Old 01-10-2020, 09:10 PM #1
MarkBlack's Avatar
MarkBlack MarkBlack is offline
Real Name: 1997 4RUNNER
MarkBlack is on a distinguished road
MarkBlack's Avatar
Issues with Duralast Fuel filter?
So I decided to replace my fuel filter, and I grabbed the Duralast Fuel Filter FF692DL from autozone for $20. It leaked like crazy! So I swapped it out for another one and had the exact same issue! Today I went to toyota and grabbed the OEM for $50.
Has anyone else had this issue? Are Duralast products just trash?
MarkBlack is offline   Reply With QuoteReply With Quote
Old 01-10-2020, 10:45 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light brillo_76 is a glorious beacon of light
brillo_76's Avatar
Real Name: Jon
I only used OEM fuel filters so I cant say much about the A/M filters. However, this dosent surprise me at all as sadly most of the A/M parts are junk.
1997 4X4 V6 5 Speed Sr5 4 Runner (97 5 speed )
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
Old 01-10-2020, 10:51 PM #3
gsb77 gsb77 is offline
gsb77 is on a distinguished road
I avoid AutoZone unless it is an emergency situation.
gsb77 is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 12:14 AM #4
MarkBlack's Avatar
MarkBlack's Avatar
I will only be buying OEM parts from now on! Thanks for the imput
Old 01-11-2020, 10:03 PM #5
3bears 3bears is offline
Real Name: Joshua 3 Bears
3bears has a spectacular aura about 3bears has a spectacular aura about 3bears has a spectacular aura about
Ive used bosch and mann in the past with no issues. However current one and spare on shelf are Toyota.
there are some parts I think are safe to use as aftermarket.
However...through some of the online dealers and if the order big enough to pay for free shipping, Toyota filters can be very cost effective.
Saddly… I moved to Alaska a year ago and the boys I used to use wont do free shipping. The local dealer will only price match to other Alaska dealers.
2000 SR-5 V6 Auto . Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, Talls, KYB, Airlift 1000, DRL delete, Big 3 wire, full rack, TBU, Swapped in Elocker, some LEDs, PIAA headlights, , Amsoil
Old 01-11-2020, 10:12 PM #6
RunningForNow RunningForNow is offline
RunningForNow is on a distinguished road
I replaced mine about a year ago, and I believe itís made by Mann. When I replaced it, it started leaking, and I had to loosen the nut and re-tighten, as I was stupid and the nipple didnít line up quite correctly. After that, I havenít had any issues.
I would check and make sure the nipples on both ends are lined up correctly before you tighten the nuts.
RunningForNow is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 12:28 AM #7
Dieselchessy Dieselchessy is offline
Dieselchessy has a spectacular aura about Dieselchessy has a spectacular aura about
They generally come with copper crush cone type washers. Iíve had to use them on older rigs where the fuel line flare was pretty worn from years of use.
But generally steel flare to steel cone works fine.
This doesnít seem to be an aftermarket only problem as far as Iíve seen.
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
Dieselchessy is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 05:18 AM #8
TWJLee TWJLee is offline
TWJLee is on a distinguished road
Dunno about duralast but sounds like It is wise to avoid.
I recently bought a Beck Arnley from advance for around $30 . Mistakenly thought it was going to be better Quality...opened it up and saw made in China.
Took it back ....for an oem 32$ when I looked it up.
Some parts (most for these) should stick with oem if possible and shop around
TWJLee is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 12:27 PM #9
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe has a spectacular aura about Kanoe has a spectacular aura about Kanoe has a spectacular aura about
Kanoe's Avatar
You are not the first person to post about this. Others in the past have had trouble with leaking aftermarket filters and eventually put OEM in. I'm not going to search for past threads but there have been some before.
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
-2001 Echo (tbd if can be resurrected)
Kanoe is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 07:50 PM #10
Project_4Burner Project_4Burner is offline
Project_4Burner is on a distinguished road
I work at AutoZone and can honestly say most of the parts are 50/50 on the quality, either they're great and work fine, or they're absolute trash. I'll actually be returning my dualist fuel filter tomorrow but for a completely different reason. Not to steal the thunder of this thread, but has anyone else has a problem even FINDING the fuel filter? I first looked where everyone else says it is to be, under the drivers door along the frame, nope. I went even further and actually followed the fuel lines from the tank to the engine and still didn't find it. Could the previous owner possibly have bypassed it somehow?
Project_4Burner is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 09:18 PM #11
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
Judging by your username I'm gonna assume you've got a 4 cylinder. If so, it's hiding underneath the intake manifold bolted the the side of the motor. Grab a flashlight and look into the driver's side wheel well and past the starter, it's right there. Terrible spot to get to, I personally wouldn't recommend replacing it unless you're having problems since it's such a pain.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 11:18 PM #12
HiLife HiLife is offline
HiLife will become famous soon enough HiLife will become famous soon enough
I've read on this forum the problems other members had with aftermarket fuel filters leaking at the fittings time and time again. When it came time to replace mines it was OEM toyota fuel filter only. No issues after install on 2 occasions now.
Old 01-12-2020, 11:39 PM #13
Preciate the input! Thanks!
Old 01-13-2020, 12:22 AM #14
wcjeep's Avatar
wcjeep wcjeep is offline
wcjeep will become famous soon enough wcjeep will become famous soon enough
wcjeep's Avatar
I use Napa Gold or OEM for any of my vehicles.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
wcjeep is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 04:36 AM #15
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
I got a Bosch filter for my 2001 and it came with a small sealing disk for the in and out. Tried to figure out how to hold them in place while i inserted the lines. I ended up using some heavy axle grease to hold them in place. I tried to put it on with out the sealing disk I could not get them to stop leaking.
plcfcng is offline   Reply With QuoteReply With Quote
duralast , filter , fuel , grabbed , issue
Fuel leak stops. Now have a blue liquid on outside of fuel filter. Hard start getting 3rdgen_4runner 3rd gen T4Rs 2 09-05-2017 10:23 AM
Repeated fuel filter clog, failing fuel pump, or ? hour 3rd gen T4Rs 74 10-09-2016 12:58 PM
If I ever strip the nuts that screws the fuel lines onto fuel filter trdrun 3rd gen T4Rs 20 06-25-2013 04:01 AM
FS: 96-01 Fuel Filter, Oil Filter, & Spark Plugs Package: $30 DudeMan For Sale: T4R Items 2 06-05-2013 01:45 PM
Fuel Pump Filter / Sock - Inline Filter 86SupraMKII 3rd gen T4Rs 1 08-15-2012 08:17 AM
