee. And will redo my install when it arrives.
Old 01-09-2020, 06:44 PM #10
Bump to the top. Anyone with an oil pressure gauge installed on the 3.4l?
Old 01-10-2020, 09:25 AM #11
Black798's Avatar
Black798 Black798 is offline
Real Name: Phoenix
Black798 is just really nice Black798 is just really nice Black798 is just really nice Black798 is just really nice
Black798's Avatar
Real Name: Phoenix
I have one. And to answer the OPs question at idle I see 4 to 6 lbs of pressure. Rubbing down the highway at 2500 rpm it's around 45 or 50 and max I've seen it was 80 at redline. My sensor is installed in the port that's lower down on the block than the factory pressure switch.
Coming from the world of small block Chevy's where they typically have 30 to 40 psi at idle the super low pressure freaked me out but the fsm specs 4 lbs as normal and the warning light comes on at 2lbs
98 Limited - Solid Axle Swapped,Turboed,And On 37s - Build
Transgo Shit Kit Writeup - Click Here
Black798 is offline   Reply With QuoteReply With Quote
Old 01-10-2020, 10:34 AM #12
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
This is for my 3rz, not what you need but maybe informative.
14 psi at hot idle RPM and 70 psi at 3,000 RPM.
These may not be exact as I bought a cheap gauge. I used the harbour freight cheapie oil pressure tester while replacing the sender due to dripping oil.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 09:43 AM #13
Thanks. How many miles are on the engine?
Old 01-11-2020, 10:30 AM #14
Black798's Avatar
Real Name: Phoenix
Black798's Avatar
Real Name: Phoenix
210k put the gauge on at 190k and haven't seen it change.
Old 01-11-2020, 10:43 AM #15
Black798,
Would you tell us what sensor/gauge you installed?
I see lots on the net but it seems to be $30 China stuff or a jump to $200 race stuff.
A little leery of the China stuff, afraid the sensor may spring a leak, and the sensors look big.
engine , idle , oil , pressure , temp
High Idle when warmed up Gerdo 3rd gen T4Rs 22 07-14-2015 08:57 PM
Rough idle when not warmed up 4runneracerunner Classic T4Rs 11 04-27-2014 09:46 PM
Engine Stalling when not warmed up tonyisme Classic T4Rs 6 10-16-2012 01:39 AM
Rough idle when warmed up whodini 3rd gen T4Rs 2 12-09-2010 09:57 AM
Rough/Jerky engine and bad accel when not 100% warmed up fishrod Problems & Warranty Issues 5 03-17-2009 09:01 PM
