Old 01-10-2020, 07:02 AM #16
tvpierce's Avatar
tvpierce tvpierce is offline
tvpierce will become famous soon enough
tvpierce's Avatar
Originally Posted by cgalloni View Post
Like mentioned before the valve gaskets were replaced at 126k doubt they broke again but you never know. I was reading in another forum that it could be the shaft seal and the torque converter seal but if that is the case that is going to be expensive.
It's common for the bolts securing the valve covers to be loose. Check and re-torque them if necessary. It's free and easy. Mine were only finger-tight when I had a seaping valve cover gasket.
Do you have a torque wrench?
tvpierce is offline   Reply With QuoteReply With Quote
Old 01-10-2020, 02:27 PM #17
cgalloni cgalloni is offline
cgalloni is on a distinguished road
Well guys, my father took the truck to my mechanic today. He says that I have to wash the truck below to have a clearer picture but he doesn't think is the transmission. He checked the fluid and the fluid its fine. After he looked at it a bit more it seems the valve cover is broken after it was tighten too much by the previous owner ( i imagine it was when they replaced the gasket. My father took the truck there and the mechanic says that is cracked and that i have to replace the cover and new seal Below is a pic. What do you guys think ?
Tranny fluid or coolant-photo-2020-01-10-09-21-39-jpg
cgalloni is offline   Reply With QuoteReply With Quote
Old 01-10-2020, 03:43 PM #18
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I don't see a crack or damage to the valve cover anywhere in that photo
Old 01-10-2020, 04:19 PM #19
Its actually cracked under the bolt. Really hard to take a pic from other angles. but if you see below the bolt is has oil all over it. Well according to the mechanic that is where the leak is coming from!
Old 01-10-2020, 06:40 PM #20
Real Name: Patrick
Real Name: Patrick
I still don't see it. Can you highlight it in paint and repost?
It sounds to me like your mechanic is grasping for straws here. There looks to be a lot of oil leaking from the opposite end of the valve cover from the oil fill cap. My money is still on valve cover gaskets/cam plugs. The person that did the valve cover gasket probably didn't do the half moons or cam plug correctly.
Old 01-10-2020, 10:14 PM #21
I just look at it myself and you can’t see in the picture but it starts right where the circle is also I think Is leaking from the back where cam housing plug is
Tranny fluid or coolant-924a468b-5932-4560-b291-f090c4e28528-jpg
Old 01-10-2020, 10:35 PM #22
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I believe there is a misprint in the FSM and it says ft/lbs instead of inch pounds for the torque of the valve pan gaskets bolts.
The cam shaft half moons and valve pan gaskets are notorious for seeping and if whoever changed them didn't know enough to not overtighten the valve pan they probably didn't do the cam seals like bad luck suggested.
Looks like you found your leak as I didn't think it was the transmission or power steering. ;)
Old 01-10-2020, 10:49 PM #23
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
when they pull the valve covers don't for get to reseal the half moons in the front and back.
plcfcng is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 12:34 AM #24
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Originally Posted by aontkos View Post
My money is on leaking valve cover gaskets/half moons/cam plugs. The color of the fluid on your finger looks like fresh motor oil.
Just because they were replaced recently does not mean they were replaced correctly. It might even be as simple as re-torquing the valve cover bolts.
As others have indicated, several potential sources for the leak but sure looks like valve cover gaskets to me as well.
Sorry guys.....missed the 2nd page of responses when I added these comments.
Didn’t see comment about the cracked valve cover, makes sense.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 07:56 PM #25
BostonJon BostonJon is offline
BostonJon will become famous soon enough
I think the misprint on torque values in the FSM is the rear differential studs. I think the valve cover numbers are accurate.
BostonJon is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 09:14 PM #26
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I stand corrected. I checked both 2001 FSM and 1997 FSM and the Torque is 6 N m or 53 in lbf so no reason on earth to overtighten and crank the cover. I thought I read somewhere there was a misprint in a FSM on the covers.
So the people cracking these covers by over tightening them really shouldn't be turning wrenches. :/
Old 01-11-2020, 11:32 PM #27
Thanks everybody. Bought the replacement valve cover new gaskets and cam housing plugs as well I will have them replaced as soon as I get the parts. Thanks to everyone
Old 01-14-2020, 04:05 PM #28
Real Name: Patrick
Real Name: Patrick
I still don't see this valve cover crack you're talking about. To clarify I'm looking for a crack in the valve cover in the photos. Not a crack in the valve cover gasket.
Old 01-14-2020, 04:17 PM #29
The crack runs from the red circle to just above the bolt in the photo. Most of the crack is hidden by the oil cap.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-14-2020, 05:26 PM #30
Real Name: Patrick
Real Name: Patrick
I give up. Thanks for trying
fluid , oil , purchased , recently , transmission
New Radiator with Coolant Flush? Power Steering Fluid Flush, and Brake Fluid Flush? jdotlim 4th Gen T4Rs 4 09-17-2017 07:52 PM
tranny fluid Q... easportz 4th Gen T4Rs 1 03-15-2015 03:19 PM
Coolant fluid question LUVDA4RUNNER 4th Gen T4Rs 3 12-27-2013 01:12 AM
Tranny fluid change...which fluid? wm69 3rd gen T4Rs 3 02-12-2008 01:11 AM
Coolant in my Tranny...All of it! Ebbsnflows 3rd gen T4Rs 1 05-29-2007 10:20 AM
