01-21-2009, 12:59 PM
skid plate removal
stupid question here.... how do i remove the skid plate? I removed all the bolts I could see from under the 4runner and it seems like it should just fall off, but it seems like it is still attached somehow. is there a clip or something? thanks.
chris
01-21-2009, 01:11 PM
There are two pieces, the front and back. After removing the bolts for the rear piece, you kinda have to wiggle it to get it out. For the front plate, there are two bolts that are deeply sunken in, so you are going to have to get a socket extension of some sort to be able to reach it. Hope that helps.
2000 4Runner Limited 4x4
Kenwood DNX7100 HU
Alpine SPR-17S Component Speakers
01-21-2009, 01:44 PM
On my '00, the front plate has 7 bolts total: 3 up front, 2 recessed mid-way and 2 rear. I don't bother removing the rear plate.
Rick
'90 T4R - sold at 205,000 miles
'00 T4R - sold at 152,000 miles
'08 Sport - 178,000 miles & still going strong
'19 ORP - just over 6,000 mi. (garage queen, like my '07 Mustang)
01-21-2009, 01:52 PM
There are hooks on the very front of the first plate but as the others said it is probably the rear skid plate bolts that are keeping the skid from dropping.
01-21-2009, 05:17 PM
thanks, got it. appreciate your help.
07-15-2011, 12:19 PM
hi i'm trying to remove the plates on an '02. is there anything different?
2002 2WD Thundercloud Metallic
Toytec Ultimate Lift Kit, 285/70/16 Nitto Trail Grapplers,LC80's, Outdoor Logic Front Bumper, HID Headlights, Clear Corners w/ LED ambers , Window Vent Visors, Plastidipped
07-15-2011, 05:40 PM
Nope.
1997 3.4l SR5 5spd 4WD E-locked. Blue wire mod, 99 tall springs, 32" Duratracs, Satoshi Grill, Tundra 231 brakes, 99 center console.
1988 3.0l 5spd Pickup SAS on 35s with 5.29's, welded 8.4 rear, custom flat bed, on board air, XRC8 winch, homemade sliders.
05-16-2015, 02:01 PM
12 mm all 7?
All 7 are 12 mm - 6 point sockets work better to avoid stripping the bolts. Middle bolts are in the holes on the slope of the front plate.
2000 4Runner Limited V6
1997 4Runner Limited V6
03-09-2017, 01:47 PM
A couple of the hex bolt heads that mount into the frame up front have sheared off. I think it's because of the rust - it's an '01 SR5.
Anyone have any ideas on how to remove the rest of the bolt? I've got nothing for a socket to grab onto. Darn things rattlin' like a you-know-what.
Do even worry about it? Should I just remove the whole plate altogether? I worry about the radiator hanging so low. Advice would be appreciated!
03-09-2017, 01:52 PM
Drill them out
2000 4Runner SR5 Sport
1998 Lexus LX470
03-09-2017, 02:08 PM
shoot a little Blaster on em and grab em from the top with a visegrip, worked for me.
03-09-2017, 02:15 PM
Here is how I did one of those bolts. This was with the frame off the truck and upside down, so it makes for great pics. But the process is the same.
Frame Rot!! Is this the end?
My Backyard Frame Swap
03-09-2017, 02:21 PM
Thank you for the quick responses! Looks like I have plans Saturday....
How bad would it be to run without the skid plate removed?
03-09-2017, 02:24 PM
Highway/street no problem. Off-road? Depends on the terrain.
03-09-2017, 02:27 PM
99% Street/Highway. Occasional snow when commuting to work in winter.
