Old 01-11-2020, 12:52 PM #16
Black798's Avatar
Black798 Black798 is offline
Real Name: Phoenix
Black798 is just really nice Black798 is just really nice Black798 is just really nice Black798 is just really nice
Black798's Avatar
Real Name: Phoenix
Originally Posted by Dieselchessy View Post
Black798,
Would you tell us what sensor/gauge you installed?
I see lots on the net but it seems to be $30 China stuff or a jump to $200 race stuff.
A little leery of the China stuff, afraid the sensor may spring a leak, and the sensors look big.
My gauge is a glowshift. I have 4 gauges from them and have yet to have an issue.
GlowShift Tinted 7 Color Oil Pressure Gauge
And a picture of where I installed the sensor itself, circled in white. Stock sensor is up on the right hand side, I did the because 1 I didnt want to mess with a t fitting, and 2 it was easier to access this port. I cant say for certain since I stole the adapter fitting out of my harbor freight oil pressure tester kit but I fairly certain this port was a npt thread and not a bpt.
What is your oil pressure at idle with a warmed up engine with hot oil?-screenshot_20200111-094600-jpg
98 Limited - Solid Axle Swapped,Turboed,And On 37s - Build
Transgo Shit Kit Writeup - Click Here
Black798 is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 01:58 PM #17
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
The block should be 1/8-28 bps and sensor is listed as 1/8-27 npt.
An adapter of that type is listed earlier in this thread from Yota shop.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 06:02 PM #18
Black798,
I bought an innova mechanical and used the copper tubing for the 4Runner.
On the CJ I put a Stewart-Warner mechanical gauge in and used copper tubing. No leaks in 10 years.
Old 01-11-2020, 08:36 PM #19
Also my adapter came in today. So Monday or Tuesday I’ll remove my NTP Tee and install the correct adapter.
I remove the Alternator to get more access
Old 01-11-2020, 11:20 PM #20
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
From a similar thread a few years back:
Originally Posted by 02SE View Post
The spec I have for the 5VZ-FE is 4.3 psi at idle. That's on an engine at operating temperature, with oil that is also at full operating temperature.
I should add that's with a Toyota recommended 5w30 oil.
02SE is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 02:15 PM #21
Here is my old NTP components which did work. And the correct British pipe adapter.
Old 01-13-2020, 02:38 PM #22
NPT and BSP are very close, and you can sometimes thread in an NPT sensor to a BSP port and have it not leak. It is better to use the adapter though...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-13-2020, 02:59 PM #23
I forgot to show my gauge. It’s a Cheapo and temporary. I plan on getting a gauge pod for the A pillar or mount it where the ashtray was.
Old 01-13-2020, 10:09 PM #24
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I have the same gauage.. lol. How long is that copper line? As mine didn't come in yet.
Old 01-13-2020, 10:42 PM #25
It’s 6 foot I think. It should be plenty long to get to the A piller or center dash. I’m going to look for a Stewart Warner Gauge for the install. The above was a cheapo to see what I had for pressure. It can stay in the engine bay for now.
Old 01-14-2020, 06:21 PM #26
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Ok yes 6 ft should be fine. The only problem with a pillar install for me would be I like the hang on handles. I really dont use it but I used to them being there.
I am thinking voltage gauge and atm fluid temp gauge. We pretty much have everything else except fuel pressure at the rail would be nice to have but not needed.
The add ins in the 80s used to go down below the radio. I had an 85 sr5 that had ac and those two gauges added on in the states by the dealer. Oil pressure and voltage was in front of the 5 speed and transfer and below the radio console.
Old 01-16-2020, 05:39 PM #27
I’m going to the Napa I have an account with and see if they still stock the Stewart Stevens gauge I put in the CJ7. If they do I’ll proceed with mounting it where the ash tray was and buy the dual gauge A pillar mount in oak and see how close it is to mine. I think it’s the lighter color.
My oil pressure relief must be set around 63psi. I can rev the engine and see 75psi for a second or so and then the pressure drops to around 62psi when the oil is up to temp.
Old 02-10-2020, 09:58 PM #28
Valvetrain32 Valvetrain32 is offline
Valvetrain32 is on a distinguished road
Originally Posted by Black798 View Post
I have one. And to answer the OPs question at idle I see 4 to 6 lbs of pressure. Rubbing down the highway at 2500 rpm it's around 45 or 50 and max I've seen it was 80 at redline. My sensor is installed in the port that's lower down on the block than the factory pressure switch.
Coming from the world of small block Chevy's where they typically have 30 to 40 psi at idle the super low pressure freaked me out but the fsm specs 4 lbs as normal and the warning light comes on at 2lbs
Same thing. That's one thing I liked about my Yukon, oil pressure gauge and voltage reading.
Valvetrain32 is offline   Reply With QuoteReply With Quote
Old 04-04-2020, 04:05 AM #29
On my way home from work last evening I stopped to jumpstart my girls sisters Kia.
Since my gauge is under hood yet after 15 miles of driving and at least 10min of idle I still had 8psi.
I believe I have the most oil pressure of anyone that answered my question.
Thanks to all that participated.
Gene
Old 04-04-2020, 04:39 PM #30
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Gene
I never hooked mine up yet. As the adapter I got was wrong. I need to get that adapter one of these days.
engine , idle , oil , pressure , temp
High Idle when warmed up Gerdo 3rd gen T4Rs 22 07-14-2015 08:57 PM
Rough idle when not warmed up 4runneracerunner Classic T4Rs 11 04-27-2014 09:46 PM
Engine Stalling when not warmed up tonyisme Classic T4Rs 6 10-16-2012 01:39 AM
Rough idle when warmed up whodini 3rd gen T4Rs 2 12-09-2010 09:57 AM
Rough/Jerky engine and bad accel when not 100% warmed up fishrod Problems & Warranty Issues 5 03-17-2009 09:01 PM
