Old 01-13-2020, 07:20 PM #16
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
I'm going to throw a wrench in the cogs here.
I have an over-bored throttle body with a custom butterfly valve (brass plate) that is seamless with the body housing. There is no gap between the valve and the housing since it's CNC machined to tight tolerances. On top of that, I have some non-air assist injectors with large o-rings that appear to completely block the air-assist holes that are in the intake manifold. My 4Runner idles fine (except when the engine gets hot & idles for 5 min or so then it stumbles a little down to 550 RPMs).
So that means my valve is airtight as can be and there's no airflow from the throttle body to the injectors. My idle is the same from when before I modded all that so theoretically if you follow the logic my engine should stall, but it doesn't. Although my IAC is clean and does operate, maybe that's the part that fails when dirty and affects idle & stalling. I have a 98 though.
326WHP 347TQ
Old 01-13-2020, 07:42 PM #17
The '96-'00 throttle bodies should close completely when the throttle is released (there is some spec in the FSM, I'm sure). The IAC should supply sufficient air for idling the engine.
The amount of air that passes through the air assist injectors must be fairly small...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-13-2020, 10:44 PM #18
STI_MECE's Avatar
STI_MECE STI_MECE is offline
STI_MECE will become famous soon enough
STI_MECE's Avatar
It's supposed to be open just slightly. I can't remember if it's a percentage or a physical distance. I remember looking through mine during my swap process and you could see the light coming through the edge of plate.
Otherwise your engine gets no air and stalls completely but you know that lol I think you were just being short with words, but for others who may derail it, it is supposed to be open a small smalllllll amount
Sent from my Pixel 3 XL using Tapatalk
2000 SR5 4x2 Resto/Maintenance
STI_MECE is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 01:38 AM #19
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
It depends what throttle body you're talking about. The 96-00 throttle plate closes all the way. Yes, there might be tiny slivers of space on the sides you can see light coming through but that's not where the engine is truly getting the air it needs when idling. The IAC valve is providing the engine the air it needs.
Now, if you're talking about the 01 and 02 throttle bodies, those throttle plates don't close all the way because the engine is using the air traveling through the throttle body bore to keep the engine running.
Old 01-14-2020, 01:19 PM #20
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Originally Posted by mtbtim View Post
Another thing I'm wondering about now with this 01 and 02 throttle body is could you throw off the calibration of the throttle plate since it's partially a DBW system? I remember watching a video about cleaning a throttle body and IAC and the guy mentioned he didn't think it would be smart to manually move the throttle place on a fully electronic throttle body because it could mess up the calibration. I'm just trying to understand why some guys have had a high idle after cleaning this newer style throttle body.
I went back & forth for a little while about the best way to clean my throttle body because of the same info you mentioned. I ended up cleaning it the same way as it would be done on 96-00 by manually moving the throttle plate. I still don't have confirmation if this is correct or not but haven't noticed any issues for the last 80k. Been doing it this way everytime I clean the MAF and change the spark plugs. The only time I've seen a temporary high idle was after cleaning the throttle body on my friends 99 but it resolved after several minutes.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 01-22-2020, 03:39 AM #21
negusm negusm is offline
negusm will become famous soon enough
Not sure if it helps at all, but I posted a bit of a tear down of my old TB on my 2002 in this thread:
The Exclusive 22030-62020 Club! Throttle Body Tear Down.
It has pics of the innards.
If you clean the TB, just take that little metal plate off and clean inside too (see pictures in that thread). Either way, there isn't much you can mess up...but you do need to get those little airways open.
Also, I measured the resistances on the brandy new TB. The Pedal Position Sensor on the new one was fairly close to the old one, for both closed and open.
The TPS side...has some obvious issues. Numbers were whacked on the old one compared to the new one. I want to recheck my measurements before posting.
-Mike
2002 4Runner 4WD SR5 - Original Owner
negusm is offline   Reply With QuoteReply With Quote
Old 12-21-2020, 11:23 PM #22
ahoss4Runner2002 ahoss4Runner2002 is offline
ahoss4Runner2002 is on a distinguished road
Hi guys,
I hope this posts find you. I cleaned the throttle body on 20024runner SR5 , and now I am getting P0304 Cylinder 4 misfiring, idle RPM low, car vibrate while driving Could it be due to those 6 holes getting clogged up, and should I open the small compartment above the 6 holes and clean them out? Also, I just reused the same metal gasket, could it be due to gasket there?
I appreciate if someone can guide me to get over this.
ahoss4Runner2002 is offline   Reply With QuoteReply With Quote
Old 12-22-2020, 10:40 AM #23
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Originally Posted by ahoss4Runner2002 View Post
...I just reused the same metal gasket, could it be due to gasket there?
Isn't the metal gasket a crush type? I believe so, a new one is needed.
Old 12-22-2020, 10:56 AM #24
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Hi guys, reused the same metal gasket, could it be due to gasket there?...
FSM indicates one time use TB gasket, reusing a crap shoot, has been done though.
air , bypass , hose , models , throttle
High Idle After Cleaning Throttle Body 2001-2002 D Farms 3rd gen T4Rs 10 03-09-2020 02:14 PM
2001 - Finally lost all power --Used throttle body? duke808 3rd gen T4Rs 24 10-25-2019 02:15 AM
2002 6cyl. 175k Vacuum leak, Throttle Body throttle lever? Hollywood1 3rd gen T4Rs 3 12-29-2018 06:25 PM
Throttle Body Cleaning - 2001 4runner - **PICTURES** ramonortiz55 3rd gen T4Rs 3 04-05-2017 01:31 PM
2002 Throttle Body? wvjeepers 3rd gen T4Rs 12 03-31-2014 11:07 PM
