Old 01-12-2020, 12:00 PM #31
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C has a spectacular aura about Ed_C has a spectacular aura about Ed_C has a spectacular aura about
Ed_C's Avatar
Real Name: Ed
Aren't those discussed headlight reflectors constructed of metal instead of composites like our headlights, wonder if they can refinish our composite lights? I'd rather have my OEMs replated instead of going aftermarket, they're constructed so much better.
Old 01-12-2020, 12:17 PM #32
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is just really nice TonyB66 is just really nice TonyB66 is just really nice TonyB66 is just really nice
TonyB66's Avatar
I believe so, but I seem to recall in other discussions I found, that Oregon company has done composite ones too. I'm tempted to look in a salvage yard for a set to try. The price is appealing.
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 05:03 PM #33
brillo_76's Avatar
brillo_76 brillo_76 is online now
Real Name: Jon
brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light
brillo_76's Avatar
Real Name: Jon
Originally Posted by Dieselchessy View Post
I use the one from Super Bright LED's. Its a pair. I only use one on the passenger side double sided taped to the Air box.
Headlight Load Resistor Kit - H4 LED Headlight Bulbs | Super Bright LEDs
Its pretty cheaply made and just contains what looks like 2 of the common 6 ohm gold anodized load resistors. There is very likely bettor options.
https://www.amazon.com/Zento-Deals-P...27705785&psc=1
I failed to mention above the pros and cons of the load resistors themselves.
Again per my opinion.
Pros: They allow the high beam indicator to work. Other drivers probably appreciate that. They are plug and play.
Cons: You have to add a component. You have to find a mounting location. They get pretty hot.
Those are what I am testing now. I use both of them. I am seeing how long they work they hold up as I was only after brighter light. I was tired of being blinded with how dim my 98 lights were. Now I can see the road when it rains. And the signs reflect back for quite a ways out. I an no longer blinded nor do I blind anyone with the low beams.
Plus by keeping my halogens bulbs in my glove box. I can switch back as some of the states have really strict laws on how bright your headlights can be .
I like stock. I am not into modifying vehicles like crazy. The most I would do would be change to a 99+ headlight. However, I doubt I ever change them.
As these solved my problem. I am just curious how long they last.
@Dieselchessy how hot are your load resistors getting?
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
brillo_76 is online now   Reply With QuoteReply With Quote
Old 01-12-2020, 09:02 PM #34
19963.4lsr5 19963.4lsr5 is online now
19963.4lsr5 has a spectacular aura about 19963.4lsr5 has a spectacular aura about 19963.4lsr5 has a spectacular aura about
Do the LED bulbs get hot enough to melt the ice and snow off the lenses? I know a few in the past went back to halogens because of this.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 01-12-2020, 09:21 PM #35
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I can let you know if we get enough ice and snow ..
I believe they melted frost. However, I need more winter weather to answer this for you.
Old 01-13-2020, 12:00 AM #36
HiLife HiLife is offline
HiLife will become famous soon enough
I like the ones Brilliant was running. Kinda taking a risk, as the part is coming from Russia. Also the front radiator support needs to be cleared to fit the headlights.
Maybe we could ask the vendor for a bulk buy? Ha
Old 01-13-2020, 02:52 AM #37
Dieselchessy Dieselchessy is offline
Dieselchessy will become famous soon enough Dieselchessy will become famous soon enough
Donít have an actual temp. They get hot enough you wouldnít want to hold onto them too long, but not so hot theyíd burn you.
No idea if they melt freezing rain, but I just drove home in a blizzard and they did great. Iíll have to put my hand on the lens some time and see if itís warm.
Mine have lasted well over a year. I carry 2 halogen bulbs in the foam lined box the LEDís came in, just in case. Still waiting.... I guess if they freeze up in freezing rain I could toss in the halogens.
Honestly I kind of expect the resistor to fail first. But itís not critical to operation and I have a spare.
I was buying $45 halogens every year and a half or so. These LEDís are not much more and if they only lasted a year Iíd be happy.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 11:30 AM #38
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
We might have to put the resister under the Light housing that way the heat will melt the ice off your headlight lens..
