01-10-2020, 09:10 PM
#1
Member
Real Name: 1997 4RUNNER
Member
Issues with Duralast Fuel filter?
So I decided to replace my fuel filter, and I grabbed the Duralast Fuel Filter FF692DL from autozone for $20. It leaked like crazy! So I swapped it out for another one and had the exact same issue! Today I went to toyota and grabbed the OEM for $50.
Has anyone else had this issue? Are Duralast products just trash?
01-10-2020, 10:45 PM
#2
Elite Member
Real Name: Jon
Elite Member
Real Name: Jon
I only used OEM fuel filters so I cant say much about the A/M filters. However, this dosent surprise me at all as sadly most of the A/M parts are junk.
Sent from my SM-J337V using Tapatalk
__________________
7 3rd gens listed in the build thread (2 are parts mobiles)
Build Thread: https://www.toyota-4runner.org/3rd-g...os-builds.html
Brillo's Bucket Fluid Ex changer: https://www.toyota-4runner.org/3rd-g...ml#post3358086
Sparks Plugs Wire and Coil Information: https://www.toyota-4runner.org/3rd-g...on-5vz-fe.html
01-10-2020, 10:51 PM
#3
Junior Member
Junior Member
I avoid AutoZone unless it is an emergency situation.
01-11-2020, 12:14 AM
#4
Member
Member
I will only be buying OEM parts from now on! Thanks for the imput
01-11-2020, 10:03 PM
#5
Senior Member
Location: north east of Fairbank out there in the frontiers Alaska
Real Name: 3 Bears
Senior Member
Real Name: 3 Bears
Ive used bosch and mann in the past with no issues. However current one and spare on shelf are Toyota.
there are some parts I think are safe to use as aftermarket.
However...through some of the online dealers and if the order big enough to pay for free shipping, Toyota filters can be very cost effective.
Saddly… I moved to Alaska a year ago and the boys I used to use wont do free shipping. The local dealer will only price match to other Alaska dealers.
__________________
2000 SR-5 Highlander version 4:30's, factory locker , green, bought 6/21
2001 SR-5... bought 11/20..sold 6/21....
2000 SR-5 moded, lifted, e locker, other cool stuff, totaled 10/20
01-11-2020, 10:12 PM
#6
Member
Member
I replaced mine about a year ago, and I believe it’s made by Mann. When I replaced it, it started leaking, and I had to loosen the nut and re-tighten, as I was stupid and the nipple didn’t line up quite correctly. After that, I haven’t had any issues.
I would check and make sure the nipples on both ends are lined up correctly before you tighten the nuts.
01-12-2020, 12:28 AM
#7
Member
Member
They generally come with copper crush cone type washers. I’ve had to use them on older rigs where the fuel line flare was pretty worn from years of use.
But generally steel flare to steel cone works fine.
This doesn’t seem to be an aftermarket only problem as far as I’ve seen.
__________________
Owned 82, 83, 87 pickup, 98, 99 SR5 4runner
Currently own a 98 SR5, 5spd, 4x4, e-locker, no sunroof. 2012 LTD with the normal options.
01-12-2020, 05:18 AM
#8
Junior Member
Junior Member
Dunno about duralast but sounds like It is wise to avoid.
I recently bought a Beck Arnley from advance for around $30 . Mistakenly thought it was going to be better Quality...opened it up and saw made in China.
Took it back ....for an oem 32$ when I looked it up.
Some parts (most for these) should stick with oem if possible and shop around
01-12-2020, 12:27 PM
#9
Senior Member
Senior Member
You are not the first person to post about this. Others in the past have had trouble with leaking aftermarket filters and eventually put OEM in. I'm not going to search for past threads but there have been some before.
__________________
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906/Toyota OEM rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
01-12-2020, 07:50 PM
#10
Junior Member
Junior Member
I work at AutoZone and can honestly say most of the parts are 50/50 on the quality, either they're great and work fine, or they're absolute trash. I'll actually be returning my dualist fuel filter tomorrow but for a completely different reason. Not to steal the thunder of this thread, but has anyone else has a problem even FINDING the fuel filter? I first looked where everyone else says it is to be, under the drivers door along the frame, nope. I went even further and actually followed the fuel lines from the tank to the engine and still didn't find it. Could the previous owner possibly have bypassed it somehow?
01-12-2020, 09:18 PM
#11
Senior Member
Senior Member
Quote:
Judging by your username I'm gonna assume you've got a 4 cylinder. If so, it's hiding underneath the intake manifold bolted the the side of the motor. Grab a flashlight and look into the driver's side wheel well and past the starter, it's right there. Terrible spot to get to, I personally wouldn't recommend replacing it unless you're having problems since it's such a pain.
Sent from my JSN-L23 using Tapatalk
__________________
'97 3RZ 5 Speed "FrankenRunner" ( Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - ( Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
01-12-2020, 11:18 PM
#12
Senior Member
Senior Member
I've read on this forum the problems other members had with aftermarket fuel filters leaking at the fittings time and time again. When it came time to replace mines it was OEM toyota fuel filter only. No issues after install on 2 occasions now.
01-12-2020, 11:39 PM
#13
Junior Member
Junior Member
Preciate the input! Thanks!
01-13-2020, 12:22 AM
#14
Member
Member
I use Napa Gold or OEM for any of my vehicles.
__________________
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
01-13-2020, 04:36 AM
#15
Member
Location: Southern California (please don't hold it against me)
Real Name: michael
Member
Real Name: michael
I got a Bosch filter for my 2001 and it came with a small sealing disk for the in and out. Tried to figure out how to hold them in place while i inserted the lines. I ended up using some heavy axle grease to hold them in place. I tried to put it on with out the sealing disk I could not get them to stop leaking.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
