01-16-2020, 09:58 AM
#16
Originally Posted by 4runnerfiend
not sure if they are waterproof.. but I have heard of people mounting them under the hood. to each his own.
Would the heat from the engine not be too much for the unit? Since it already gets hot.
01-16-2020, 11:48 AM
#17
Real Name: Reinout
Real Name: Reinout
Great price: maybe get one so I don't have to switch my VIAIR back and forth.
Yes, these things get hot, moving parts, electricity, and compressed air does that.
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
01-16-2020, 12:13 PM
#18
Originally Posted by Bumbo
I kinda want two of them... put them in parallel for very fast tire fill speeds.
I found such a beast a few years ago. sold out of Australia. it was only around $100 USD. but, total to get it imported to the states was going to be closer to $600. so I scrapped the idea.
it was essentially this same compressor, except it had another pump head on the other end. it was rated at basically double of this one, 11cfm or so. crazy!
1985 pickup : EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5 : 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited : stock. Build Thread YouTube Channel
01-17-2020, 01:13 PM
#19
I doubt the engine heat would be too much for these. Unless you have lines running next to the exhaust manifold.
IG: @4runnerfiend- 1999 SR5: TRD Supercharger, ELocker, Wheelers T1 Coils-tundra 5100's, Built Right UCA's, LC 8 wraps-Fox 2.0 with CD adjuster, Rokmen lower links, Savage skids, Hot Metal Fab Front Tube bumper, Savage Rear tube bumper, TruckShopSD Sliders, DuroBumps, RidgeGrapplers, Doug Thorley Headers, yellow top, XRC 12k, ARB single compressor.
01-17-2020, 01:27 PM
#20
Sounds like they utilized a single motor with two pistons to increase the volume?
I still like the idea of two separate units, it provides fault tolerance should one ever fail.
Sometimes one is none.
01-17-2020, 02:05 PM
#21
correct. one motor, 2 pump heads.
and yes, I agree about redundancy.
https://www.4wdsupacentre.com.au/thu...FlZq23J7orOGvg
01-17-2020, 02:15 PM
#22
Well heck… for $50 more I can get 2x the CFM.
I might as well just get two of those and have 22 CFM for $300
01-17-2020, 02:21 PM
#23
if you live in Australia...
they don't export them.
I know some people that live there. I was going to have them buy it, and ship it to me. it was going to be about $600.
literally cheaper to fly there, buy it, and fly back...
01-17-2020, 04:49 PM
#24
Real Name: Jake
Real Name: Jake
just bought it, arrives next week! been waiting for a price drop for a while.
https://i.imgur.com/WQdryKXm.jpg
The Sequel - 1996 4Runner SR5 - Houston, TX
The Original - 2001 4runner SR5 - SOLD
Etsy Page - Custom Pinstriping and Sign Making
@8LinePinstripe: Instagram
01-17-2020, 07:17 PM
#25
So FYI the pressure gauge that it comes with is terrible. Best mod to do on this is cut the fitting off the end and replace it with a standard quick connect. Then get a digital pressure gauge of your choice. Rhino has a good one, ARB is the best or my buddy has been running this cheap one for a while with no issues.
I'm actually running the Morrflate system that connects all the tires. which is baddass.. but its almost 200 bucks. Was a gift but I freaking love it.
Inflate/deflate all 4 tires at once with the MORRFlate
https://www.amazon.com/Rhino-USA-Inf...language=en_US
https://www.amazon.com/ARB-ARB601-Pr...language=en_US
https://www.amazon.com/gp/product/B0...language=en_US
01-18-2020, 12:43 AM
#26
Last year my local 4wheel parts had this on sale for $90. Highly recommend throwing away the junk yellow flexible hose. I bought a flexible hose rated for heat with thicker material. I also ditched the oddball connections. Upgraded to standard brass fittings that match the house compressor and two other vehicles.
2018 Offroad Premium w/KDSS
1993 Jeep YJ w/stuff
01-20-2020, 03:37 PM
#27
Real Name: Dan
Real Name: Dan
mine will be here on thursday
01-21-2020, 10:06 PM
#28
Real Name: Alan
Real Name: Alan
Thanks for the heads up.I snagged one
01-22-2020, 12:25 PM
#29
Mine showed up yesterday, this thing is beefy!
-Rob
01-22-2020, 01:48 PM
#30
did you buy the shorter version of the morrflate? its a fantastic idea but very pricey for what it is at $180-200. my father plumbs sprint cars in his spare time, so i may show him a couple of pictures and see what we can do to make myself one.
99 4runner limited; imperial jade mica
IG: mesooohoppy
