Old 01-13-2020, 06:06 PM #1
VernySanders's Avatar
VernySanders VernySanders is offline
Real Name: Werner
VernySanders will become famous soon enough VernySanders will become famous soon enough
Real Name: Werner
Hesitant to start. Intermittently.
Hello all you great forum members! Nothing too crazy but I wanted to know if anyone has had any experience with this or not. Aka should I look further into it or just leave it.
Every once in a while probably once ever 50 starts my truck doesnt want to start right up like it usually does it will just turn over. Obviously it's not a starter issue, I'm thinking it's something fuel related, however I must say, the first time I ever encountered this was shortly after installing my cold air intake, has anyone else encountered this? Even on cold starts in 20 degree weather my truck turns over for a half second and fires right up so I thought this to be odd.
Thanks all!
VernySanders is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 06:36 PM #2
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
It could be a sticky IAC valve.
Old 01-13-2020, 06:55 PM #3
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
I just had problem with my Cat Converters and it would present like this. It fooled me for a while until I put a simple Vac gauge on it to see that Vac was low at idle. This maybe not be your problem but don't count it out.
plcfcng is offline   Reply With QuoteReply With Quote
Old 01-14-2020, 09:46 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Clogged cats?
Old 01-14-2020, 10:28 AM #5
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You've got me scratching my head on this one. Like @Bad Luck , are you saying your catalytic converters were blocked up? Also, what did you put a vacuum gauge on?
If you are talking about blocked up catalytic converters, why would that cause an intermittent hard start. I would think it would be more of a constant issue if the cats were in bad shape.
Old 01-14-2020, 11:08 AM #6
spartacus's Avatar
spartacus's Avatar
It could also be related to fuel pressure at start up. I cleaned the maf replaced the fuel filter , checked and cleaned the battery terminals etc but the symptoms remained. Ended up being the oe fuel pump, which finally gave up after a year or so but lasted about 300k so it was due.
Old 01-14-2020, 12:20 PM #7
Real Name: Patrick
Real Name: Patrick
I've seen blocked cats cause mid-low range and above rpm loss of power and lower intake vacuum because of the restriction, but I've never heard of it causing a intermittent start issue.
Old 01-14-2020, 01:17 PM #8
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Yeah, I've heard of the loss of power as well with blocked cats, but like you, I haven't heard of it causing an intermittent starting issue either.
I'd like to see how somebody measures the intake vacuum pressure.
Old 01-14-2020, 01:24 PM #9
Real Name: Werner
Real Name: Werner
I'm going to do the fuel pump and filter soon. I already have the OEM filter replacement just need the pump. This is a good suggestion I appreciate it!
Old 01-14-2020, 01:25 PM #10
Real Name: Werner
Real Name: Werner
I will add this to the list! Fortunately I deleted one of my cats and the other is brand new so no need to even consider cats.
Old 01-14-2020, 01:54 PM #11
19963.4lsr5 19963.4lsr5 is online now
I’d do the IAC first
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 01-14-2020, 04:08 PM #12
Real Name: Patrick
Real Name: Patrick
You should be able to hook a vacuum gauge to where the brake booster connects to the intake.
Old 01-14-2020, 04:14 PM #13
Real Name: Werner
Real Name: Werner
I'm just going to do it all! I never shy from proper preventative maintenance! Neither do you I'm sure that's why I love this forum! Honestly best online community for any vehicle that I've ever come across.
Old 01-14-2020, 05:57 PM #14
I’m going to say this......
As part of our collective and sharing knowledge, shotgunning the problem by replacing a bunch of things at the same time may fix it but not define what was the actual problem from a troubleshooting perspective.
You can still replace all the things you want but do it one part at a time to figure out what’s causing the problem.
There are a bunch of extended crank threads without any solution. My Ex’s 97 Puppy Hauler would start normal in about 2 seconds on the starter. Then on occasion it would take longer. 5 or so. It’s not my problem anymore.
If it was my problem I’d do the IAC first since at times I caught it idling high. And cleaning it would fix it.
Second I’d watch fuel rail pressure to see if a injector was leaking and bleeding off rail pressure.
Third would be fuel filter (in my case it’s only two years old)
Fourth would be fuel pump.
I do not think our fuel pump starts running until it’s put to start. American rigs will run the fuel pump at ignition on for a few seconds and after it detects engine run it will keep it running.
Old 01-15-2020, 10:22 PM #15
Real Name: Werner
Real Name: Werner
You're logic is extremely true! Usually when trying to fix something troubleshooting is the best way or else like you said you're just throwing a bunch of parts at it, in this case I was leaning more towards doing all three just because theres really no way for me to know if what I did worked or not unless my truck does the same thing again which may more may not happen. Perks of not having any prior maintenance records on a 20 year old truck Haha I get to replace everything! When i dug down to the timing belt to replace it that bad boy was on its last leg. I've been under the impression for quite some time that the maintenance wasnt kept up very well on my truck. I dont notice any high idle or anything just every once in a while a good 5 second crank kinda like you said.
cold , encountered , start , starts , truck
Help! 98 3.4 V6 Hesitant/surging under acceleration on incline Guy Bri 3rd gen T4Rs 17 12-02-2018 09:22 PM
Elocker rebuild, hesitant to try arthurm 5th gen T4Rs 4 07-20-2018 12:05 AM
2005 4Runner Won't Start Intermittently flcoasterguy2 4th Gen T4Rs 21 01-21-2018 09:42 PM
Need help/ advice.. Hesitant throttle response dnbprofessor 3rd gen T4Rs 0 08-03-2012 03:54 PM
For those hesitant about extended oil change intervals... Toyodas Maintenance/Detailing 3 10-28-2010 07:25 PM
