Old 01-11-2020, 12:19 PM #1
jerbrun0515's Avatar
jerbrun0515 jerbrun0515 is offline
jerbrun0515 will become famous soon enough
How would you mount these KC Hilites Pro6 lights?
I just picked up a pair of KC Hilites Pro6 6" LED lights to mount on my Shrockworks front bumper. Was getting tired of the severely lacking stock lights when off-roading.
I was hoping to mount them in the two pre-existing holes for that purpose on the top center of the bumper. Unfortunately, though, there is not quite enough depth in front of the grill there for the lights to drop fit right in.
The Pro6's have a 3/4" ball stud mount that can angle forward and backward quite a bit. I've looked for universal light riser brackets and the like, but not having a lot of luck. I think I need to get the light up and/or forward in order to get the light to fit right.
The holes in question are the two oval holes about 6" to either side of the Toyota emblem.
Ideas?
Sent from my SM-G965U1 using Tapatalk
jerbrun0515 is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 02:40 PM #2
RunningForNow RunningForNow is offline
RunningForNow is on a distinguished road
Maybe you can fab up (or have someone do it) a U-bracket? Mount the lights on the bracket, and make sure the strips on either sides are long enough to give you the clearance you need. Or, instead of a U-bracket, just have a plate made with holes drilled out to mount to the bumper, and holes for the lights.
Thanks for this. I’ll put this on the list of things to consider when I do order a bumper in the future.
RunningForNow is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 04:11 PM #3
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Just make up a bracket to push them forward a bit. A little steel plate from Lowes and some stainless hardware should get you going. I could fab something in about an hour probably in my little garage workshop with an angle grinder.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 07:04 PM #4
Thanks for the great tips guys. I'm not always the first to dive into custom fabrication so initially I was hoping there would be some universal light mounting hardware that someone might point out that I had missed.
That being said, I think you're both right that I'm going to have to go the DIY route. The other option I'm considering is taking a Dremel and elongating the existing holes forward. I'm pretty certain there is adequate spacing there but I'm going to go out and do some measurements tomorrow.
Old 01-11-2020, 09:57 PM #5
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
I agree it's east to fab on the cheap. I can't tell the dimensions from the photo. But if you want to spend the extra use try these...
KC HiLites Tube Clamp Mount Bracket Pair for 1.75 Inch to 2 Inch Round Light Bars - K/C73071 | 4wheelparts.com
Mount to the top of your bumper bar and hang the lights upside down so their in front of your grill and out of your view of the hood...
If the lights have rock guards rotate them to read correct...
G_Raw is offline   Reply With QuoteReply With Quote
Old 01-11-2020, 10:03 PM #6
Looking at the existing holes above the bumper, the Dremel idea could work, depending on how deep the lights are. Another thing that could work is making yourself a Satoshi grille, where the intake part is recessed as opposed to your current grille, which is mostly protruded. I know not everyone is into the Satoshi grille look, but I’m a fan of it.
Old 01-12-2020, 01:15 AM #7
UnderFire's Avatar
UnderFire UnderFire is offline
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
They don't give you much room at all there by the looks of it. If I had to guess those holes are for an LED bar, I can't think of any round lights that would fit off the top of my head.
Sent from my JSN-L23 using Tapatalk
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 04:17 AM #8
Dropzone's Avatar
Dropzone Dropzone is offline
Dropzone is a jewel in the rough Dropzone is a jewel in the rough Dropzone is a jewel in the rough
Dropzone's Avatar
Trim the grill so you have clearance for the back of the lights.
1994 4Runner AKA: Project Recycle
@503dropzone on IG
Dropzone is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 09:32 AM #9
Shrockworks definitely offers several different Baja Designs (and previously PIAA) lights as an option for the top. Not sure what the dimensions of those lights are, but I also wonder if the previous owner who installed my bumper might have installed it a fraction of an inch tighter than spec?
1996-2002 4Runner Front Bumper, 3rd Generation
Old 01-12-2020, 12:12 PM #10
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
I don't have that bumper or lights. Just some thoughts or considerations.
- The type of light or beam pattern. Location matters for performance.
- Don't want to significantly obstruct other lighting
- Protection. There would be added protection if within the hoop, as opposed to outside it.
- Obstruction of airflow to the heat-exchangers, like A/C condenser, radiator, others added..
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 05:05 PM #11
prcGTI's Avatar
prcGTI prcGTI is offline
Real Name: Jeff
prcGTI is on a distinguished road
prcGTI's Avatar
Real Name: Jeff
Nilight 90020B 2-Pack (Standard) Mounting Bracket Kit LED Off-Road Light Horizontal Bar Tube Clamp Roof Roll Cage Holder
https://www.amazon.com/dp/B0714CYKBJ..._gJ4gEbX51Y35S
Similar to the KC lights bracket option but these fit up to a 2” diameter bar. I have the same bumper but currently have an led light bar but was looking at these for a mounting round lights.
prcGTI
2001 4Runner SR5 4x4, V6 Auto, ME Silver|2nd Owner|5 Stars with 265/75/R16 Falken Wildpeak AT3Ws
4.88s w/ front and rear ARB lockers|Shrockworks front bumper, rear bumper with swing out, and rock sliders|Tundra TRD Pro springs and Bilstein 5100s|OME 890 springs and Bilstein 5100s|SS Fully Adjustable Trac/PanHard Bar|SS Diff drop|TBU – 13WL calipers w/ Stoptech slotted rotors|Prinsu full length roof rack|Smittybuilt X20 winch|ARB CKMA12 compressor
prcGTI is offline   Reply With QuoteReply With Quote
Old 01-16-2020, 02:42 PM #12
Well, I bit the bullet and purchased some KC HiLites Tube Clamp mounts. Wasn't sure exactly how I would configure it but I wanted to experiment with them and the lights in hand.
I'm liking the outcome so far. I was able to move the lights out away from the grill just a hair and still keep them within the center hoop for protection.
Night pictures are of lows, highs, then HiLites.
Whatya think?
Old 01-17-2020, 06:35 PM #13
prcGTI's Avatar
Real Name: Jeff
prcGTI's Avatar
Real Name: Jeff
The KC tube clamp solution looks good!
Old 01-17-2020, 06:57 PM #14
R Marra R Marra is offline
R Marra is on a distinguished road
Ok, so i have to ask what headlight bulbs are you using. I am running the silver stars and they are no where that bright. Thanks Ray.
R Marra is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 09:26 PM #15
TBH I don't even know what they are. I bought the truck last spring and it's what came with it. They do seem a little whiter more like a silver star and there is a blue reflection to them in daylight just looking in through the glass. They are not bad, but still aren't great at all in lowlight woods and off-road trails.
fit , forward , light , lights , mount
KC HiLites Pro6 Roof Rack for 5th Gen 4Runner TotalAutomotiveLV 5th gen T4Rs 7 02-04-2024 12:28 PM
KC HiLites Gravity PRO6 LED Light Bar - Game Changer Desgin! what do you think? TotalAutomotiveLV General Discussions 21 05-16-2019 01:11 PM
Who has installed the KC Hilites pro6 light bar? Charlievee 5th gen T4Rs 0 03-13-2019 07:56 PM
KC Hilites Ditch Mount Led Light Kit Battle Born Offroad Battle Born Offroad 0 11-08-2018 07:15 PM
PREORDER EXCLUSIVE - KC HiLites PRO6 LED Light Bar - Newest Desgin on the market! TotalAutomotiveLV Total Automotive Performance 2 05-24-2016 07:06 PM