Old 01-16-2020, 08:35 AM #39
JZiggy's Avatar
JZiggy JZiggy is online now
JZiggy is a jewel in the rough JZiggy is a jewel in the rough JZiggy is a jewel in the rough JZiggy is a jewel in the rough
JZiggy's Avatar
Originally Posted by gamefreakgc View Post
I swapped my 98 housings that were dirty with a cracked lens to the newer, brighter 99-02 style housings, $40 each from Rockauto.com, TYC brand. Made a substantial difference.
Last month I put in a relay system so I can safely run higher wattage lightbulbs for $18: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1.
Then I put in 100W/80W bulbs (stock is 55W/50W) for $4 a bulb: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Let's just say I don't worry about dim headlights anymore. Plus cheap replacements if they burn out.
So I tried this upgrade and it's been working out well so far. That relay is pretty decent and hooked up without issue. The Hella bulbs are definitely brighter and are the same color as normal. The high beams are really powerful as well.
I seem to have lost my high beam indicator. That's not surprising since there's a relay harness in front of the headlight plugs now. Any ideas how to get the indicator back?
"Check out that four by four, that thing is hot!" - Marty McFly
1999 4Runner 3RZ/W59/4WD Turboencabulator
1st gen 4Runner crap for sale!!
JZiggy is online now   Reply With QuoteReply With Quote
Old 01-16-2020, 11:40 AM #40
TonyB66's Avatar
TonyB66's Avatar
Glad it is working well for you, minus the hi-beam indicator...
As you might have seen, the seller commented on such:
Q: will these still trigger the high beam indicator?
A: This will vary from vehicle to vehicle. Some vehicles' dash light indicator lights up only when a good amount of power is being drawn through the original high beam circuit. Since this wiring harness omits the factory circuit, and only uses 150mA to trigger the relay through the factory circuits, it may cause the vehicle to fail on noticing the high beams being on. Hope this helps.
If you have not gone with LED dash bulbs yet, I wonder if doing so, at least for that bulb, would do-the-trick (they don't need to see as much power to function). Just a thought...
It seems that some harness options incorporate the high beam indicator lamp. Scroll down here a bit.
Brighter Head Lights
Old 01-16-2020, 11:45 AM #41
Reinout's Avatar
Reinout Reinout is online now
Real Name: Reinout
Reinout will become famous soon enough
Reinout's Avatar
Real Name: Reinout
If anyone is interested I have someone somewhat locally to me selling 2002 glass headlights for $40 on offerup.
Also someone else selling HID retrofit headlights on offerup for $450.
Headlights off of 2002 4runner for Sale in Graham, WA - OfferUp
96-02 4Runner HID Headlights for Sale in Seattle, WA - OfferUp
1997 4Runner SR5- ~370k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 142k Miles - Automatic - Brake Controller.
2011 VW JSW TDI- 104k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
Reinout is online now   Reply With QuoteReply With Quote
Old 01-16-2020, 11:49 AM #42
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy will become famous soon enough
I upgraded to the 99+ headlights and noticed a huge difference even with used units, I might try the LED bulbs that Brillo is using before going to a projector retrofit
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 11:57 AM #43
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You can search the forum for wiring diagram of the headlights put a replacement put a resistor were the low beam bulb will go something like 100 ohm 5w. So when they are high beam current can flow back through and light the indicator.
Old 01-16-2020, 12:37 PM #44
Tampa_T4R Tampa_T4R is offline
Real Name: Doug
Tampa_T4R is on a distinguished road
Real Name: Doug
Are the 96-98 housings inside(the reflective part) the same as the 99-02? I want to do the retrofit, but I would rather just keep my OEM housings and buy the clear lenses from rock auto. I just can't tell if the 96-98 have the same nice reflective part as 99+, and can't seem to find a picture online of just the housing without the impossible to see through lens.
Tampa_T4R is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 01:00 PM #45
Ed_C's Avatar
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
Don't have links to the images, but the inner reflectors are different.
advance , headlights , options , pixel , units
DIY: TE Headlights, Black Headlights (BHLM) Jesse1983 5th gen T4Rs 39 02-14-2019 09:29 AM
2005 4Runner headlights to 2006 headlights bizkd 4th Gen T4Rs 1 10-06-2015 08:03 AM
GX470 headlights=4Runner headlights? ssmumich00 Engines / Suspension / Wheels / Tires / Audio / Accessories 17 10-18-2013 06:54 PM
Anyone have these projector headlights or crystal clear headlights?? afdj006 3rd gen T4Rs 12 10-30-2007 12:16 AM
