Old 01-11-2020, 01:31 PM #1
SeaDug SeaDug is offline
Real Name: Sean
SeaDug is on a distinguished road
Real Name: Sean
Body Lift help ASAP
So i just finished installing the passenger side of my Toytec 1in body lift, and I'm stuck on the very front drivers side mount. It seems like the bolt is stuck inside of the sleeve at the bottom. Anyone know a way to fix this? I need to get new tires put on in about 4 hours and have been working at this one mount for almost an hour so far. Thanks.
SeaDug is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 01:15 AM #2
rallypoint_1's Avatar
rallypoint_1 rallypoint_1 is offline
Real Name: Bill
rallypoint_1 is on a distinguished road
Real Name: Bill
I know this is late but the bolt should come out. Did you try to lift or lower the body seeing it was stuck? To see if the bolt would come out. Weird..it should lift up.
1998 T4R SR5 V6 2wd Evergreen Pearl OME 880 Toytec 1/4" spacer OME 906w/OME20mm(10mmx2)spacers Bilstein 5100 BFG KO2 31's Satoshi mod 1.5" BL(Fat Pats)
My 4Runner build:
http://www.toyota-4runner.org/3rd-ge...8-sr5-2wd.html
rallypoint_1 is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 10:11 AM #3
ccurrans ccurrans is offline
ccurrans is on a distinguished road
Sounds like you didnt take all the bolts out first and by doing this one last it is wedge in?
ccurrans is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 11:08 AM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Maybe this video will help you out. When we did this job, we had no problems getting any of the bolts out. It might just be a slight corrosion problem and you need to give the bolt a little persuasion with a hammer or mallet to get it out.
Old 01-12-2020, 11:58 AM #5
TonyB66's Avatar
TonyB66 TonyB66 is offline
Real Name: Tony (no surprise)
TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light TonyB66 is a glorious beacon of light
TonyB66's Avatar
Doing this right now actually, hopefully finishing today...
Since you got one side done, and it's 1" higher, or more if still jacked, it's possible the delta between the two sides has made for some binding. If you haven't already done so, raise and lower the two sides to see if it frees-up. Lightly tap upward on the end of what should be a pointy bolt. I imagine you did this on level ground, and if not, that too can introduce such dynamics...
I have a winch control box in that spot on the passenger side that I might have to move, but it's plenty free, like the driver side that came-out with ease.
I'm having a hard time removing the A-pillar plate attached to the frame perch with two bolts (14mm heads/15mm nuts). Cordless impact not cutting it, so I'll go air in a bit. It seems that many or all BL kits don't remove the factory rubber, so this might not be something the OP will need to do...
2000 Limited, E-locker
Maintenance/Build Thread
TonyB66 is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 06:57 PM #6
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
I had exactly that issue on my frame swap. Of all the mounts, that was the only one that required a Sawzall. It was totally frozen, but I'm in NJ, not Phoenix. I hope you have better luck.
My Backyard Frame Swap
Old 01-12-2020, 10:27 PM #7
Real Name: Sean
Real Name: Sean
Thanks to all you guys, but this ended up being the problem. The bolt was seized (either bent or rusted) inside of the sleeve it threads into. This prevented it from being able to thread out. Took a Sawzall to it and sliced right through. I kept the bushing on (cut in half) and was able to continue as normal. Hopefully, this can help others with the same problem.
Old 01-13-2020, 01:22 PM #8
kyle_seal kyle_seal is offline
kyle_seal is on a distinguished road
I would also recommend doing body bushings while you're in there as well. Not a job you want to go back and do again!
kyle_seal is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 03:53 PM #9
TheDurk's Avatar
TheDurk's Avatar
As I recall, it's not a threaded sleeve. It just slides in, until the corrosion locks it in.
Old 01-13-2020, 03:59 PM #10
TonyB66's Avatar
TonyB66's Avatar
Yup, it drops-in, at least should.
Old 01-14-2020, 11:08 AM #11
Real Name: Sean
Real Name: Sean
Oh, my bad. I honestly couldn't tell with how corroded it was.
body , lift , mount , side , stuck
Body lift help asap SavinWillyWonka 4th Gen T4Rs 21 12-01-2014 11:21 AM
Need a lift ASAP, please help. bubbasmeat 4th Gen T4Rs 6 12-01-2013 12:04 AM
Polyurethane replacement body mounts with body lift opinions? ellner357 3rd gen T4Rs 0 02-02-2013 12:42 PM
Need spacer lift asap! R1FIGHTER 4th Gen T4Rs 8 05-27-2010 11:29 AM
Lift, question! doing asap! Shipoopi 4th Gen T4Rs 9 08-05-2009 01:27 AM
