01-30-2014, 04:17 PM
Advise on Dual Battery Tray
Had everything ordered and ready, then found out Columbia Overland's dual battery tray can no longer be ordered...They do make a pretty awesome tray and the price is good..Anybody any advise? Thanks in advance..
01-30-2014, 04:25 PM
Banned
Banned
I haven't looked into this too much, but will be doing it down the road. Hope somebody knows where to get one. You could always build your own.
01-30-2014, 04:34 PM
2002 SR5 4x4- Resurrection in Process
Originally Posted by t4r4life
i like how my nipples are all smooth and pointy all six of them, sometimes i rub them when they get dirty
01-30-2014, 04:35 PM
Seriously? I was planning to use that tray for mine. I'll be watching to see what you find. It's a shame as it was a good looking option.
17 Jayco Precept 35UP Motorhome - 18 Jeep Wrangler JLU - current
16 4Runner TEP KDSS - 15 4Runner Trail KDSS 4x4 - 06 4Runner V8 4x4 - ALL SOLD
97 4Runner Ltd. 4x4 - SOLD - http://www.toyota-4runner.org/3rd-ge...d-project.html
01-30-2014, 10:02 PM
Real Name: Throws like a girl
I'm using a ruff stuff box-
Battery Boxes - RuffStuff Specialties
The box is great- it's the fender skirt that's gonna need some reinforcing. Two batteries are heavy + too much rocks. I'll be addressing that issue in the spring.
That bolt w/fender washer is one of the 4 holding the box on, the other ones are through the battery spot (tray?, flat metal area?) and not the skirt.
A Blue Sea 7622 sits in that empty space where the coolant reservoir was.
The coolant reservoir is now a large bike bottle in a bike bottle cage that's bolted to the side of the air box.
Anyways...
'96 4Runner SR5, assorted baubles and doodads. Stuff happened to it. Stuff is still happening to it. Okay, now the stuff is just getting ridiculous.
'99 4Runner SR5 Highlander, manual w/locker. Stuff is starting to happen to this one too...too much stuff! Too much stuff!!
http://www.yotatech.com/f200/habaner...thread-201751/
Originally Posted by PWD4R
I know this is a weird ass question but do you shave your legs or something?
01-30-2014, 10:16 PM
I'm actually in the process right now of doing this. Just bought the T-Max Battery Controller, and 2 Yellow tops. I was planning on buying one of these
Optima D34 Battery Box Yellow Red Blue Top Custom Offroad | eBay
And mounting it somehow to the passenger side where that void is. But after seeing the Ruff Stuff one I want to see if I can get that fit in the stock location.
Giant Motosports
01-30-2014, 10:29 PM
I looked up the Columbia overland dual tray and they provide a relocation mount for the radiator overflow tank. They are for Odyssey batteries and not Optimas so I don't think the links we provided will help the OP.
http://www.columbiaoverland.com/prod...l-battery-tray
戦争イーグル
Cory J
Wheel converter,
01-30-2014, 10:45 PM
That reservoir location on the overland box wouldn't work well with checking the oil.....
aluminum, cool.
01-31-2014, 07:45 PM
Thanks everybody, my battery of choice is odyssey or diehard platinum. So this limit my choice of battery tray to almost none..bad luck..
01-31-2014, 08:16 PM
I've got a diehard platinum G35 in the stock location. Planned to use the Columbia bracket for a second but am now thinking maybe I could fit a single battery mount somewhere else. Will keep watching for what you come up with.
01-31-2014, 09:31 PM
my battery of choice is odyssey or diehard platinum. ..
Which size? 1400 Odyssey? What group size Diehard?
I want to build one just to see if I could make something nice and worth sharing.
1989 FJ62 5.3 Chevy, FZJ80 Axles, 4.88's with ARB.
2000 2wd runner, 4 cylinders, yes it IS slow.
1999 4WD SR5 Desert Dune 3.4 351K and counting.
2000 4WD sport 3.4 Elocker <--My son's but I still end up paying.
2001 2WD SR5 3.4 <-- My daughter's...see preceding line.
02-03-2014, 03:02 AM
DieHard Platinum Group Size 35 Model# 51035. It is the same as the odyssey, save yourself some money.
02-03-2014, 03:08 AM
Very Curious to see what people come up with here, I've thought about moving my secondary battery from the cargo area to the giant void where the ABS pump is (No ABS on mine)
'97 3RZ 5 Speed "FrankenRunner" ( Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - ( Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
