Old 01-12-2020, 10:43 PM #1
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
Strut top bolt doesn't have enough threads
So I installed 90004 OME struts wit 883 coils ( I have armor and winch up front). My drivers side went fine. On my passenger side I couldn't get the strut to feed through enough to put the rubber bushing, wash and nut on. I tried a thinner washer, a thinner bushing ( my old compressed one) and nothing. I'm not driving it as it is because currently all I could do was put my old worn compressed bushing on with the nut.
I tried compressing the spring again jacking up the lca. No go.
I tried adding a bottle jack into the mix with my hydraulic to further compress my lca...No go.
Any ideas?
Thanks in advance.
G_Raw is offline   Reply With QuoteReply With Quote
Old 01-12-2020, 11:11 PM #2
HiLife HiLife is offline
Not the proper way to do it but, in a pinch, I would try to compress the spring evenly with ratchet straps on both sides.
The proper way to compress the spring is to use a dedicated spring compressor tool.
Old 01-12-2020, 11:13 PM #3
nissanh nissanh is offline
Did you mount the bottom spring resting plate on the strut upside down?
Old 01-13-2020, 02:51 AM #4
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
let the weight of the vehicle compress the coils by installing the tires then release the jack. you can then tighten the nut and apply a second nut to lock the first nut.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 09:18 AM #5
G_Raw's Avatar
G_Raw's Avatar
Nope. Installed same way on driver side and went super smooth. The set plate is oriented correctly with the spring sitting in the plate correctly.
I may try to double nut method mentioned above to pull the threads through...
Old 01-13-2020, 09:46 AM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Like HiLife says. Use a spring compressor so you dont get hurt. I believe eurozone will let you buy a tool and return it so you can rent it for free.
Old 01-13-2020, 10:38 AM #7
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
HiluxSurf SSR-G has the right idea. Let the weight of the vehicle sit on the strut. If that does not give you enough thread than you have a problem that needs to be corrected or your parts are defective somehow
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 01:14 PM #8
kyle_seal kyle_seal is offline
kyle_seal is on a distinguished road
Best thing to do would be to remove strut and use a compressing tool to get more threads available.
kyle_seal is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 01:19 PM #9
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Before taking the strut off, try this. Put the nut on without the washer and tighten it down snugly but don't totally crank on it. This will compress the rubber bushings a little so when you take the nut off, there's a good chance you'll now have threads showing above the washer so you can get the nut threaded on the shaft and you can tighten it all back up.
Old 01-16-2020, 09:40 AM #10
G_Raw's Avatar
G_Raw's Avatar
Let the vehicle sit over night, went out the next morning and things had settled enough to let me get the new bushing and washer on with just enough thread to start the bolt. Got it all assembled and torqued to spec. Thanks all for the input.
bushing , compressed , nut , put , thinner
Damaged Caliper bolt threads hkazmi 5th gen T4Rs 7 09-12-2018 09:38 AM
Passennger rear wheel well rubber coating missing over threads of bolt? 1996_Valencia_Owen 5th gen T4Rs 20 05-22-2018 12:44 AM
lower strut mounting bolt and nut Herculean T4R 3rd gen T4Rs 12 03-28-2015 11:27 AM
HELP! Rounded Bolt. Doesn't come out! d0nkeyxpunch 3rd gen T4Rs 31 12-28-2014 12:41 PM
Roll bar bolt threads Corporal6531 General Discussions 8 07-06-2012 10:36 PM
