Originally Posted by nevada
I went to harbor freight, and bought 2 of their coiled hoses, for about $6 each. then I got a couple quick disconnects, a TEE and a pair of euro lock on chucks. I do 2 tires at a time. works great.
I considered doing 4, but didn't want to deal with that much hose. and, its too easy to overinflate tires. too many things going on...
Cool thank you. i know this can be built for much cheaper, its just how much time am i willing to invest in it.
i like the all 4 corners approach, more time to have fun and/or do other things. although i do share the same worries you have. im sure if you have a tire that is a couple of LBs off, it will just create an average reading of all 4 through equilibrium. for 100% piece of mind you would likely need to go back through after youve aired up and make sure everything is good to go. im sure the hoses get it real close, but when you have real world factors at play messing with each individual tire, its damn near impossible to keep all 4 at the same PSI with this type of line/setup.
