Old 01-11-2020, 12:19 PM #1
FrogginAround's Avatar
FrogginAround FrogginAround is offline
FrogginAround is on a distinguished road
Door Drain
Is there a drain on the doors by any chance? I currently have a piece of cladding which snapped off the front passenger door. I plan on replacing it but was wondering if it will fill with water and debris in the meantime with no way of draining it. Thanks.
Door Drain-resized_20200111_081637-jpg
FrogginAround is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 12:35 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
There are small drain holes in the bottom of the doors
Old 01-11-2020, 01:18 PM #3
Awesome. Thanks for the response.
Old 01-13-2020, 02:43 PM #4
Plenty of water gets in the top of the door where it meets the window. You'll be fine.
Water can make to the inside (from the top of the door) if the inner door plastic isn't in place correctly and sealed - but if you aren't having problems with that now, those cladding holes won't be a problem either.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-13-2020, 03:31 PM #5
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Water drains right out the body pinch welds. That's exactly where the front sunroof drains lead to. If you pour water into your front drains, you will see it dripping right out of the pinch welds. I'm assuming it would be the same all along the body pinch welds where water can make it's way out.
This video will give you a demonstration of what I'm talking about. Go to play time 11:41.
Old 01-13-2020, 07:12 PM #6
Mark_BC's Avatar
Mark_BC Mark_BC is offline
Real Name: Just call me the Grease Monkey
Mark_BC has a spectacular aura about Mark_BC has a spectacular aura about
Mark_BC's Avatar
If you live in tha salt zone you shud spray rust inhibitor in those bottom holes of the door to prevent them from rusting from the inside out as salty water will drip in from the windows. Not fluid film as it will stink up your truck in summer but something linseed oil based. In Canada we have rust cure 3000 which is awesome but you yanks dont get it.
My Snow and Sand build thread
Mark_BC's 2000 Limited Salvage Build
Determined to keep them from becoming parts trucks. Yes, even the one I just picked up as a parts truck...
Mark_BC is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 11:49 PM #7
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
I use WD40. Block the holes and let it soak in.
Old 01-14-2020, 03:13 PM #8
Tampa_T4R Tampa_T4R is offline
Real Name: Doug
Tampa_T4R is on a distinguished road
Real Name: Doug
yikes
Tampa_T4R is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 09:34 PM #9
Thanks for all the responses guys. Once again you guys are an awesome source of information. Thank you so much.
Old 01-14-2020, 09:41 PM #10
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I have my doors and rockers full of fluid film. WD-40 is another good choice.
debris , door , drain , meantime , water
DIY: Replace door courtesy / door jamb switch (fix door ajar light and door sensor) andrewbares 3rd gen T4Rs 17 05-16-2021 03:17 PM
Coolant drain and fill. Block drain plugs. lj4r 4th Gen T4Rs 2 11-24-2018 07:11 PM
Door buzzer stereo and clock all stay on and drain battery..how do you fix it? White87sr5 Classic T4Rs 9 04-24-2015 04:09 PM
Budbuilt 3rd gen 4runner skid with custom oil drain door- Pomona CA $300 SIKHILUXSURF For Sale: T4R Items 25 03-18-2015 05:17 PM
